Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: BNLS-Werkspoor - Plan U 1:87 in geplot styreen  (gelezen 870498 keer)
Karst Drenth
    • Plan U op Sleutelspoor
« Reactie #2100 Gepost op: 16 May 2008, 17:20:04 »
P L A N  U  B O U W E R S  O P G E L E T ! !
Morgen, 17/5/2008, worden door Tilly ca. 40 setjes schort en scheenplaten afgeleverd in Houten.
Voor degenen die ze nog niet ontvangen hebben, maar morgen wel in Houten zijn:
Kom ze even afhalen aan de 'kroketten-tafel' zo rond 12:00. Dan heb je ze snel en zeker, zonder kans op breuk. En het scheelt mij een bende werk  :P
Grtzz,
Karst
    • sleutelspoor
« Reactie #2101 Gepost op: 16 May 2008, 19:16:12 »
Als je er belangstelling voor hebt ik heb morgen een paar interieurs bij me.Om 12 uur bij de bekende tafel.
Gr. Gerco
Karst Drenth
« Reactie #2102 Gepost op: 16 May 2008, 22:33:37 »
Bedoel je de cabine interieurs Gerco ?
Grtzz,
Karst
nscargo
  • Wederopbouw Opsolder
« Reactie #2103 Gepost op: 16 May 2008, 23:23:26 »
Nou, ik kan nog wel het een en ander gebruiken voor mn plan U.
Toegegeven, het meeste wat ik nog nodig heb is...lef.
Harm
    • sleutelspoor
« Reactie #2104 Gepost op: 17 May 2008, 01:25:46 »
Grtzz,
Karst
Ik heb er een aantal voor je geplot
Gr. Gerco
stig
« Reactie #2105 Gepost op: 19 May 2008, 01:43:02 »
Nou Karst, ik heb die Plan U bijna tegen de muur gesmakt. Het was echt heel gezellig hier net... Grrrrrrrrrrrrrrrr...  >:(
Ik ben die LEDjes in het plafond aan het frotten. Ok, prima. Ik denk, ik trek wel ff een kabel open en jat de strengen eruit. Fout, nog te dik. Bah, ik had echt geen zin om allerlei kleurtjes dun flexibel draad te kopen. Ook niet lijmbaar, hmm, raar spul. Dus de hele bende eruit gerukt. 'T connectortje kon ik nog van het balkon lossnijden.  :'(
Dan die draaistel connectors, zagen, zagen, krak. Hmmm, nou ja, een hoekje met een pennetje eruit, dat lijm ik wel weer. Maar goed, zo blijft er weinig heel na 2 connectors gemaakt te hebben. Die dingen lijken ook niet op die van jou op sleutelspoor. Maar goed, de ABk en B kunnen wel gedaan worden. Met wat lijm hier en daar... :-|
Maar goed, hoe positioneer ik nou die printplaat op de bodem van het balkon? Want die trutstekker moet wel in de connector die aan de wand gelijmd is en dan moet je het ook nog op de juiste positie leggen om aan de draaistelconnector te solderen... Hoe heb jij dat gedaan? :) Dot lijm onder printplaat, in de connector steken en dan de bodem in de bak stoppen? Wachten tot lijm droog is en dan de 2 weer scheiden? Draaistel connector solderen en klaaro?
Verder komen de deuren van de balkons precies op de connector. Daar moet dan wat uitgesneden worden.
En verder is vandaag uiteraard de Dordtse middenstand niet geopend om wat draad en weerstanden te halen... >:(
Hmmm, nou moet ik weer wat op eBay kopen om mijn humeur goed te krijgen... Eens even kijken... ;D
Karst Drenth
« Reactie #2106 Gepost op: 19 May 2008, 07:08:01 »
Citaat van: stig
...ik heb die Plan U bijna tegen de muur gesmakt...
Niet doen !!  :'( Geduld mijn zoon, geduld !!!  :D
Citaat van: stig
...allerlei kleurtjes dun flexibel draad te kopen...
Hoeven niet allerlei kleutjes te zijn, maar wel dun !  :P
Citaat van: stig
...Dan die draaistel connectors, zagen, zagen, krak...
Idd een K werkje, maar met een 0.1mm cirkelzaagje in de 'Proxxon/Dremel' gaat het vlot en pijnloos. Je zaagt bij de contra steeds op een tussenliggend contact...
Citaat van: stig
Je beschrijft de enig correcte manier ! Ik gebruik een dot 2 componentenlijm  :D
Citaat van: stig
...uhm... hier is dat uitgelegd ;)
Jammer dat het even tegenzit, maar nog even doorzetten ;) dan is een schitterend stel je deel  8)
Grtzz,
Karst
stig
« Reactie #2107 Gepost op: 19 May 2008, 11:15:08 »
Ach ja, we gaan er straks weer met frisse moed tegenaan! ;)
nscargo
« Reactie #2108 Gepost op: 19 May 2008, 11:42:32 »
Ik ben weer een stapje verder, ik heb nu de koppen, schorten en scheenplaten van Karst kunnen overnemen.Alleen ben ik dan weer vergeten te vragen naar de plotjes voor de interieurtjes van de cabina bij Gerco. De stripjes heb ik al wel, maar de draaistellen dan weer niet.En dat schijnt nog een probleem te gaan wordenIk ga mijn plan U samen met Jos (Roco) bouwen. Hij heeft een gele geloof ik, maar voor het bouwen maakt het niet veel uit.Ik heb onlangs de hele bouwbeschrijving uitgeprint en netjes in mapjes in een grote ordner gedaan. Een rode natuurlijk. Dus de start van mijn treinstel is een stap dichterbij gekomen. En samen met Jos durf ik het wel aan.Want de reactie van Stig om het bijna tegen de muur aan te smijten komt me wel bekend voor. Harm
« Laatst bewerkt op: 19 May 2008, 15:06:34 door nscargo »
stig
« Reactie #2109 Gepost op: 19 May 2008, 11:44:47 »
Op zich had ik met de constructie van het ding geen enkel probleem, alleen dat gefrot met ledjes en solderen van draadjes is niet aan mij besteed... Ach, zaten ze er maar in, dan kon het dak erop!
Ivo tB
« Reactie #2110 Gepost op: 19 May 2008, 12:39:38 »
Stig,
Goed dat je hem niet tegen de muur hebt gegooid. Beetje solderen en het wordt wel weer wat. Je bent dan vast nog niet begonnen aan de SMD LED's voor de front- en sluitseinen. Maar daar is een alternatief voor van Tom.
Bij mij bleek vorige week ineens dat er een spijltje tussen de cabineramen was gebroken. Het restje hing er nog half bij. Dus ik voorzichtig terugbuigen en ja, toen brak deze helemaal af. Daarna met een pincet ertussen proberen te wurmen, maar het leek wel of het afgebroken stuk groter was dan de ruimte. En ja, poing, daar vloog het stukje uit mijn pincet ergens op de vloer. Na een kwartier zoeken vond ik het zowaar weer terug. Dus weer proberen en na een paar minuten, poing de andere kant uit. Daarna heb ik het niet meer gevonden.
Vorige week Karst maar even gebeld, of hij naast goede koppen nog ergens een spijltje had liggen. Dat leek hem echter niks, dus afgelopen zaterdag had Karst nog een kop voor mij. Gisteravond in meer dan een uur voorzichtig de kop langs de voorkant van de cabinedeuren en net voor de goot op het dak eraf gezaagd, nadat ik een half uur nodig had gehad om de nieuwe kop op de goede plek door te zagen. En waarempel de delen pasten perfect. Nu nog een beetje plamuur tussen de halfronden en de kop en het zit weer goed. Foto's volgen later nog wel.
Kortom het zit ons allemaal wel eens tegen. Dat wordt nog leuk bij het spuiten.
Ivo
Ivo
stig
« Reactie #2111 Gepost op: 19 May 2008, 14:12:22 »
Gelukkig wel ja, dat gepiel met smd ledjes zie ik echt niet zitten. Ik houd wel van een beetje prutsen, maar dat gaat me te ver.
Hou op schei uit! ;D
Fijn dat het met je spijltje nog goed is gekomen!
nscargo
« Reactie #2112 Gepost op: 19 May 2008, 15:01:49 »
Ik heb Gerco inmiddels een berichtje gestuurd voor de plotjes van de cabine interieurs.
Ik ga zelf ook niet prutsen met die ledjes hoor. Tom heeft daar een perfecte oplossing voor, dus dat komt wel goed.
Ik krijg steeds meer zin om te beginnen, maar dan begin ik wel met die interieurtjes.
Die zijn niet zo groot  ;)
Harm
stig
« Reactie #2113 Gepost op: 19 May 2008, 16:26:44 »
Van die interieurtjes kan je ook aardig sacherijnig worden hoor! ;D
Delftinhetklein
    • bouweninhetklein
« Reactie #2114 Gepost op: 21 May 2008, 10:32:00 »
Onder de noemer "waar zijn al die plan U's gebleven" mijn bouw perikelen.
Wat dagen vrij dus maar eens aan het bouwen geslagen.
Omdat de koppen iets smaller zijn dan de bakken maar eens een andere methode geprobeerd.
De kop van de 'bak' van binnen uit redelijk 'vet' in de plastic weld gezet. Hierdoor wordt het styreen wat weker. Nu tijdelijk (lees een minuut of 15) wat gewichten op de kop geplaatst om zodoende de kop wat samen te persen....
Toch nog een zaagsnede gezet in de kop en deze een beetje naar buiten gebogen volgens de 'Karst methode"
Kon het alleen niet laten wat versteviging aan de binnenkant aan te brengen.
En dit is het resultaat tot nu toe
De schade aan raam stijltjes van de motorwagen is opgelopen tijdens het transport met TNT post.  :'( Maar dat komt wel weer goed.
Grt Erwin
