Vandaag om 00:15:48
Vandaag om 00:04:16
13 February 2026, 23:59:24
PB Models, ICR-rijtuigen door MarkSpoor
13 February 2026, 23:57:00
13 February 2026, 23:55:09
13 February 2026, 23:30:44
13 February 2026, 23:08:59
Spoorwegmuseum in zwaar weer door Ferdinand Bogman
13 February 2026, 23:07:10
13 February 2026, 23:03:50
13 February 2026, 22:58:20
13 February 2026, 22:49:17
Roco 63421, hoe kom ik bij de stroomafname lipjes? door Albert de Heer
13 February 2026, 22:38:18
PT Trains 2026 door Chris Westerduin
13 February 2026, 22:10:50
Stub switches door Frank 123
13 February 2026, 21:50:55
13 February 2026, 21:49:12
13 February 2026, 21:41:19
13 February 2026, 21:24:24
13 February 2026, 21:13:45
13 February 2026, 20:31:01
Euronight 295 samenstelling door EN446
13 February 2026, 20:29:30
13 February 2026, 20:05:35
RailBOX Accessoire Decoder RB4400 door Etsmodelspoor.nl / Modelspoorbaanwinkel.nl
13 February 2026, 19:47:25
13 February 2026, 19:33:16
US diorama in H0 door Eric B
13 February 2026, 19:23:39
13 February 2026, 19:19:59
13 February 2026, 18:55:31
13 February 2026, 18:32:55
13 February 2026, 18:19:53
13 February 2026, 17:47:25
NMJ 2026 door hansberekvam
13 February 2026, 17:40:43
Auteur Topic: Liliput Sahimms901  (gelezen 1536 keer)
  • Take It Or Leave It
Liliput Sahimms901
« Gepost op: 12 August 2009, 12:40:24 »
Weet iemand de afmetingen van de Sahimms901 in 1:1?
http://www.fleischmann.com/images/Liliput/235771.jpg
De Liliput versie is breder dan de Märklin & Roco Shimmns bijvoorbeeld.
Ik heb het idee dat de Liliput te breed is, maar is dat ook zo?
« Laatst bewerkt op: 12 August 2009, 13:06:24 door Arnold van Heyst »
    • Filmpjes op YouTube
Re:Liliput Sahimms901
« Reactie #1 Gepost op: 12 August 2009, 15:44:56 »
Lengte 16,40 meter
Draaistellen type 714
eigengewicht 34,7 ton
maximale last bij DB D 100: 85 ton
Bouwjaar vanaf 1991
aantal: 100 stuks
Type is gebaseerd op type Sahmms711 uit 1974.
Uit boek goederenwagens DB van Stefan Carstens.
« Reactie #2 Gepost op: 12 August 2009, 15:55:39 »
Dat boek heb ik helaas niet.
Waar het mij om gaat is de breedte van de huif ???.
« Reactie #3 Gepost op: 12 August 2009, 16:14:43 »
De breedte van de huif staat ook niet in het boek van Carstens, dus pakken we het volgende boek, en wel Güterwagen der Bahn, uitgave door de DB zelf.
Hierin staat de breedte van de wagen inclusief huif beschreven als 3094mm, en dat de maximale breedte van de lading in het frame 2445mm is. Hoogte is 4295mm.
Als ik dit vergelijk met de Shimmns708 (hoogte 4110mm) en de Sahimms900 (4148mm) geeft het boek precies dezelfde breedte aan, dus wat dat betreft kun je afleiden dat de Liliput te breed is. Verder zijn van het Liliput model de draaistellen nogal vlak weergegeven, wat de bak nog breder zal doen lijken.
« Reactie #4 Gepost op: 12 August 2009, 16:46:07 »
De huif is 35.5 tot 36mm breed.
RodeDuivel
« Reactie #5 Gepost op: 12 August 2009, 17:37:12 »
De conclusie is dat de breedte correct is. 3.094 meter maakt 35.5 tot 36.0 millimeter. De stelling dat het model te breed is derhalve onjuist.
Grts,
Willem
« Reactie #6 Gepost op: 12 August 2009, 17:46:28 »
Oftewel, hij klopt :D.
Bedankt voor alle info heren (y).
