Vandaag om 16:56:20
Vandaag om 16:55:07
Vandaag om 16:51:46
Vandaag om 16:36:30
Vandaag om 16:32:28
Vandaag om 16:17:57
Vandaag om 15:21:38
Vandaag om 14:50:52
Vandaag om 14:13:48
Vandaag om 13:06:48
Vandaag om 12:55:13
Vandaag om 12:34:57
Vandaag om 12:31:33
Vandaag om 12:30:59
Wissel polijsten door Herb73
Vandaag om 12:09:16
Vandaag om 11:47:55
Vandaag om 11:30:43
Vandaag om 11:02:53
Vandaag om 11:01:02
Vandaag om 10:50:28
Ontraxs 2026 door Sven
Vandaag om 10:40:56
Vandaag om 09:56:08
Vandaag om 09:44:29
Vandaag om 09:39:32
Vandaag om 09:33:41
Vandaag om 07:15:30
21 April 2026, 23:19:15
21 April 2026, 23:14:57
21 April 2026, 22:24:30
21 April 2026, 21:43:29
Auteur Topic: Reinigingsthinner  (gelezen 4972 keer)
Ponytail
Reinigingsthinner
« Gepost op: 29 September 2013, 16:58:04 »
Via een ander modelbouwforum kreeg ik een tip:
Schoonmaak-thinner.
Niet geschikt als verdunner of zo, maar wel prima om verf te verwijderen en het tast plastic niet aan.
Heb het zelf nog niet getest en het is o.a. verkrijgbaar bij Hornbach...
Misschien iemand die wél al het gebruikt heeft?
Zie hieronder de enthousiaste tekst:
"Purely by chance I discovered the wonderful properties of a new Dutch
product : Cleaning Thinner.
Go to their website to read more about it.
I needed a powerful thinner (tolueen or xyleen and isobutanol based) to make
my own glue. However,this new thinner did not seem to mix at all with my old
thinner. I tried to use it as a normal paint thinner, but the results were
very poor at best. One liter costs about 8.50 euros, so throwing it away was
not an option. Maybe I could use it for something else...??!! I tried to
dissolve some plastic with it. After all, I needed it to make glue. To my
amazement it did not affect the plastic AT ALL !!! But it DID dissolve both
enamels and acrylics..... Bingo ! Let's find an old model and cover it with
this new product. Wow....the paint started to curl up from the plastic, in
under 15 minutes. I think I found the ideal paint remover. Both enamels and
acrylics can be removed. Especially acrylics dissolve before your eyes. This
thinner does evaporate too quickly, so one or two layers of toilet paper or
a tissue, then soaked, will keep the paint wet enough to be dissolved. After
wetting the paper, GENTLY push it into all corners to make sure all paint
stays wet. Tearing the paper will cause that part to get dry again. Paint
will not dissolve there.
Some info about this product :
- clear transparent liquid, thicker than water
- almost odourless
- non flammable
- does not affect plastic or rubber in any way
- in combination with paper tissues makes it the ideal paint remover for
scale models
- next to none harmfull effects on hands and nose (unlike chlorine, for
instance)
- water soluble, can be rinsed under the tap
- removes both acrylics and enamels
Note: for some reason this liquid has great difficulty removing metallics
such as silver and gold. It takes much longer and it leaves a shiny, spotted
layer.
The characteristics of this liquid also makes it the ideal airbrush cleaner.
My old, dirty Badger airbrush, not used for many years, came out almost like
new, after a 30 min. soak. That hard, next to impossible to remove paint
just fell off, or could be removed with a tooth pick. I could NOT believe my
eyes..... I have tried a large variety of products, but NONE of them could
clean my airbrushes as well and fast as this Cleaning Thinner. Even
expensive Airbrush Cleaner is rubbish compared to this stuff....really !
I spray my models with enamels and acrylics and therfor use a variety of
thinners and cleaning liquids. Turpentine, white spirit, 70 and 96% alcohol,
brush cleaners, etc... etc.... you name it, I've used it. But none of them
work as well as this liquid. I just had to let you know.
The big question for you guys is : where can we get this Cleaning
Thinner....??!!In the Netherlands you can find it in many stores, the brand
is De Parel (www.pearlpaint.nl)."
Rubedino
Re: Reinigingsthinner
« Reactie #1 Gepost op: 29 September 2013, 17:08:54 »
Al geprobeerd echter het werkte bij mij niet.
kawaaad
« Reactie #2 Gepost op: 29 September 2013, 20:14:45 »
Hallo Kees-jan, dit zal dan wel andere schoonmaak thinner zijn dan die ik gebruikte bij spuitklussen om mijn verfbekers schoon te maken. De schoonmaak thinner was goedkoper omdat het een soort vervuilder was dan die ik voor het verdunnen gebruikte. Deze nevelde mooier maar was knap duurder. Ik kan je wel vertellen dat mijn schoonmaak thinner alles sloopte wat geen metaal was. tip: pas altijd op met thinner !! test een klein plekje vooraf.
mvg aad
Rubedino
« Reactie #3 Gepost op: 29 September 2013, 20:16:41 »
Van de Hornbach was die van mij.
Normale thinner voldoet overigens prima om te verdunnen.
Thom
« Reactie #4 Gepost op: 30 September 2013, 20:45:47 »
Reinigingsthinner is verkrijgbaar bij elke Praxis.
Vanwege het veranderen van de oplosmiddelenwet en de daardoor aan banden gelegde toegestane hoeveelheid van oplosmiddel in verven is thinner eigenlijk niet meer nodig om (particulier) verven te verdunnen.
Thinner word daarom voornamelijk alleen nog maar gebruikt als ontvetter en daarom is de nieuwe samenstelling daar juist op aangepast.
Er zitten minder vluchtige stoffen in, waardoor het minder snel vervliegt en ook 'gezonder' is voor de verwerker.
Mede daardoor is het dus niet meer geschikt om verven te verdunnen, maar een stuk beter geschikt om oppervlaktes te reinigen en vetvrij te maken.
« Laatst bewerkt op: 30 September 2013, 20:48:59 door Thom »
Ponytail
Re: Reinigingsthinner en acrylverdunner
« Reactie #5 Gepost op: 23 October 2013, 11:27:14 »
Gisteren 'toevallig' langs de Hornbach gekomen en natuurlijk naar binnen en dat kost altijd geld.... ;D
Een fles van de PP-schoonmaakthinner meegenomen, maar ook Acrylverf-verdunner.
Voor een knaak de halve liter het proberen waard.
Eerste test: Tamiya matverf verdroogd tot chocoladepastadikte.
Wel dat ging prima. De prut lostte weer snel op tot smeerbare verf zonder korreltjes.
Een proefstukje gekwast en droogde op zo glad als een spiegel! Gewoon op ongereinigd polystireen.
Uitstekende hechting want met welke tape ook kwam het niet los.
"Volgens de folder" vertraagt het goedje de droging en daardoor is de acrylverf beter met de kwast/penseel te verwerken. Meer 'pot-life'.
Daarnaast zou bij het spuiten de verfspuit ook minder snel verstoppingen krijgen. Dat moet ik nog testen.
Zijn er soortgelijke ervaringen bij jullie?
« Laatst bewerkt op: 23 October 2013, 11:37:32 door Ponytail »
