Schaal TT
T.Spat
02 February 2026, 23:50:58
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:59:03
02 February 2026, 22:43:31
Petertje
02 February 2026, 22:41:36
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
02 February 2026, 19:42:07
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Inrijbaan 240x120cm
02 February 2026, 16:29:13
Bielerfelderland spoor nul bouw
Topic: Bielerfelderland spoor nul bouw (gelezen 41216 keer)
HJ
Re:Bielerfelderland spoor nul bouw
Reactie #165 Gepost op:
23 June 2013, 11:06:20 »
Zo te zien op de foto's een prachtige layout!
Of zoals de duitsers zouden zeggen een: Traumanlage.
groetjes
Hendrik
PS wat kan een "L" meer of minder een verschil maken
Laatst bewerkt op: 23 June 2013, 20:20:03 door HJ
bernhard67
Reactie #166 Gepost op:
23 June 2013, 15:36:15 »
HOI HJ,
Tja was even een L vergeten maar goed nu staat er Avontuur in Miniatuur.
Misschien wel iets te veel meegenomen maar ik wou toch even het mooie nieuwe geluid van de V100 laten horen koste wel iets maar dan heb je ook wat moois qua geluid.
Groetjes van bernard
bernhard67
Reactie #167 Gepost op:
23 June 2013, 20:01:08 »
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Hoi Modelspoor liefhebbers,
tja wie nou eenmaal niet veel ruimte heeft zou deze leuke combinatie voor zijn spoor nul baan kunnen samen stellen. Zo klein treintje in spoor HO is geen gezicht maar als je de samenstelling met twee 3YB en één 4YB samensteld in spoor nul dan kan je al van een hele trein spreken.
De V100-10 of V100-20 staat voor zo trein heel mooi tja dat landschap op de foto zou je heel goed kunnen gebruiken als achtergrond.
tot zo ver dit berichtje over een leuke trein samen stelling
groetjes van bernard
Laatst bewerkt op: 23 June 2013, 20:08:30 door bernhard67
bernhard67
Reactie #168 Gepost op:
23 June 2013, 20:25:05 »
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Hoi modelspoor liefhebbers,
Hier bij nog twee foto's van trein samenstelling dit maal met zilverlingen met een V100-10 of V100-20. Deze trein samenstelling kan zo wel voor tijdperk III als tijdperk IV kan je zo wel een rode DB diesel voor zetten als blauw creme.
Als je deze samenstelling in spoor nul zou om zetten dan het je gelijk wel een hele lange trein en wordt het qua lengte zo 2.10 met V100 er voor wat op zich weer een heel mooi gezicht is. Als alles mee zit zou in 2014 de zilverlingen door MBW uitgebracht gaan worden lengte van zo wagon 60 cm voor spoor nul.
tot zo ver dit kleine berichtje over trein samenstelling tijdperk III en IV
bernhard67
Re: Bielerfelderland spoor nul bouw
Reactie #169 Gepost op:
10 July 2013, 19:31:49 »
Zo hierbij na een lange tijd weer eens even een klein berichtje van mij. Na lange tijd ben ik toch maar even begonnen met het gedeelte achter de onbewaakte overweg.
Ik heb er voor gekozen om de weg omhoog te doen, naast de weg loopt de stoep die weer langs een betonnen muur loopt. Op de betonnen muur is mijn bedoeling dat er een hekwerk boven op komt om de tuinen af te bakenen.
De woonhuis is nog niet helemaal klaar het dak moet nog worden afgemaakt en langs de ramen komen nog luiken. Het bruine zand wat in de tuin is te zien komt uit de van Wedestraat hier in Soest waar ze op dit moment de straat aan het veranderen zijn.
tot zo ver dit kleine bouw verslag
Laatst bewerkt op: 13 July 2013, 23:51:18 door bernhard67
Martin Welberg
FYA !!!
OO. Organisatie OntraXS!
Reactie #170 Gepost op:
10 July 2013, 20:12:57 »
Hep u ook grotere plaatjes
Mvgr. Martin
Mooie grasjes enzo
bernhard67
Reactie #171 Gepost op:
13 July 2013, 23:41:02 »
Zo vanavond voor de eerste keer de V200-0 op mijn spoor nul baan laten rijden. Wat is het toch een mooie lok om te zien geluid van de lok is super
Meer over de V200-0 is te lezen op mijn blog
Rubedino
Reactie #172 Gepost op:
14 July 2013, 00:32:40 »
Mooie lok!
Hoe zit het met de plannen voor het station wat ik voor je moest maken?
Heb je inmiddels tekeningen voor me?
bernhard67
Reactie #173 Gepost op:
14 July 2013, 12:27:04 »
Hoi Kees Jan,
Tekeningen voor het station heb ik jammer genoeg niet dus gaat dat even niet door.
Met vriendelijke groeten,
bernard
bernhard67
Reactie #174 Gepost op:
21 July 2013, 12:26:35 »
Zo inmiddels is het huis voorzien van dakpannen en de tuin verder afgemaakt. De beneden verdieping van de woning is nu voorzien van luiken. Deze luiken heb ik zelf gemaakt hiervoor heb ik dun wit plastic gebruikt vervolgens aan de zijkanten voorzien van dunne strookjes fineer rondom. Aan de boven kant in het midden dunne stukjes fineer over elkaar geplakt zo als deze luifel moet uitzien.
Daarna de luiken grijs groen geschilderd hiervoor Tamiya verf gebruikt.
Nu moet ik alleen nog schoorsteen maken plus een kleine dakkapel die aan de voorkant boven de deur komt te zitten,
Tot zo ver dit verslag van bouw van een kleine woonhuis
bernard
bernhard67
Reactie #175 Gepost op:
21 July 2013, 21:19:24 »
Zo vandaag ook nog even lekker in de zon begonnen met een kleine knutsel werk. Namelijk het hekwerk voor de tuin voor de voorkant van het huis. Het hekwerk is gelaserd zo dra het hele hekwerk klaar is dan wil ik het licht groen verven.
tot zo ver dit kleine knutsel bericht
bernard
HJ
Reactie #176 Gepost op:
22 July 2013, 00:40:59 »
Weer of geen weer,
je houdt het tempo hoog!
grt
HJ
PS lekker prutsen word je blij van
bernhard67
Reactie #177 Gepost op:
22 July 2013, 23:09:51 »
Hoi HJ,
Prutsen blijft altijd leuk om te doen of het nu in de winter of herfst is of in de zomer. Voor mij geld blijft het hele jaar gewoon lekker door gaan
met spoor nul is gewoon een veel te leuk hobby om dat niet te doen
groeten bernard
0spoorder
Reactie #178 Gepost op:
23 July 2013, 15:46:08 »
Dag Bernhard,
Wat is de lengte van de V200 ?
Ben.
bernhard67
Reactie #179 Gepost op:
23 July 2013, 19:36:26 »
Hoi Ben
Lengte van deV200 is zo 42 cm lang pas net op 1 Lens G1 rail.
Hoop hierbij voldoende geïnformeerd te hebben. In de V200-0 zit heel erg mooi geluid.
met vriendelijke groeten,
bernard
