Schaal TT
T.Spat
02 February 2026, 23:50:58
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:59:03
02 February 2026, 22:43:31
Petertje
02 February 2026, 22:41:36
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
02 February 2026, 19:42:07
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Inrijbaan 240x120cm
02 February 2026, 16:29:13
Digitaal
Fleischmann piccolo 7230 (BR212) met Kuehn N025
Topic: Fleischmann piccolo 7230 (BR212) met Kuehn N025 (gelezen 4357 keer)
Patrick Pontier
Maak van de scherf in je hart geen dolk in je mond
09 May 2009, 16:58:31 »
Gisteravond deze decoder in betreffende loc gebouwd.
Van te voren reed deze loc prima, maar na de inbouw lijkt de stroomafname er alleen maar slechter op geworden.
Dus het spul weer uit elkaar gehaald en nogmaals alle stroomafnemers en wielen schoon gemaakt maar geen verbetering
Uitlezen en programmeren gaat prima, rijden dus schokkerig.
Zijn er nog opties wat ik zou kunnen proberen?
De inbouw aan de hand van deze link gedaan
http://www.1zu160.net/digital/einbaubsp/gfn-212.php?view=all&id=#ufb
en ook deze link
http://www.nbf-worms.de/html/decodereinbau.html
Bij de bovenste link word er gesproken over het omzetten van CV 50 maar dat gaat om een Lenz decoder.
Is het zinvol dit te gebruiken bij een Kuehn?
Iemand een idee?
Alvast bedankt,
Patrick
Trein
HO Fleischmann TC Koploper SBB
Re:Fleischmann piccolo 7230 (BR212) met Kuehn N025
09 May 2009, 17:18:17 »
Hallo Patrick
Kijk eens op deze link.
http://www.kuehn-digital.de/
Mvg bert.
Jos001
N en G rijder
09 May 2009, 17:36:13 »
Als het goed is heb je de printbaan op 2 plaatsen onderbroken tussen de stroomdoorvoerklemmetjes die ook het printje vastzetten.
Heb je wel een draadbrug genaakt om de beide uiteinden weer met elkaar te verbinden? Anders ben je de stroomafname van 1 wiel kwijt.
Groetjes,
Jos
N-spoor, digitaal met TC
G-spoor, digitaal met LGB-MZS
Patrick Pontier
09 May 2009, 17:46:53 »
Gedankt voor de reakties
@Bert, bedankt voor de link ik zie alleen niet het antwoord
@Jos, de printbaan heb ik idd op de twee plekken onderbroken en de draadbrug heb ik geplaatst.
Patrick
Jos001
N en G rijder
09 May 2009, 18:12:10 »
Patrick,
Wat staat er in CV29? En waarmee programmeer je?
Groetjes,
Jos
Patrick Pontier
09 May 2009, 18:43:24 »
CV29 = 2
Ik programmeer met de DecProg van Passmann. Mijn systeem is DINAMO-hybride. Aansturing koploper.
Patrick
Jos001
N en G rijder
09 May 2009, 19:05:54 »
Ik ken DINAMO niet. Staat het op 28 stappen ingesteld? Lokadres daarin ook op DCC?
Groetjes,
Jos
Patrick Pontier
09 May 2009, 20:05:30 »
Voor info over DINAMO zie link
http://dinamo.vanperlo.net/
Het is een DCC systeem, wordt bijvoorbeeld ook gebruikt bij RAILZ. Je kan er gecombineerd met analoge locs en digitale locs rijden.
De loc is ingesteld op 28 stappen. DINAMO ook.
Patrick
Digitaal
