Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Sein decoder  (gelezen 4307 keer)
Private SNAFU
  • Member of the 1(to)87 gang
    • project "Nijkerk:87"
Sein decoder
« Gepost op: 02 July 2006, 21:02:52 »
Hallo allemaal,
Welke seindecoder gebruiken jullie voor het aansturen van de NS seinen.
Welke decoder kan de meeste (correcte) seinbeelden weergeven?
Ik ben benieuwd omdat ik binnenkort mijn seindecoders ga aanschaffen.
Persoonlijk zit ik te twijfelen tussen de Serial32 en de LDT LS-DEC-NS
Gr,
Bart
Website
NS - IVa (1968 - 1978) / Koploper / LocoNet / IB+ProfiBoss / Modulebouw
    • Het Groterdam Project
Re: Sein decoder
« Reactie #1 Gepost op: 02 July 2006, 21:05:44 »
LDT LS-DEC-NS, werkt prima bij mij, icm Koploper.
Ben er tevreden over.
Private SNAFU
Re: Sein decoder
« Reactie #2 Gepost op: 02 July 2006, 21:06:37 »
Welke seinbeelden kan de LDT eigenlijk precies weergeven Chris?
Gr,
Bart
Website
Re: Sein decoder
« Reactie #3 Gepost op: 02 July 2006, 21:35:31 »
Nou, ik weet het niet zeker, maar alles behalve knipperstand vrees ik.
Maar ik heb bij Koploper gekozen voor een eenvoudig seinstelsel.
Wel gewoon seinen met cijferbak enz enz.
Aangezien jij nogal veel seinen gaat gebruiken denk ik niet dat het de decoder voor jou is.
Hub
Re: Sein decoder
« Reactie #4 Gepost op: 02 July 2006, 22:44:56 »
Zelf gebruik ik het Duist seinstelsel met de Serial32.
Heb wel eens gekeken met het Nederlands seinstelsel.
Moet zeggen werkte toch mooi.
Hub
Private SNAFU
Re: Sein decoder
« Reactie #5 Gepost op: 03 July 2006, 18:29:21 »
Denk dat ik dan toch voor de serial32 ga. Is deze eigenlijk ook aan te sturen via zo'n USB->RS232 convertor?
Gr,
Bart
Website
Hub
Re: Sein decoder
« Reactie #6 Gepost op: 03 July 2006, 21:29:21 »
Ik dacht van wel. Om het zeker te weten kun je een mailtje sturen naar Leon van Perlo, hij zal daar zeker op reageren.
Hub
pahasoft
Re: Sein decoder
« Reactie #7 Gepost op: 03 July 2006, 22:09:49 »
Hallo Hub,
Volgens mij werkt. Het is een richtingsverkeer en daar kan een usb/serial converter het toch niet echt moeilijk mee hebben.
Met vriendelijke treinengroeten,
Paul Haagsma.
Hub
Re: Sein decoder
« Reactie #8 Gepost op: 03 July 2006, 22:42:47 »
Hallo Paul,
Het is inderdaad een richtingsverkeer, echter de serials stuur ik via de Compoort, niet via een usb/serial converter, vandaar mijn antwoord met enige voorzichtigheid richting Bart. Toch bedankt.
Hub
Private SNAFU
Re: Sein decoder
« Reactie #9 Gepost op: 03 July 2006, 22:47:29 »
Dan zal ik voor de zekerheid Leon nog een email sturen, maar dan weet ik wel bijna zeker dat het de Serial32 wordt voor mijn seinen..
Gr,
Bart
Website
Leon van Perlo
    • Modelbaanbesturing (met of) zonder decoders
Re: Sein decoder
« Reactie #10 Gepost op: 03 July 2006, 23:01:12 »
De OM32 serial heeft geen hardware-handshake nodig en de timing tussen de asynchrone bytes is onbelangrijk. Het enige dat de USB-serial converter dus moet kunnen is asynchrone seriele bytes versturen en als-ie zelfs dat niet kan is het geen USB-serial converter.
Met inachtneming van de algemeen gangbare opvatting dat USB support pas redelijk goed geregeld is vanaf Windows2000 of XP zou een USB converter gewoon moeten werken (bij mij en vele anderen in elk geval wel).
Overigens ondersteunt de OM32 Serial alle seinstanden van alle seinstelsels die Koploper kent.
Leon
