Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Artitec SS700/NS3700  (gelezen 509163 keer)
  • Nervensäge.
    • belse roestkraam
Re: Artitec SS700/NS3700
« Reactie #2055 Gepost op: 30 January 2020, 15:09:06 »
die trapjes zitten er net als de zuigerstangbeschermers dan ook los bij. De vorige bewoner van de loc zal m dan ook wel in de vitrine gehad hebben?
sander1985
  • Team Mitropa *
    • -- Team Mitropa --
« Reactie #2056 Gepost op: 30 January 2020, 15:29:44 »
Of voldoende ruimte bogen, want dan rijdt de loc ook prima met de trappetjes
Bouw: OHMB - Krommeveer
Chrisjantje
  • I'm always keep TRAINing!!
« Reactie #2057 Gepost op: 14 February 2020, 20:37:18 »
Ja de nieuwe versie van Artitec, 5.0
Wat Robert bedoelt zijn de genoemde locomotieven in de post ervoor. Dus niet de 3700.
Heb MTE inmiddels even gemaild, eens kijken wat er uit komt.
Mijn zoontje al teleurgesteld dat er nog geen geluid is
Inmiddels contact gehad met MTE en Artitec. Artitec heeft mij gevraagd de decoder naar hen op te sturen zodat ze hem na kunnen kijken. Woensdag verstuurd en vandaag een nieuwe ontvangen, ook zij hadden geen idee wat het probleem precies was. Alle decoders werden getest voordat ze de deur uitgingen, maar de mijne was dus toch niet helemaal zoals het hoorde.
Maar inmiddels dus de nieuwe, hoopvol inpluggen, verwachtingsvol koppie van m'n zoontje en........yes geluid (y) Hulde voor de fantastische service van Artitec, een dikke plus en een tevreden klant (ook mijn zoontje dik tevreden, heeft ermee gereden tot bedtijd)
Als ik vroeger wist wat ik nu weet, had ik liever vroeger geleefd!!
    • MCKmodelbouw
« Reactie #2058 Gepost op: 31 March 2020, 11:37:04 »
In de categorie pimp mijn Artitec 3700 een klein verslag voor een koppeling aan de voorzijde.
Een goede vriend van mij wilde met zijn 3700en graag aan beide kanten een sleep rijtuigen kunnen koppelen. Bij gebrek aan een draaischijf moest de loc aan de voorzijde een kortkoppeling krijgen. Met de ervaring van mijn NS 6000 en de constructie van de Artitec 6300 als inspiratiebron ben ik aan de slag gegaan met het construeren van een koppelboom.
Allereerst heb ik van styreen een moedermodel gemaakt. Dit snijd, knipt en boord makkelijk. Nadat de definitieve versie klaar was heb ik dit vertaald in een drietal messing exemplaren. Vanuit een stripje messing is een mooie slanke boom gevijld. Het styreen model diende hierbij als een soort mal. Daarop werd met lijm een nemschacht geplakt. Zo kunnen alle soorten en maten koppelingen gemonteerd worden. Leek mij wel zo prettig.
De bogie moet iets aangepast worden. Er is bij het origineel geen ruimte voor een nemschacht. Aan de voorzijde moest iets weggesneden/geslepen worden. De Artitec 6300 heeft dezelfde bogies als de 3700, maar dan mét genoeg ruimte voor de nemschacht. Daar is in het ontwerp het stukje dat ik weg wilde halen al weggelaten. Ik was dus niet bang dat de constructie van de bogie te slap zou worden, want dan moest dit probleem bij de 6300 ook aanwezig zijn. De baanruimers zijn gedemonteerd en het stuk is weg geslepen. Let op, de baanruimers kunnen niet meer gemonteerd worden. Nu valt dat ook niet heel erg op...
Daarna was er een proefpassing van de koppelboom. De boom wordt vastgehouden door de schroef waarmee je de bogie monteert. De veer tussen chassis en bogie drukt de koppelboom op de juiste plek, namelijk direct tegen de onderkant van het chassis. Dit gaf - bij toeval - de perfecte hoogte! Als de hoogte niet juist was, dan had ik dit opgelost door een aantal ringen te plaatsen of de koppelboom te buigen.
Gekoppeld met een rijtuig is het bijna buffer aan buffer. Afhankelijk van je minimale boogstraal is hier nog wat mee te spelen, echter wilde ik voldoende ruimte bewaren voor eventuele krappe bogen. Deze afstand is geschikt voor Roco Geoline R3. Mijn minimum. Helaas kan het niet buffer aan buffer omdat je aan de loczijde geen kortkoppelingsmechaniek hebt. Daardoor is er een grote kans op overbufferen.
En de proefkoppeling en bogie weer gemonteerd:
Ik heb helaas geen foto van het eindmodel. Maar dat verschilt niet veel van het moedermodel, alleen dan is het zwart gespoten messing. De voorzijde heb ik daar nog iets schuin afgevijld zodat de bovenzijde mooi achter/onder de handgrepen onder de bufferstelen draait.
Mocht je ook zoiets willen, doe er je voordeel mee! (y)
Groet, Mathyn
Nu ook op instagram
  • Team Mitropa
« Reactie #2059 Gepost op: 31 March 2020, 11:46:41 »
netjes (y)
  • Bestuur
« Reactie #2060 Gepost op: 31 March 2020, 11:48:27 »
 (y)
  • NS tijdperk II(c)/III
    • Obdam in h0
« Reactie #2061 Gepost op: 31 March 2020, 11:58:22 »
Netjes Mathyn  (y). Deze ga ik onthouden, aangezien mijn 3700 t.z.t. ook buurtgoederentreinen moet rijden en rangeren :)
Fotodijkje en fotodiorama
Obdam
JurS
  • Swindon, UK
« Reactie #2062 Gepost op: 31 March 2020, 14:07:58 »
Mooie oplossing. Wat zijn de afmetingen van het messing plaatje?
Groetjes, Jur
  • Modelspoor is emotie...
« Reactie #2063 Gepost op: 31 March 2020, 19:45:23 »
Slimme oplossing (y). Zou het lukken om een maatschetsje te plaatsen? Daar zou je heel wat mensen een plezier mee doen denk ik zo... ;)
Tbinnebarretije…
    • MCKmodelbouw
« Reactie #2064 Gepost op: 10 April 2020, 10:03:27 »
Het gevraagde maatschetsje (y)
Gr, Mathyn
Nu ook op instagram
JurS
  • Swindon, UK
« Reactie #2065 Gepost op: 17 April 2020, 13:37:21 »
Perfect, bedankt hoor!
Groetjes, Jur
« Reactie #2066 Gepost op: 17 April 2020, 15:03:43 »
Met dank namens (ongetwijfeld) velen... (y)
Rob
« Laatst bewerkt op: 17 April 2020, 15:15:50 door Rob E. »
Tbinnebarretije…
Gerke
  • Mcn NSR
  • NS 4503!
    • Modelspoorvereniging Midden Limburg
« Reactie #2067 Gepost op: 16 May 2020, 13:50:39 »
Even een vraagje van mijn kant:
Weet iemand hier wanneer het schuifluik in het dak van de 3700 gekomen is? In het boek kan ik niks erover vinden, alleen het dichtzetten van de raampjes boven de vuur kist.
Zou dit ongeveer gelijktijdig plaats gevonden hebben?
Als iemand het weet: ik hoor het graag.
Met groet,
Ger.
TonM
« Reactie #2068 Gepost op: 16 May 2020, 15:45:06 »
Op foto's zie je dat in de 2e helft van de jaren 1930 sommige locs wel zo'n luik hebben en andere (nog) niet. Dus het lijkt mij dat ze in die periode zijn aangebracht.
Als ik snel door de foto's heen blader, lijkt het ook dat bij de loc met schuifluik de raampjes boven de vuurkist zijn dichtgezet en die raampjes bij de locs zonder schuifluik nog aanwezig zijn.
Snel een paar foto's bekijken is natuurlijk niet genoeg om conclusies op te baseren, maar misschien wel een richting om verder te zoeken.
En als je het helemaal zeker wilt weten, zal je in de archieven moeten duiken om de verschillende CW's te achterhalen.
Grtz, Ton
