Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Hoog adres Tran DCX70-2D decoder  (gelezen 2195 keer)
Coen Burki
« Gepost op: 18 April 2013, 23:48:14 »
Beste forumlezer,
Ik probeer bovenstaande Tran decoder op adres 602 te zetten maar dit lukt niet. :(
Deze decoder is via 8-polige stekker ingebouwd in een Roco NS600, waarbij tevens een Krois koppeling is aangesloten. De koppeling werkt prima ook het kort voor- en achteruit rijden gaat prima. Geheel via voorgeschreven CV aanpassingen gewijzigd.
Als ik CV 29 met 32 verhoog zou een adres hoger dan 127 bij CV 1 moeten kunnen worden ingevoerd.
CV 17 staat op 18 en CV 18 staat op 00.
Dit is mijn eerste Tran decoder. Ik gebruik normaal Lopi's 3.0 en 4.0, waarmee ik dit probleem niet heb.
Voorts kan ik met mijn Esu lokprogrammer de Tran decoder niet uitlezen maar op de codeeruitgang van mijn Lenzcentrale LZ100 lukt dit wel??
Wie weet raad?
Coen.
RE465
Re:Hoog adres Tran DCX70-2D decoder
« Reactie #1 Gepost op: 19 April 2013, 00:26:12 »
Wanneer de TRAN decoder aan  de NMRA norm voldoet dan moet cv17 op 194 en CV18 op 90 voor adres 602.
CV29 met 32 verhogen of bit 5(6) inschakelen.
RE465
RE 465
Eisenbahn-Amateuren Weinfelden-Berg
Beurse Berg (Thurgau) 13 november 2021
Dag der open deur 9/10 Oktober 2021
2015: *
Marc Riswick
    • Stuyteweg
« Reactie #2 Gepost op: 19 April 2013, 05:15:46 »
Als CV29 verhoogd is wordt CV1 dus niet meer gebruikt, maar in plaats daarvan de combinatie van CV17 en 18. Daar moeten dus de waardes in worden gezet zoals RE465 al schreef. In CV1 hoef je dus niks in te vullen.
groet Marc
PS De Esu Lokprogrammer is bedoeld voor Esu decoders.
Coen Burki
« Reactie #3 Gepost op: 19 April 2013, 09:19:19 »
Beste RE465,
Inderdaad met jouw instellingen werkt het adres 602. Ik neem aan dat van deze instellingen tabellen zijn. Waar vind ik die eventueel ?
Bij ESU is het adres onder CV 1 te zien, bij Tran dus niet.
Heb jij nog een tip voor de instellingen voor een standaard Roco motor.
Bij de nieuwe Lopi's ( 4.0 ) is het eenvoudig: CV50 op 0, lok op de rail F1, lok rijdt een stukje en de motorinstellingen zijn aangepast.
Bedankt voor je advies en groet,
Coen.
VAM65
  • Nederland 1949-1963 in h0
« Reactie #4 Gepost op: 19 April 2013, 09:22:28 »
Met behulp van deze link, kun je CV17 en CV18 zelf uitrekenen:
http://www.ruppweb.org/xray/comp/decoder.htm
RE465
« Reactie #5 Gepost op: 19 April 2013, 10:01:53 »
Ik Heb gezien dat U LENZ LZ100 hebt.
Daar mee kan U ook gewoon het lange adres ingeven dan berekend het gereed het zelf.
RE465
PS. Ik heb LENZ LZ100 met Software 3.6
« Laatst bewerkt op: 19 April 2013, 10:03:37 door RE465 »
RE 465
2015: *
Coen Burki
« Reactie #6 Gepost op: 19 April 2013, 11:05:55 »
Beste RE465,
Mijn Lenzcentrale heeft software 3.6 .
Ik heb bij CV1 het adres 602 ingegeven en dit is waarschijnlijk fout. Waar moet ik het adres ingeven zodat de decoder automatisch de juiste instelling in CV 17 en 18 instelt?
Met de Esu programmer kon ik wel de CV's wijzigen maar niet uitlezen. Ik kreeg wel de melding dat de Tran decoder niet herkent werd??
Coen.
RE465
« Reactie #7 Gepost op: 19 April 2013, 12:09:25 »
http://www.digital-plus.de/pdf/b_21100_d.pdf
In de Duitse handleiding van de LH100 op bladzijde 57 en 58 staat wie U het moet doen .
Ik heb even moeten zoeken om dat ik het normaal met de computer en de USB-Interface doe
RE465
PS Gaat alleen  op  het programmeer rils.
RE 465
2015: *
Coen Burki
« Reactie #8 Gepost op: 19 April 2013, 13:59:52 »
OK,
In ieder geval bedankt voor je adviezen en hulp.
Weer wat geleerd!
Coen.
Coen Burki
« Reactie #9 Gepost op: 21 April 2013, 13:09:42 »
Beste forumlezer,
Koppeling werkt na wat verbuigen van de metalen haak nu prima.
Het aankoppelen werkt volledig maar het loskoppelen lukt niet. De lok rijdt wel automatisch voor en achteruit maar de haak doet niets.
Nu staat in de beschrijving dat na de koppelaktie de koppeling moet worden uitgeschakeld om de nieuwe opdracht voor ontkoppelen volledig uit te voeren.  De koppeling wordt na de koppelaktie toch automatisch uitgeschakeld!
Heeft iemand een idee wat hiermee wordt bedoeld?
Coen.
Karst Drenth
    • Plan U op Sleutelspoor
« Reactie #10 Gepost op: 21 April 2013, 13:57:01 »
Als het net zo werkt als bij ESU, wordt de uitgang ( een tijdje ) actief bij het IN schakelen van de functie. Je moet dus de functie eerst UIT schakelen en dan weer IN, zodat je opnieuw een puls krijgt op de uitgang.
Overigens wil de koppeling NIET ontkoppelen als er nog (trek)spanning op staat. Je zult dus net als in het echt, eerst de lok eens stukje terug moeten laten duwen. En dan tegelijk de koppeling bedienen en de loc weg laten rijden.
Grtzz & suc6,
Karst
Coen Burki
« Reactie #11 Gepost op: 21 April 2013, 19:06:22 »
Beste Karst,
Bij de de Tran decoder kun je middels CV's de ingebouwde functie instellen voor eerst ontspannen ( stukje vooruit ) en daarna ontkoppelen ( metalen haak koppeling omhoog ) en stukje wegrijden.
Aankoppelen gaat dus prima.
Bij ontkoppelen wordt 2e aktie ( metalen haak omhoog ), ondanks dat de trekspanning is weggenomen door een paar mm vooruit te rijden, niet uitgevoerd.
Volgens de instructie moet tussen aan- en afkoppelen de koppeling worden uitgeschakeld.
Hoe schakel je je de koppeling uit of wat wordt hiermee bedoeld ?
Coen.
Karst Drenth
« Reactie #12 Gepost op: 21 April 2013, 19:15:33 »
Anders dan ik hierboven beschreven heb geen idee hoe de Tran dat doet Coen  :-\
Ik laat Koploper dat vooruit, achteruit, haak omhoog, uitschakelen functie etc. allemaal verzorgen. Werkt uit de grote kunst... (y)
Grtzz,
Karst
Coen Burki
« Reactie #13 Gepost op: 21 April 2013, 19:18:44 »
Dat heb ik in Utrecht gezien, vandaar dat ik de de in mijn bezit zijnde Krois decoders heb omgeruild met de KK-uitvoering.
Coen.
Karst Drenth
« Reactie #14 Gepost op: 21 April 2013, 19:21:40 »
Heb je een link van de handleiding naar de door jou gebruikte decoder ? Misschien dat ik er iets uit wijs kan worden ;)
