om 00:15:46
03 February 2026, 23:52:50
T.Spat
03 February 2026, 23:23:21
03 February 2026, 22:54:50
03 February 2026, 22:53:27
Mooi, maar hou je neus dicht…
03 February 2026, 22:51:05
03 February 2026, 22:38:45
Bertholdowitsch
03 February 2026, 22:34:39
03 February 2026, 22:32:08
03 February 2026, 22:23:43
Stub switches
03 February 2026, 21:54:07
03 February 2026, 21:52:47
03 February 2026, 21:46:39
Arjen52
03 February 2026, 21:45:35
Edwin2121992
03 February 2026, 21:18:19
Zoek site ombouw lokomotieven
03 February 2026, 20:59:07
Waalspoor
03 February 2026, 20:23:28
Rijnstraat
03 February 2026, 20:10:34
Exact-train 2026
VAM65
03 February 2026, 20:09:59
Fotowedstrijd 2025
03 February 2026, 20:02:50
Joz
03 February 2026, 19:37:34
Slijptrein
03 February 2026, 19:28:42
Nieuw in de winkel!
ex-DR V100
03 February 2026, 19:28:36
Lucien
03 February 2026, 19:12:23
03 February 2026, 18:47:07
Hout realistisch nabootsen
03 February 2026, 18:33:38
Zermitz
03 February 2026, 18:30:38
03 February 2026, 18:09:15
The Rail Lab
03 February 2026, 18:04:47
03 February 2026, 17:49:20
Modelspoorverenigingen (MSV)
Modulebaan.nl
MB-module: "L'Esimé"
Topic: MB-module: "L'Esimé" (gelezen 300039 keer)
Chris80
Re: MB-module: "L'Esimé"
Reactie #1200 Gepost op:
31 October 2018, 20:42:40 »
Door de goede service van Bentink en Alsacast toch nog dit stationnetje op tijd binnen voor Eurospoor!
Daar naast in Frankrijk nog wat leuke dingetjes besteld, oa hekjes, bankjes en een typische franse wc met gat in de grond (voor op het stationsdeel ergens
Laatst bewerkt op: 31 October 2018, 21:09:41 door Chris80
Bouw Zeedoorn.
Modulebaan.nl L'Esimé
Wim1969
Reactie #1201 Gepost op:
31 October 2018, 21:19:29 »
Gaaf, lijkt erg op Artitec, maar die is ook gaaf
Kautenbach
Wolzerdange
Saint Tourbiere
Court du Bouton
la Ligne du Gerize
Au bord de la Céze
En hopen lol
Reactie #1202 Gepost op:
31 October 2018, 21:20:02 »
Op tijd binnen.... je gaat het ook nog bouwen, schilderen en verweren vóór Eurospoor?
Pauze
Reactie #1203 Gepost op:
31 October 2018, 21:23:30 »
Het is geen Grasland, he?
(Sorry, te makkelijk...
Chris80
Reactie #1204 Gepost op:
31 October 2018, 21:29:50 »
Ja gaaf he!
@Marc, uiteraard is die klaar voor Eurospoor, verweerd en al. Er is veel moeite gedaan om hem op tijd bij mij te krijgen, dus hij gaat zeker af komen
. Het verhaal vertel ik je wel ff op Eurospoor.
En ik zit nu elk vrij moment te werken aan de baan om hem toonbaar te hebben voor Eurospoor.
Bouw Zeedoorn.
Tjalling
Reactie #1205 Gepost op:
31 October 2018, 22:17:12 »
Goed bezig. Ook hier druk bezig voor Eurospoor. Dit motiveert wel om nóg wat extra gas te geven.
Ben erg benieuwd hie he bak er op Eurospoor bij staat
Tjalling
modulebaan.nl
Edsko Hekman
Nooit uitgeklust....
Reactie #1206 Gepost op:
31 October 2018, 22:31:07 »
Ziet er goed uit Chris!
Grasland
Jeroen Water
NS tijdperk IV (1973/1974)
Reactie #1207 Gepost op:
01 November 2018, 07:07:49 »
Dat wordt een fraaie baan, Chris!
Ter overweging:
Je kunt de muur gebruiken om verlichtingsarmaturen en bijv twee stationnaamborden op te hangen, dat breekt het geheel weer.
Hoe komen de reizigers straks vanaf het stationsgebouw op het perron dat voor de muur ligt? Ik zou opteren voor een kuil in de perrons recht tegenover het stationsgebouw en daar een overpad maken. Beveiliging van die oversteekplaatsen geschied door gele schrikstrepen op de kuilen van de perrons en een stoplicht op elk perron dat brandt als er een trein aan komt en anders gedoofd is. Het betreft (uiteraard) een rood verlicht mannetje met de tekst stop, maaar dat zal te klein worden in H0.
Veel succes en bouwplezier verder!
Chris80
Reactie #1208 Gepost op:
01 November 2018, 11:28:34 »
Thanks allen!
Er had eigenlijk inderdaad een kuil oid moeten komen om van perron naar perron te komen. Helaas lukte dit niet goed en omwille van de tijd heb ik het voor nu maar even zo gedaan. Dus voor nu moeten de reizigers maar springen of klinmen. Dit is wel iets wat ik in versie 2.0 aan wil pakken, want het is niet realistisch. Maar voor nu dus een tojdstechnische keuze.
Bouw Zeedoorn.
Reactie #1209 Gepost op:
01 November 2018, 18:03:38 »
Klimmende of springende reizigers ?
Beide dingen horen machinisten in real life liever niet
*hoe zou dat er uit zien een klimmende ouwe taart op hakken die probeert van perron 1 naar 2 te komen in dr nette pak met bij passende handtas
Chris80
Reactie #1210 Gepost op:
01 November 2018, 18:16:13 »
Misschien zet ik voor die bejaarden wel een trampoline neer om de overkant te bereiken
Bouw Zeedoorn.
Chris80
Reactie #1211 Gepost op:
02 November 2018, 15:21:01 »
Ok, nu weet ik weer wat ik vervelend vind aan resin bouwpakketjes, het verwijderen van alle vliesjes.. en zoals je ziet bij de ramen en deuren waren dat er een hele boel. Maarrrr er kan met wat vertraging toch nog gebouwd gaan worden 😀.
Bouw Zeedoorn.
Chris80
Reactie #1212 Gepost op:
05 November 2018, 16:34:24 »
En de postbode kwam nog even langs vandaag met een doosje vol spulletjes.. hopelijk krijg ik voor Eurospoor in elk geval de hekjes nog geplaatst..
Bouw Zeedoorn.
Chris80
Reactie #1213 Gepost op:
06 November 2018, 23:38:13 »
Inmiddels zit het stationnetje in elkaar. Koste toch weer (veel) meer werk dan ik gehoopt had. Hij moet nog wel wat verder vervuild worden, maar dat komt wel na Eurospoor.
Bij deze een sneak preview. Om te weten hoe die op de baan staat moet je op Eurospoor maar even komen kijken
Bouw Zeedoorn.
Rondje_HO
Reactie #1214 Gepost op:
06 November 2018, 23:40:20 »
Maar wel mooi geworden!
Met vr. groet, Martijn.
Mijn banen:
Nieuw; nu met foto's:
Modulebaan.nl
