Vandaag om 00:48:20
Vandaag om 00:42:51
Vandaag om 00:15:48
13 February 2026, 23:59:24
PB Models, ICR-rijtuigen door MarkSpoor
13 February 2026, 23:57:00
13 February 2026, 23:55:09
13 February 2026, 23:30:44
13 February 2026, 23:08:59
Spoorwegmuseum in zwaar weer door Ferdinand Bogman
13 February 2026, 23:07:10
13 February 2026, 23:03:50
13 February 2026, 22:58:20
13 February 2026, 22:49:17
Roco 63421, hoe kom ik bij de stroomafname lipjes? door Albert de Heer
13 February 2026, 22:38:18
PT Trains 2026 door Chris Westerduin
13 February 2026, 22:10:50
Stub switches door Frank 123
13 February 2026, 21:50:55
13 February 2026, 21:49:12
13 February 2026, 21:41:19
13 February 2026, 21:24:24
13 February 2026, 21:13:45
13 February 2026, 20:31:01
Euronight 295 samenstelling door EN446
13 February 2026, 20:29:30
13 February 2026, 20:05:35
RailBOX Accessoire Decoder RB4400 door Etsmodelspoor.nl / Modelspoorbaanwinkel.nl
13 February 2026, 19:47:25
13 February 2026, 19:33:16
US diorama in H0 door Eric B
13 February 2026, 19:23:39
13 February 2026, 19:19:59
13 February 2026, 18:55:31
13 February 2026, 18:32:55
13 February 2026, 18:19:53
13 February 2026, 17:47:25
Auteur Topic: Nederlandse stads- en streekbussen in model  (gelezen 172603 keer)
  • NS 1607 Vlissingen
  • Zal 't gaan, ja!
    • Tramlijn Maastricht-Vaals
Re: Nederlandse stads- en streekbussen in model
« Reactie #300 Gepost op: 07 January 2018, 13:19:10 »
Hoewel het geen Nederlandse bus is kwam deze wel aan deze kant van de grens.
De Lijn Snelbus (Hasselt-Maastricht)
Mercedes-Benz O303
Jos
En was 1680 cm Lang
(Rotterdam, 2009)
ddv
« Reactie #301 Gepost op: 07 January 2018, 22:06:31 »
Hoi;
Nen Belsch van de Lijn  :), zelf geschilderd neem ik aan, ik ga er van uit dat die bus zo niet in de handel is?
Groet ...
  • Zal 't gaan, ja!
« Reactie #302 Gepost op: 07 January 2018, 22:23:53 »
Dieter, deze is in zeer beperkte oplage door Rietze uitgebracht.
Alleen dit model is op basis van een Wiking model.
Jos.
En was 1680 cm Lang
(Rotterdam, 2009)
ddv
« Reactie #303 Gepost op: 07 January 2018, 23:10:44 »
Maar je hebt zelf de kwast laten spelen en een wagen van "De Lijn" van het Wiking model gemaakt.
« Reactie #304 Gepost op: 23 November 2018, 16:21:53 »
Voor een kennis ben ik op zoek naar een model van een Daf-bus met een carrosserie van Groenewold zoals hij reed voor de ESA met busnummer 133 in 1964.
Iemand ideeën?
Foto van Wikipedia.
Albert
https://denapp.blogspot.com/
  • Zal 't gaan, ja!
« Reactie #305 Gepost op: 23 November 2018, 16:44:02 »
Albert, ik ben bang dat je op zelfbouw uitkomt.
Van dit type bus is geen enkel schaalmodel.
Jos
« Laatst bewerkt op: 22 May 2019, 14:23:11 door 44 »
En was 1680 cm Lang
(Rotterdam, 2009)
« Reactie #306 Gepost op: 23 November 2018, 18:33:39 »
@Jos,
Bedankt voor het meedenken, ik vrees dat zelfbouw een brug te ver is voor mijn club-collega. En stel dat ik het zelf zou proberen, welk model zou ik als donor kunnen nemen?
Albert
  • Het leven op de weg.
    • Midland
« Reactie #307 Gepost op: 23 November 2018, 22:18:40 »
Je zou 3D-print kunnen overwegen.
Bv Shapeways, er zijn hier een aantal mensen die ook een schaal/werktekening kunnen maken zodat ie uiteindelijk geprint kan worden.
Van belang is dan een schaal tekening.
Gr Koen.
MDG
  • Voor elk probleem bestaat een oplossing
« Reactie #308 Gepost op: 23 November 2018, 22:31:15 »
ddv, waar doel je nou precies op?
Er staat vaak een man in Houten met bussen, heb zo snel geen naam of standbummer.
Maar hij kan wellicht wat betekenen zowel in zoektocht als productie?
Groetjes Max
Max de Groot
Mijn draadje; Vrije vertaling Nedstaal H0
https://forum.beneluxspoor.net/index.php?topic=91123.0
Deetrein
« Reactie #309 Gepost op: 24 November 2018, 00:20:23 »
De man op Houten met handgemaakte HB modellen heet Paul Roerbag.
mvg, Erich
« Reactie #310 Gepost op: 24 November 2018, 15:28:35 »
Bedankt mannen. De zoektocht gaat verder.
Albert
ReneN
« Reactie #311 Gepost op: 24 November 2018, 15:52:08 »
Ik heb Paul Roerbag al meerdere malen naar het maken van tourbussen gevraagd. Dit gaat hij echter niet meer doen, de beste man is al rond de 80. Helaas komt de ESA-bus met geen enkel ander model overeen, niet qua voor- en achterzijde en ook niet qua raamindeling. Hoogstens zou bijvoorbeeld de bodemplaat van een Mastica DAF als basis kunnen dienen waarop dan een styreen carrosserie wordt geplaatst. Fokko Feenstra heeft daarmee veel ervaring: http://members.home.nl/fsfeenstra/
« Laatst bewerkt op: 24 November 2018, 15:54:23 door ReneN »
Eric-Jan Hartstra
« Reactie #312 Gepost op: 25 November 2018, 22:03:46 »
Het is wat Rene zegt, bijzonder mooie bus maar het model is zo uniek, dat er geen markt voor te vinden is. 300 modellen is tegenwoordig het minimum bij een variant op een serie model. En dit is geen seriemodel maar een unicum. Heel mooi maar inderdaad alleen bereikbaar door zelfbouw.
ReneN
« Reactie #313 Gepost op: 25 November 2018, 23:34:58 »
Bij Paul werkt het omgekeerd, al zijn resin bussen worden juist in kleinserie gemaakt. Dit gebeurt in Oekraïne, maar het assortiment is qua varianten inmiddels zo groot dat de Oekraïners vaak te weinig leveren. Ruimte voor nieuwe modellen is er daarom nauwelijks.
  • Duitsland TP III/IV
« Reactie #314 Gepost op: 26 November 2018, 10:05:39 »
Mercedes-Benz O303
Jos
Groetjes Max
Jos.
Als Rietze daadwerkelijk met bovenstaand model zo op de markt is gekomen dan zou ik onmiddellijk deze hebben geretourneerd. Wat Dieter probeert duidelijk te maken is dat Jos uit een bestaand model een bus heeft gemaakt zoals deze daar heeft gereden.
Het antwoord is ja, Jos heeft deze omgeschilderd en dat is helaas te zien maar dat is voor Jos geen probleem want hij heeft dit vaker gedaan.
Grt, Ronald.
