Schaal TT
T.Spat
02 February 2026, 23:50:58
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:59:03
02 February 2026, 22:43:31
Petertje
02 February 2026, 22:41:36
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
02 February 2026, 19:42:07
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Inrijbaan 240x120cm
02 February 2026, 16:29:13
Digitaal
intellibox
Topic: intellibox (gelezen 1476 keer)
DB 189-008 6
intellibox
01 February 2009, 17:30:57 »
hallo allemaal
ik heb intellibox maar kan intellibox op clubbaan(heeft dubbelspoor) (HO DC) van ongeveer 25 meter lang (in elke module zo'n 1 meter lang)
clubbaan heeft zo'n grote trafo (2x 300VA 16V~ 5A)
moet hoeveel booster's nodig of niet?
groet thijs
Laatst bewerkt op: 01 February 2009, 17:34:04 door DB 189-008 6
Wim Ros
BHV
Re: intellibox
01 February 2009, 17:35:21 »
Ja, en waarom zou dat niet kunnen. En wat is nu 25 meter??
Mvg
Wim.
Intellibox via LocoNet-Interface met s88 via een s88 naar LocoNet adapter.Of L.NET-S88SD16-N Marklin 6021 via een 63820, LocoNet-Interface en een s88 naar LocoNet adapter. Lenz Digital Plus via LI101F of s88XPressNetLi s88SD16-n.
http://rosoft.boards.net
DB 189-008 6
Re: intellibox
01 February 2009, 17:39:20 »
25 meter lange clubbaan(die clubbaan is van modelspoorclub drachten)
ze zijn bezig met 9 meter station-module (centraal station amsterdam )
ze bestolen analoog vervangen door DCC
heeft twee keerlussen
thijs
Wim Ros
BHV
Re: intellibox
01 February 2009, 17:45:40 »
Geen probleem dus. Goed aansluiten met voldoende aansluitingen op een centrale voedingsleiding kortweg CVL of ringleiding. En gaan met die baan.
Mvg
Wim.
DB 189-008 6
Re: intellibox
01 February 2009, 17:50:32 »
en moet ik ook booster's nodig?
onder module's van clubbaan zitten draden van 4mm dikte
thijs
Laatst bewerkt op: 01 February 2009, 17:52:38 door DB 189-008 6
Re: intellibox
01 February 2009, 17:56:17 »
Dat is afhankelijk van het aantal treinen dat tegelijk kan rijden.
Op een grote clubbaan is het wel zeer waarschijnlijk dat er een booster (of een paar boosters) aan te pas moet komen, maar uiteindelijk kunnen jullie dat alleen zelf bepalen.
santerdam
Re: intellibox
01 February 2009, 18:03:58 »
Het is me niet helemaal duidelijk. Je praat over een clubbaan en jouw IB. Heeft de club zelf dan geen centrale ? De techneuten van de club zullen vast wel een plan hebben voor de aanleg, heb je dat plan al eens bekeken ?
Sander
DB 189-008 6
Re: intellibox
01 February 2009, 18:12:56 »
die club in drachten heeft geen techneuten alleen mensen met hobby
de club heeft geen centrale maar ze rijden op analoog
paar treinen hebben decoder(DC/DCC)
dus heb ik Intellibox IR en heb ik geen booster
welke heb ik nodig?
uhlenbrock(power 3) of andere booster
er rijden 5~10 treinen
nog ding heb ik probeleem : twee keerlus
thijs
Laatst bewerkt op: 01 February 2009, 18:15:18 door DB 189-008 6
Re: intellibox
01 February 2009, 21:51:40 »
Okay, dus je wil gewoon je eigen IB op de baan aansluiten, zodat er ook eens digitaal kan worden gereden. Dat kan je natuurlijk gewoon doen. Kun je een stuk of 4 treinen laten rijden. Probeer dat eerst eens op het gemak.
Keerlussen zijn analoog ook een probleem. Hoe is dat nu opgelost?
DB 189-008 6
Re: intellibox
04 February 2009, 12:37:48 »
ja klopt
keerlussen zijn standaard met relais via wissel met schakelaar en spoelen
de club rijden altijd (op analoog) : 2~3 treinen
de club bestolen rijden op digitaal :5~10 treinen
uhlenbrock booster "power 3" heeft keerlusmodule ingebouwd
moet booster erbij nodig?
let op alle modules van club hebben tweesporen ,hoe oplossen?
thijs
Laatst bewerkt op: 05 February 2009, 11:59:31 door DB 189-008 6
Digitaal
intellibox
