Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Middagje op het dak..  (gelezen 3154 keer)
  • Spoor-0 & Spoor-1
    • Modeltreinbaan.nl
« Gepost op: 17 December 2006, 17:47:20 »
Nieuwe dakbedekking was hard nodig, dus vanmiddag het dak op.
Grijs schuurpapier een beetje zwart gespoten.
Houtlijm gemengd met zwarte acrylverf.
En dicht is mijn dakkie ;D
Jeroen1975
  • GTW in de tuin
  • 45mm, zelfbouw, Brits- en Achterhoeks smalspoor
    • Jeroen's Treinen Site
Re: Middagje op het dak..
« Reactie #1 Gepost op: 17 December 2006, 17:49:14 »
Dit zit er zeker mooi en geslaagd uit.
Ga zo door!!
Treinen van britse eilanden
Treinen uit de achterhoek
Peppi
  • Peppi1991
  • Obey your master!:P MASTER!
« Reactie #2 Gepost op: 17 December 2006, 18:13:38 »
Om de één of andere reden vind ik die teerlagen te dik en daarom minder mooi. :) Of de stroken zijn te smal... Maar het is wel netjes. Jaap, zo heb je toch ook het dak van de locloods bedekt? ;)
Our brains are on fire with the feeling to kill and it won't go away until our dreams are fulfilled. There is only one thing on our minds. Don't try running away 'cause your'e the one we'll find. Searching...Seek and destroy! Searching...Seek and destroy!
Eric "den Belg"
« Reactie #3 Gepost op: 17 December 2006, 18:29:15 »
Mooi gedaan, ik hoop dat het waterdicht is ;D
stig
« Reactie #4 Gepost op: 17 December 2006, 18:34:36 »
De stroken zijn zeker niet te smal, vergelijk maar met een raam. Maar de teernaad had iets subtieler gekund, dan was het af. Het idee is goed vind ik!
  • Spoor-0 & Spoor-1
    • Modeltreinbaan.nl
« Reactie #5 Gepost op: 17 December 2006, 18:41:36 »
Stroken zijn 10mmx87=87cm, mastiek is 100 cm
Teernaad had inderdaad beter gekund :'( (beun was op zondag aan het klussen ;D )
Harry
« Reactie #6 Gepost op: 17 December 2006, 18:58:54 »
Dan is die beun op zaterdag flink doorgezakt en niet opgehouden bij 15 pullen bier.
H0e: Lilliput en Halling
Ronald Tolner
    • Mijn eigen online MORPG
« Reactie #7 Gepost op: 17 December 2006, 19:09:49 »
gaaf man jaap , vind het echt schitterend eruit zien . idd beetje jammer van de te dikke teerlaag maar het een zeker een prachtige manier.
Mag ik de verhouding weten van je mengsel
Ga naar mijn site hij is echt te gek
  • Spoor-0 & Spoor-1
    • Modeltreinbaan.nl
« Reactie #8 Gepost op: 17 December 2006, 19:14:31 »
Witte houtlijm en dan een klein beetje zwarte acrylverf erbij. De kleur wordt dan grijs, maar als de houlijm opdroogt wordt de "teer"zwart.
« Reactie #9 Gepost op: 18 December 2006, 09:23:33 »
Kijk dat is nou het leuke van onze hobby. Je bedenkt iets, probeert het uit en weet na afloop hoe het nóg beter kan.
Nog even dak-inhoudelijk; mastiek daken werden tot halverwege de jaren '70 aangelegd. Daarna werden uitsluitend nog bitumineuze dakbedekkingen toegepast.
Goed branden van zo'n dak is een vak op zich en vergt vele m² oefening. Niet zo raar dus dat bij Jaap de randen wat uitgevloeid zijn  ;D.
  • Spoor-0 & Spoor-1
    • Modeltreinbaan.nl
« Reactie #10 Gepost op: 18 December 2006, 10:26:08 »
Marc, bedankt. Tenminste iemand die het begrijpt.. ;D
PieterW
    • Gemeente Laagstad-Hoogdorp
« Reactie #11 Gepost op: 18 December 2006, 10:47:26 »
Zo Jaap dat gaat er goed uitzien.
Persoonlijk zou ik de overgangen nog wat afzwakken met wat weathering kleurtjes grijs/wit en bruin tintjes. Ook de panelen iets van kleur laten varieren geeft een mooi "dak" beeld
Fraai  ;)
Peter
Niet iedere kop is een Hondekop
Sander
« Reactie #12 Gepost op: 18 December 2006, 12:17:27 »
iets donker groen erop (mos, gras of onkruid) zal zeker niet misstaan.
En Jaap, ik had het je zaterdag nog willen zeggen, jij met je opmerkingen kan van mijn part het dak op.
 Sander ;D
 Sander
m de deugd
Re:Middagje op het dak..
« Reactie #13 Gepost op: 07 September 2009, 21:20:51 »
Goeden avond Jaap
Leuk een dak in het klein
Kunnen we ook eens zien wat je met schuurpapier anders kan dan
aleen schuuren, gaafgedaan je moet d,r maar net opkomen (y) (y)
GROEDJES van Martin de Deugd (y)Ook n spoorder (y)
santerdam
« Reactie #14 Gepost op: 07 September 2009, 21:36:51 »
Als ik kijk naar de datum van de berichten, denk ik dat er zo ongeveer wel weer een nieuw dak op zal moeten.
Sander
