Pantografen mDDM door Biesje
Vandaag om 02:27:32
Heroplage Artitec Plan W? door Peter J K
Vandaag om 01:10:07
Rondom Charlois door NS264
Vandaag om 00:40:06
Vandaag om 00:27:57
Miniature Project in Noordwijk ,wat is dit voor bedrijf? door Duikeend
Vandaag om 00:21:11
Faller 2026 door Floris Dilz
Vandaag om 00:13:44
Bouw van tijdperk 1 HSM en SS rijtuigen door Rob Bennis
27 January 2026, 23:25:28
27 January 2026, 23:23:59
Dubbele keerlussen in schaduwstation door RobVille
27 January 2026, 23:19:28
27 January 2026, 23:13:48
27 January 2026, 23:12:30
Interesse stamtafel/club Amersfoort? door Huib
27 January 2026, 22:58:24
17 mei Modelspoorbeurs Houten door Quinzeedied
27 January 2026, 22:11:15
27 January 2026, 22:03:24
Artitec 2026 door arnout
27 January 2026, 21:48:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Quinzeedied
27 January 2026, 21:39:02
19 Toen door Ferdinand Bogman
27 January 2026, 20:55:10
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robert vh Prutsert
27 January 2026, 20:38:40
Molenbaan (werktitel) door basjuh1981
27 January 2026, 20:32:50
Altbau e-loc BR163 zelfbouwen in H0 door Frits C
27 January 2026, 20:21:19
Reysburg H0 (NL TP 5/6) door Chiel
27 January 2026, 19:52:15
Länderbahn en Reichsbahn locomotieven. door Ronald69
27 January 2026, 19:36:39
Positie anti-slipbanden bij zes-assige draaistel locs (Roco, DC, H0) door Klaas Zondervan
27 January 2026, 19:35:55
DaisyII door Steven Loosman
27 January 2026, 19:30:06
PIKO 2240 71096 uit de doos! door Ben
27 January 2026, 19:12:01
27 January 2026, 18:52:49
SIK Roco 72012 snelheid ijken Itrain door Steven Loosman
27 January 2026, 18:50:24
Jouef BB9201 anno 1968 door saskia
27 January 2026, 18:48:38
Plan N van Heris. door Edsko Hekman
27 January 2026, 18:35:09
Model cipressen in 1:87 door Sven
27 January 2026, 18:12:17
Auteur Topic: CT electronik DCX 74D/N decoder met probleempje  (gelezen 2550 keer)
Bouwe
  • Koekiemonster
  • Nitropa
« Gepost op: 11 October 2006, 14:10:31 »
Hallo
Mijn Minitrix Koploper is voorzien van een - voor mij onbekende - dcc decoder. Deze werkte tot voor kort perfect.
Nu heb ik het volgende probleem. Als ik nu een oneven rijstap instel (bijv. 1, 3, 5, 7 enz), rijdt de trein als de spreekwoordelijke trein, als ik een even rijstap instel (bijv. 2, 4, 6 enz) dan rijdt de trein schokkerig,
Een reset van de decoder heeft niets geholpen. Met een andere decoder in deze trein heb ik dit probleem niet. Decoder heb ik ook geprobeerd in een andere trein, hetzelfde effect.
Is de decoder nog te redden of moet deze vervangen worden?
Met vriendelijke groeten,
Bouwe
« Laatst bewerkt op: 12 October 2006, 11:34:49 door Bouwe. Reden: Type decoder bekend »
RoSoft
Re: Onbekend soort decoder met probleempje
« Reactie #1 Gepost op: 11 October 2006, 14:14:34 »
Bouwe,
Zet de lok op het programmeerspoor en lees CV8 uit. Plaats de waarde van de uitlezing hier, dan vertellen wij je welke decoder het is, en of hij gereset kan worden en hoe.
Mvg
Wim.
Bouwe
  • Koekiemonster
  • Nitropa
« Reactie #2 Gepost op: 11 October 2006, 14:16:05 »
Hallo Wim,
CV8 waarde is 117
Bouwe
Hans van de Swaluw
« Reactie #3 Gepost op: 11 October 2006, 14:19:19 »
Stuur je deze decoder vanuit de centrale wel aan met hetzelfde aantal rijstappen??
Ik kan weliswaar dit probleem niet doch wel is bekend dat de verlichting niet correct werkt als het aantal rijstappen in de centrale en decoder niet hetzelfde zijn.
Aangezien je het type decoder niet kent en dus de handleiding ook niet hebt zul je wat moeten experimenteren met diverse instellingen op de centrale.
De instelling voor het aantal rijstappen zit (gelukkig) bij vrijwel alle DCC decoders in dezelfde funktie (29 bit 1).
2-rail, IB met Koploper en veel (teveel) randapparatuur
RoSoft
« Reactie #4 Gepost op: 11 October 2006, 14:32:56 »
Dit is een CT-Elektronik decoder, een uitstekende decoder, welke met kop en schouders boven de rest uitsteekt. Meer informatie over deze decoder staat op www.tran.at
Mvg
Wim.
« Laatst bewerkt op: 11 October 2006, 14:45:41 door Wim Ros »
Bouwe
  • Koekiemonster
  • Nitropa
« Reactie #5 Gepost op: 11 October 2006, 16:16:09 »
Hallo Wim,
Bedankt voor de link, heb opgezocht welke decoder ik heb: DCX74D/N.  Heb volgens de gebruiksaanwijzing de decoder gereset.  Helaas heeft dit geen effect gehad, de lok schokt nog steeds bij een even rijstap en rijdt als de spreekwoordelijke trein bij een oneven rijstap.
Weet iemand nog een oplossing of is dit het einde van de decoder?
Bouwe
RoSoft
Re: CT electronik DCX 74D/N decoder met probleempje
« Reactie #6 Gepost op: 11 October 2006, 17:19:06 »
Bouwe,
Misichien even wat onderhoud plegen aan de trein zelf?
Mvg
Wim.
Bouwe
  • Koekiemonster
  • Nitropa
« Reactie #7 Gepost op: 11 October 2006, 19:25:05 »
Wim,
Het ligt niet aan de trein. Heb deze decoder ook in een andere koploper gestoken en de trein vertoonde precies hetzelfde gedrag  :-[
Bouwe
RoSoft
« Reactie #8 Gepost op: 11 October 2006, 19:40:21 »
Als resetten niet helpt, neem dan even contact op met de heer Tran. Email adres staat op zijn site.
Mvg
Wim.
Bouwe
  • Koekiemonster
  • Nitropa
« Reactie #9 Gepost op: 11 October 2006, 19:41:56 »
Hallo Wim,
Daar ben ik net mee bezig, desondanks bedankt dat je meedenkt!
Bouwe
Bouwe
  • Koekiemonster
  • Nitropa
« Reactie #10 Gepost op: 12 October 2006, 10:30:59 »
Heb een reactie van Tran gekregen op mijn email. Dit probleem is niet bij bekend bij de firma.  Mij werd verzocht om de decoder op te sturen voor kostenloos onderzoek.
Bouwe
« Laatst bewerkt op: 12 October 2006, 11:34:28 door Bouwe »
Bouwe
  • Koekiemonster
  • Nitropa
« Reactie #11 Gepost op: 30 November 2006, 12:41:53 »
Vandaag een reactie van de firma Tran gekregen. In de brief wordt verteld dat de decoder gerepareerd is. Wat er precies aan mankeerde wordt niet verteld. De decoder is bijgesloten bij de brief en functioneert weer naar behoren.
Bouwe
