Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: BNLS-Werkspoor - omBC 2900 van PolderModelSpoor  (gelezen 113479 keer)
Re: BNLS-Werkspoor - omBC 2900 van PolderModelSpoor
« Reactie #375 Gepost op: 31 October 2013, 07:55:14 »
Flauw hoor, klim jij nou maar op een lege zeecontainer.  ;)
Het kon best eens meevallen. Op verschillende foto's lijkt de dakopbouw ook behoorlijk fors. Ik zou de ontwerper (Frie) mailen en vragen op welke bronnen hij zich heeft gebaseerd. Originele bouwtekeningen of modeltekeningen. Ik vermoed dat het allemaal behoorlijk klopt.
Mvg, Paul
Andries
« Reactie #376 Gepost op: 06 November 2013, 21:56:34 »
Voor degenen die de aandrijving van de omBC ook een lastig verhaal vinden (hij zit wel in elkaar, maar draait heel moeizaam - net of de tandwielen te dicht op elkaar zitten), kun je overwegen een Roco BR 215 draaistel te gebruiken. De opening in de bodemplaat moet dan wel iets vergroot worden. Hij zal misschien iets zichtbaar zijn, maar je hebt wel een uitstekend aangedreven treinstel. Zie de foto - hier moet het een en ander nog wel aangepast worden.
Andries
tomas-A
  • Nieuwe gebruiker
« Reactie #377 Gepost op: 04 October 2015, 20:17:38 »
Gisteren bij Frie wat spulletjes opgehaald en heb toen ook de nieuwste in aanbouw zijnde omBC bekeken.
Aan dat model van de vervolgserie heeft hij een aantal zaken verbeterd, zoals een compleet nieuw (kunststof) motordraaistel, standaard digitaal voorbereid, correcte hoogte van de klasseborden, zelf gemaakte derde klasse bankjes met geëtste armleuningen (uit nieuwzilver), de Scharfenbergkoppeling is nu verfraaid met slangetjes en is nu draaibaar, waardoor koppeling met een soortgenoot mogelijk wordt.
Ook het stukje kunststof aan de voorkant van de cabine onder de cabineruiten (ter plekke van het trekoog) is vervangen door een messing exemplaar.
Verder zijn – heel subtiel – de sluitseinringen nu voorzien van een zestal schroefpuntjes, conform het origineel.
Heb het model zien rijden en het reed erg stil en rustig. De front- sluit- en binnenverlichting brandde mooi en niet te fel.
Met zijn toestemming mocht ik een paar foto’s maken en publiceren, zie hieronder.
Heb verder begrepen dat er ook weer kits van de omBC uitgeleverd gaan worden.
Hierbij is het model al vrijwel geheel gesoldeerd en zijn diverse onderdelen reeds compleet geassembleerd.
Voor meer vragen kun je bij hem terecht.
T
tomas-A
  • Nieuwe gebruiker
« Reactie #378 Gepost op: 30 November 2015, 22:15:48 »
Zojuist van FRIE een paar foto’s ontvangen over een interessante verbetering aan het model van de omBC.
De cabine is nu volledig opgebouwd uit messing; het dubbel-gekromde cabine-dak is nu vervaardigd uit messing plaat dat in de juiste vorm is geperst; de wand van de cabine is (bestaand) messing etswerk; het frontstukje onder de cabineramen is messing gietwerk.
Een en ander heeft diverse voordelen, zoals het aan elkaar kunnen solderen van alle onderdelen.
Bijgaand enkele plaatjes.
Constructie is nog niet helemaal af; de opening boven het middelste cabineraam moet nog 'opgevuld' worden met een stripje messing.
Geïnteresseerden kunnen contact met hem opnemen.
T
tomas-A
  • Nieuwe gebruiker
« Reactie #379 Gepost op: 11 December 2015, 23:44:23 »
Zojuist van Frie weer enkele plaatjes ontvangen over de messing neus.
't wordt steeds fraaier!  ;)
Nou nog 4 extra bakken erbij en een messing dieselvijf is bijna een feit.  ;)
T
« Reactie #380 Gepost op: 12 December 2015, 12:55:59 »
Dat ziet er fraai uit! Op deze manier heb je én de goede kromming in de neus én de ramen zijn scherp en exact uitgeëtst. Goed werk van FRIE!  (y)
tomas-A
  • Nieuwe gebruiker
« Reactie #381 Gepost op: 29 December 2015, 11:12:09 »
Zojuist van Frie weer een foto toegestuurd gekregen over de kit voor de omBC.
Deze is nu ook compleet vernieuwd.
Zo is onder andere het onderstel nu kant en klaar (en reeds in kleur gespoten); zo ook de draaistellen.
Het gehele elektrische deel is nu gesoldeerd en wel.
T
mpol
« Reactie #382 Gepost op: 29 December 2015, 18:23:55 »
Ziet er idd zeer goed uit
Grt,
Marcel
Sent from my GT-I9295 using Tapatalk
Rob Moerkerken
« Reactie #383 Gepost op: 30 December 2015, 11:54:28 »
Een hele mooie bouwset, wat moet ie kosten?
Rob Moerkerken
« Reactie #384 Gepost op: 30 December 2015, 12:05:13 »
Wordt alleen kant en klaar geleverd, begreep ik.
  • Modelspoor is emotie...
« Reactie #385 Gepost op: 30 December 2015, 14:52:57 »
Ik lees anders iets naar boven in een berichtje van Tomas dat ie ook als kit geleverd gaat worden, voorgesoldeerd en wel. Ben dan ook erg benieuwd naar de prijs... Misschien dat Erwin kans ziet om ff te reageren tussen oliebollen, vuurwerk en champagne door?  ;)
Grtn,
Rob
Tbinnebarretije…
FRIE
« Reactie #386 Gepost op: 30 December 2015, 21:07:34 »
Inderdaad, zojuist een heerlijke oliebol verorberd. ;)
De prijs van de omBC-kit in de afgebeelde toestand bedraagt € 425,-
Met name het aanbrengen van de geheel messing neuzen maakt het model vrij prijzig.
De prijs van een wat versimpelde versie bedraagt € 370,-
Hierbij dient de bouwer het volgende zelf te doen:
- elektronica zelf in elkaar solderen
- bovenkant cabine zelf vast solderen
- stukje aan voorkant van cabine zelf vast solderen
Evt. minderprijs indien het model niet digitaal voorbereid hoeft te zijn: € 7,50
Evt. belangstelling voor een kant en klare 'kneus-omBC'? Laat maar weten.
Erwin
« Reactie #387 Gepost op: 30 December 2015, 22:32:40 »
Hi Erwin,
Wat versta je onder een 'kneus-omBC'? ;)
Grtn,
Rob
Tbinnebarretije…
  • Forummoderator
« Reactie #388 Gepost op: 30 December 2015, 22:39:47 »
Eentje zonder functioneel toilet.
Reinout
« Reactie #389 Gepost op: 31 December 2015, 10:51:57 »
 ;D
Grtn,
Rob
Tbinnebarretije…
