€88.00
€-162.00
Verwisselen koppelingen Hamo 1205
hmmglaser
om 00:33:52
Modeltreinenbeurzen
om 00:10:03
Project seaside Germany
20 October 2025, 23:26:48
Het bouwen van een Philotrain 2400 kit
Huup
20 October 2025, 23:22:53
Robert vh Prutsert
20 October 2025, 23:13:34
Märklin 2025
Edwin2121992
20 October 2025, 23:11:41
Schroefkoppeling voor H0.
Edwin2121992
20 October 2025, 23:09:16
Modelspoor Vereniging Nijkerk MVN Nijkerk
Train Charter Services
20 October 2025, 23:03:33
MODELSPOOR by MTD - 2025 - 18 & 19 oktober 2025 in Edegem (B)
20 October 2025, 22:52:31
20 October 2025, 22:24:31
T.Spat
20 October 2025, 22:19:35
West-Brabantse modelspoordagen
HenkN
20 October 2025, 21:25:38
Werking Piko goldcap i.c.m. met niet-Piko decoder
De eerste Ivo
20 October 2025, 21:21:20
20 October 2025, 21:16:39
NL cameo layout (0,26m2)
Joran
20 October 2025, 20:38:07
Cherteau, fictieve Waals industriedorp
20 October 2025, 20:36:29
20 October 2025, 20:23:16
Diorama Oelde Mittelweg Hp
20 October 2025, 20:23:03
20 October 2025, 19:43:39
20 October 2025, 19:22:16
20 October 2025, 19:17:34
20 October 2025, 19:07:07
Zaterdag, 1 november 2025 | 7e Ruilbeurs MSV Post B
20 October 2025, 18:46:48
Pendel module Viessmann 5214
Te 2/2
20 October 2025, 17:57:31
Huup
20 October 2025, 17:55:12
Het einde van de RhB- Chiavenna Stazione Merci
AP3737
20 October 2025, 17:51:57
gtw6016
20 October 2025, 17:25:44
Bruggen-IG - brug over de Poldervaart Schiedam/Kethel
Forever Rocofan
20 October 2025, 17:22:45
20 October 2025, 16:41:37
MSC HetSpoor-ClubTentoonstelling~Niklaas-Niklaas~6+7dec.'25
20 October 2025, 15:55:00
Digitaal
Frontlicht dimmen?
Topic: Frontlicht dimmen? (gelezen 2939 keer)
Weerd
Re:Frontlicht dimmen?
Reactie #15 Gepost op:
31 August 2011, 23:10:12 »
Als ik de handleiding lees, dan kan de verlichting in twee standen branden, namelijk normaal of in dimlichtmode.
Vooruit CV49 = bit 4 en bit 0 oftewel 16+1 = waarde 17.
Achteruitverlichting bit 3 en bit 0 oftewel als waarde ingeven 8 + 1 = 9.
Maar dat heb je al gedaan en krijg een pulserend licht.
Tja, dan is er maar een remedie, hang er een weerstandje tussen met een waarde van 1000 Ohm of 2200 Ohm of misschien wel 3300 Ohm. Het vermogen van het kleine weerstandje kan 0,1 Watt of 0,25 Watt bedragen, grotere waardes zijn niet nodig.
Gerard
peterha
Reactie #16 Gepost op:
01 September 2011, 09:49:07 »
Hier nog even een update.
Ik heb een mail gestuurd naar Digirails met mijn vraag. Het antwoord was: "
Wat betreft het dimmen: dat is een beperking van de decoder. Gloeilampjes zijn wel software matig te dimmen maar leds niet. Daar biedt een hogere waarde serie weerstand een oplossing. In serie met de gele en/of witte draad een weerstandswaarde van 5k of meer dit moet door proberen worden vast gesteld."
Ik heb inderdaad een extra weerstand ertussen gezet en de leds branden nu minder fel. Dus: probleem opgelost, met dank aan Digirails
Peter
Peter
Reactie #17 Gepost op:
01 September 2011, 09:54:42 »
Het is inderdaad waar dat leds lastiger te dimmen zijn via PWM, maar het is niet onmogelijk.
Andere decoderfabrikanten krijgen het ook voor elkaar. Dus misschien moet Digirails daar eens de kunst afkijken.
Digitaal
Frontlicht dimmen?
