Vandaag om 00:32:31
Vandaag om 00:07:35
17 February 2026, 23:53:29
17 February 2026, 23:33:12
17 February 2026, 23:17:28
17 February 2026, 23:03:24
17 February 2026, 23:02:46
17 February 2026, 22:53:29
17 February 2026, 22:52:33
17 February 2026, 22:25:54
17 February 2026, 21:53:49
17 February 2026, 21:52:21
17 February 2026, 21:41:11
17 February 2026, 21:41:05
17 February 2026, 21:37:24
17 February 2026, 20:39:30
17 February 2026, 20:27:09
17 February 2026, 20:06:51
17 February 2026, 19:36:48
17 February 2026, 19:34:07
17 February 2026, 19:21:28
17 February 2026, 19:17:24
17 February 2026, 19:13:40
17 February 2026, 19:13:00
17 February 2026, 18:23:36
17 February 2026, 18:14:32
17 February 2026, 18:01:26
17 February 2026, 17:48:00
17 February 2026, 17:29:24
17 February 2026, 16:28:43
Auteur Topic: LED-strips van Kruidvat, is dat wat?  (gelezen 28903 keer)
RocoKolkie
  • Module baan DCC/analoog Duits II/III
Re: LED-strips van Kruidvat, is dat wat?
« Reactie #15 Gepost op: 07 October 2013, 14:04:04 »
http://www.ebay.com/itm/Warm-white-Waterproof-3000K-5M-5050-SMD-Flexible-LED-Strip-Light-300-Leds-500CM-/150827185024?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item231e003380....errug goedkoop...omgerekend 10,75...
Mooi voordelig idd Martin!
Ik heb net een LED pakket gekocht bij de Kruidvat. Heb gekozen voor de multicolor van 5 meter.
Betreft een complete set bestaande uit:
Rol a 5mrt RGB leds 150 stuks (iedere 10cm 3 ledjes) is per 3 leds in te korten.
Adapter
Lichtnet snoer
RGB LED controller
Afstandsbediening
Rol leds is voorzien aan de achterzijde van 3M tape prijs: €29,99
Ik ga deze gebruiken als verlichting boven de modulebaan.
Mvg
Mark
Roco module-baan DCC analoog geschakeld
Tijdperk II/III
Duits thema met vee- en militair-transport.
http://forum.beneluxspoor.net/index.php/topic,52660.0.html
Brian.
« Reactie #16 Gepost op: 07 October 2013, 16:26:51 »
Kan nog goedkoper: Klikkie :).
Martin Welberg
  • FYA !!!
  • OO. Organisatie OntraXS!
« Reactie #17 Gepost op: 07 October 2013, 17:08:49 »
3528 SMD's, minder licht opbrengst...5050's zijn de way to go...
Brian.
« Reactie #18 Gepost op: 07 October 2013, 17:14:11 »
Vind die 3528'jes al ondraaglijk fel.. ::). Zal er trouwens wel op gaan letten mocht ik nog wat nodig hebben.
« Reactie #19 Gepost op: 07 October 2013, 19:20:34 »
Wat ik me afvraag bij voorgaande getoonde linkjes,is moet je aan dat spul nog zelf knutsellen,of is ook dat kant en klaar ?
(aangezien ik zelf compleet geen eletronica expert ben,kan een niet "compleet pakket" me aardig gaan frustreren  :-\ )
Nu effe uitgaande van het kruidvat spul,zit ik met een andere vraag.
Als ik 2 strips van 5 mtr koop in de heldere/witte versie voor verlichting van de in aanbouw zijnde schuur,is dat dan zat ?
(het hokje wordt 3 mtr en een beetje bij 4 mtr en een beetje  :o )
En als ik iets met die verlichting wil voor de toekomstige modelbouw is t dan zo dan ik 1 witte/heldere en 1 rgb strip nodig heb van 5 mtr ?
(ofwel 3 strips van 5 mtr in helder licht en 1 rgb strip voor alles)
Ik hoor t graag.
Alvast bedankt voor t antwoord  (y)
« Laatst bewerkt op: 07 October 2013, 20:51:00 door tijgernootje »
Menno
    • Mijn van-alles website
« Reactie #20 Gepost op: 07 October 2013, 20:20:16 »
Het Kruidvat-pakket is plug & play: aan de LEDstrip zit een connector die met de adapter te verbinden is en in het geval van de RGB-variant is de ledstrip zo te verbinden met de controller en de controller met een plugje met de adapter te verbinden.
Zelf vind ik LEDstrip best aardig, maar niet als vaste verlichting. Nog niet tenminste, de ontwikkelingen gaan wel hard.
Ik zou zelf dan 2 witte ledstrpis van 5 meter nemen, eventueel zelfs 1 koud-witte en 1 warm-witte (dit zeg ik even zonder de kruidvat-aanbieding gezien te hebben, ik weet niet of ze die varianten alle twee aanbieden)
Wel 1 ding jongens: als de strip continu op volle kracht aanstaat is het aan te bevelen de strip op een koelend oppervlak te plakken, anders kun je al aardig snel kleurverloop gaan krijgen bij de RGB-variant.
Martin Welberg
  • FYA !!!
« Reactie #21 Gepost op: 07 October 2013, 20:28:06 »
Geen koud wit, veeeeeeeeeeeeeeeeeeeeeeels te blauw...
RocoKolkie
« Reactie #22 Gepost op: 07 October 2013, 20:30:09 »
Floris,
Ik gebruik 2 LED strips voor de baan.
1 warm-wit die ik regel via een oude fleischmann trafo.
De andere van de Kruidvat is kant en klaar.
Zo nodig kan ik er nog losse spots bij zetten.
Tijdperk II/III
« Reactie #23 Gepost op: 07 October 2013, 20:48:17 »
Als ik het dus zo lees dan zou de de volgende verhouding perfect wezen:
2 warm wit strips van 5 mtr voor de verlichting van de in aanbouw zijnde schuur,en 1 warm wit+ 1 rgb strip van 5 mtr voor de baan die in coma ligt  :-\
Want die wordt als t plan af is bijna zo lang als de schuur  :o
(ofwel de locatie van de baan zal veranderen,zodat deze semi permanent kan blijven staan daar)
Klop dit dan ?
« Laatst bewerkt op: 07 October 2013, 20:52:49 door tijgernootje »
Wim Corduwener
  • Enschede (import)
« Reactie #24 Gepost op: 07 October 2013, 23:55:04 »
Op dezelfde pagina staan ook theelichtjes en die zijn makkelijk te demonteren en de ongesoldeerde onderdelen die daaruit komen zijn:
1x onregelmatig knipperende led die je in een kachel of open haard kunt inbouwen
1x minischakelaar die past in een bus of vrachtwagen van Faller Car system
1x batterijknoopcel om bijvoorbeeld led's te testen
Maar de Action verkoopt ze ook.
Trefwoorden:  Mac • Modulebouw • H0, H0e en 0e • Tijdperk III (1950-1960) • Nederlands (H0 en H0e) • Frans smalspoor (1:45) • Gelijkstroom • Twee rails • Voorlopig nog even analoog • Scratchbuilding en Kitbashing
ddv
« Reactie #25 Gepost op: 08 October 2013, 00:36:14 »
Zijn die dingen geschikt om in 50 partjes van 3 op te delen en dan te gebruiken als gebouwverlichting via trafo ??
Dieter
MarcNL
    • foto's op Imgur
« Reactie #26 Gepost op: 08 October 2013, 12:45:17 »
Ja,
ieder partje van 3 heeft een eigen weerstand, en kun je zo op 12VDC aansluiten.
St00mboy
« Reactie #27 Gepost op: 08 October 2013, 16:23:01 »
Ik heb ook een strip met 5m warmwitte leds bij het Kruidvat gehaald.
Dit staat er verder op de verpakking:
Kleurtemperatuur 2700 K
Max. 1200 Lumen
Stralingshoek 120 graden, IP65
> 50.000 uren, 12V strip.
Leen.
Menno
« Reactie #28 Gepost op: 08 October 2013, 17:31:45 »
Ik zei het ook alleen in combinatie MET warmwit. Even lezen verduidelijkt een hoop!
Het komt de kleurwaarneming vaak ten goede als warm en koud-wit met elkaar gemengd worden.
Martin Welberg
  • FYA !!!
« Reactie #29 Gepost op: 08 October 2013, 18:09:28 »
Nope, niet mee eens...valt niet te mengen. En heb al bijna 4 jaar deze meuk boven me baan...
