welke zimo decoder in roco SIK 72012
vader057
om 08:20:09
Ronaldk
om 08:15:22
om 08:12:02
Spoor010
om 07:20:33
Schaal TT
om 07:01:31
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:43:31
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Materieelbespreking
decoder lenz le 130
Topic: decoder lenz le 130 (gelezen 1965 keer)
Klaas1907
decoder lenz le 130
09 August 2012, 20:13:09 »
ik meet op de gele draad van de lenz decoder geen spanning
de gele draad was van de sluitverlichting
vervolgens de groene draad op de sluitverlichting aangeloten
verlichting brandt en is aan en uitschakelbaar via f1
is de gele draad opnieuw via de decoder van spanning te voorzien of is de groene draad via de decoder te veranderen zodat deze de gele draad vervangt en de verlichting rijrichting werkt
AdrieE
Re:decoder lenz le 130
09 August 2012, 21:26:35 »
Klaas,
Als ik me niet vergis is dit de -draad en wordt de spanning geleverd door blauw.
Groet Adrie
nero
09 August 2012, 22:43:56 »
geel en wit is de - van de lampen voor en achter
blauw is de spanning
daarom alleeen aansluiten bij compleet geisoleerde lampen(of leds)
uit mn hoofd
geel voor en wit achter
dit is eventueel met een cv om te keren
09 August 2012, 23:24:27 »
Je zou, indien geel niet meer werkt (decoder gedeeltelijk defect??) de groene kunnen gebruiken en deze via functiemapping een "geel" functie kunnen geven. Bij ESU kandat en ik neem aan ook bij andere merken decoders. Zie handleiding. Het kan wel zijn dat je er een programmer voor nodig hebt. Is garantie op je decoder geen optie?
FreekH
09 August 2012, 23:57:38 »
Klaas, je kunt het beste de groene draad aangesloten laten op de sluitverlichting, en die verlichting dan zelf met F1 aan/uit schakelen. Een echte machinist moet denk ik ook zelf z'n sluitseinen aan en uit zetten
Maar kijk eerst eens of de gele draad wel goed aan de dekoder/stekker is gesoldeerd en of er geen breuk in zit.
De Lenz LE130 is tegen de 15 jaar oud, toen was de door Ruud genoemde funktiemapping nog lang niet uitgevonden. Het was een van de eerste dekoders met lastregeling, en dat doet-ie eigenlijk nog steeds prima in mijn Roco-loks uit diezelfde tijd.
Freek.
Materieelbespreking
decoder lenz le 130
