om 00:15:46
03 February 2026, 23:52:50
T.Spat
03 February 2026, 23:23:21
03 February 2026, 22:54:50
03 February 2026, 22:53:27
Mooi, maar hou je neus dicht…
03 February 2026, 22:51:05
03 February 2026, 22:38:45
Bertholdowitsch
03 February 2026, 22:34:39
03 February 2026, 22:32:08
03 February 2026, 22:23:43
Stub switches
03 February 2026, 21:54:07
03 February 2026, 21:52:47
03 February 2026, 21:46:39
Arjen52
03 February 2026, 21:45:35
Edwin2121992
03 February 2026, 21:18:19
Zoek site ombouw lokomotieven
03 February 2026, 20:59:07
Waalspoor
03 February 2026, 20:23:28
Rijnstraat
03 February 2026, 20:10:34
Exact-train 2026
VAM65
03 February 2026, 20:09:59
Fotowedstrijd 2025
03 February 2026, 20:02:50
Joz
03 February 2026, 19:37:34
Slijptrein
03 February 2026, 19:28:42
Nieuw in de winkel!
ex-DR V100
03 February 2026, 19:28:36
Lucien
03 February 2026, 19:12:23
03 February 2026, 18:47:07
Hout realistisch nabootsen
03 February 2026, 18:33:38
Zermitz
03 February 2026, 18:30:38
03 February 2026, 18:09:15
The Rail Lab
03 February 2026, 18:04:47
03 February 2026, 17:49:20
Digitaal
Welke decoder is dit
Topic: Welke decoder is dit (gelezen 2710 keer)
KNed
05 September 2009, 00:02:40 »
Ik heb tijdens de beurs in Houten vorige week een Lux stofzuigerwagon gekocht waar de volgende decoder in zit.
Kan iemand mij zeggen welke merk en type het is?
Koen
Beheerder van:
NL in Model
modelspooradressen
Marklin dipswitch[/u
Wim Ros
BHV
Re:Welke decoder is dit
05 September 2009, 00:19:14 »
Koooooeeeeeenn CV8 uitlezen nummer opzoeken en je weet het.
Mvg
Wim.
Intellibox via LocoNet-Interface met s88 via een s88 naar LocoNet adapter.Of L.NET-S88SD16-N Marklin 6021 via een 63820, LocoNet-Interface en een s88 naar LocoNet adapter. Lenz Digital Plus via LI101F of s88XPressNetLi s88SD16-n.
http://rosoft.boards.net
Online
05 September 2009, 08:29:00 »
Koen,
Lijkt heel erg (niet helemaal) op de Uhlenbrock 76400/420.
http://www.digital-bahn.de/info_lokd/lokdekoder/ul_76420_1.jpg
http://www.digital-bahn.de/info_lokd/lokdekoder/ul_76420_2.jpg
Gr, Ben.
Wim Ros
BHV
05 September 2009, 11:17:13 »
Koen, het merk is Uhlenbrock, want dat staat er op. Het Type CV7 lezen.
Mvg
Wim.
KNed
07 September 2009, 06:52:49 »
Bedankt voor de info.
Als ik decoders uit kon lezen had ik dat wel gedaan! Mijn Central Station kan het niet en met mrDirect moet je een aparte schakeling hebben die ik niet heb....
Maar hij lijkt heel erg op de afbeeldingen die Ben plaatste.
Dat er Uhlenbrock opstaat geloof ik graag maar ik heb het nog niet kunnen ontdekken
Het is ook allemaal zo priegelijk klein.
Koen
Beheerder van:
NL in Model
modelspooradressen
David Hoogvorst
07 September 2009, 07:57:44 »
Er staat ook niet letterlijk Uhlenbrock op, maar hun logo, de U met de R erin.
David.
KNed
07 September 2009, 09:05:23 »
Ik zag die inderdaad op de foto's uit Ben z'n antwoord wel staan maar op mijn foto nog niet. Maar ik geloof best dat die erop staat.
Als het inderdaad deze Uhlenbrock is is het een meevaller, ik had gedacht dat het een DCC decoder is maar deze Uhlenbrock is een multi-protocol. Dat scheelt weer een nieuwe decoder!
Ik moet misschien toch maar is de ACK schakeling voor mrDirect bouwen. Dan kan ik decoders uitlezen. Het adres vinden van deze decoder is dan ook makkelijker.
Al kan ik met m'n CS wel adressen vinden maar die gaat dan gewoon adres 1 t/m 80 uitproberen.
Koen
Beheerder van:
NL in Model
modelspooradressen
Wim Ros
BHV
07 September 2009, 11:32:47 »
Koen, dat adres hoef je niet te zoeken, als je MRDirect gebruikt kun je hem gewoon een adres geven. via CV1, dat is de eenvoudigste weg.
Dat veranderen of geven van een adres gaat ook met je CS, alleen iets omslachtiger.
Mvg
Wim.
Wim Ros
BHV
07 September 2009, 11:36:24 »
Citaat van: KNed op 07 September 2009, 09:05:23
Mvg
Wim.
KNed
07 September 2009, 13:08:12 »
Inderdaad!
En dat adres geven klopt natuurlijk ook, had ik niet aan gedacht!
Ik ga eens proberen binnenkort. Kijken of die het nog doet.
Verkoper kon er niets over zeggen, maar daarom had ik de wagon ook voor een heel leuk prijsje.
Koen
Beheerder van:
NL in Model
modelspooradressen
KNed
23 September 2009, 13:38:19 »
Nog even het laatste nieuws rond deze decoder: na wat zoeken bleek programmeren met een Märklin Central of Mobile station niet echt eenvoudig. Bovendien moet je dan het adres weten en dat wist ik nou net niet.
Daarom maar een poging gewaagd om m'n CS het adres op te laten zoeken, en ziedaar! bij adres 30 begon het motortje te snorren...
Ik blij! De decoder zit in een Lux stofzuiger die ik voor een zeer zacht prijsje gekocht heb, en hij werkt dus nog ook!
Adres 30 is bij mij nog vrij dus ik laat die lekker staan. Kan eventueel later nog wel wat met MrDirect programmeren als ik de verhuisdoos gevonden heb waar de mrDirect spullen in zitten
Nu alleen nog de stroomafname goed maken, die was voor 2-rail en zéér amateuristisch...
Koen
Beheerder van:
NL in Model
modelspooradressen
Digitaal
