Daan Knoben
om 00:48:20
om 00:42:51
servo aansturing
Ruud Teunissen
om 00:15:48
13 February 2026, 23:59:24
MarkSpoor
13 February 2026, 23:57:00
daveric
13 February 2026, 23:55:09
13 February 2026, 23:30:44
Vraagje over servo aansturing
13 February 2026, 23:08:59
Spoorwegmuseum in zwaar weer
13 February 2026, 23:07:10
TTI Bergland Express
metpetergaathetbeter
13 February 2026, 23:03:50
13 February 2026, 22:58:20
13 February 2026, 22:49:17
Roco 63421, hoe kom ik bij de stroomafname lipjes?
Albert de Heer
13 February 2026, 22:38:18
PT Trains 2026
13 February 2026, 22:10:50
Stub switches
13 February 2026, 21:50:55
LS Models 2026
Dennis1984
13 February 2026, 21:49:12
13 February 2026, 21:41:19
13 February 2026, 21:24:24
Hobojohn
13 February 2026, 21:13:45
jan55
13 February 2026, 20:31:01
Euronight 295 samenstelling
EN446
13 February 2026, 20:29:30
nighttrain1
13 February 2026, 20:05:35
Etsmodelspoor.nl / Modelspoorbaanwinkel.nl
13 February 2026, 19:47:25
13 February 2026, 19:33:16
13 February 2026, 19:23:39
13 February 2026, 19:19:59
j.ossebaar
13 February 2026, 18:55:31
Rsd1000
13 February 2026, 18:32:55
13 February 2026, 18:19:53
Sporlijn Úje
13 February 2026, 17:47:25
Digitaal
MR-Direct en roco booster 10764
Topic: MR-Direct en roco booster 10764 (gelezen 2158 keer)
Beusi
Pindakaas is lekker
07 October 2008, 17:26:40 »
Is het mogelijk om MR-direct te gebruiken met de roco booster met artik. nr. 10764 ipv die op de MR-direct website is aangevene (10761) Visueel zien ze er hetzelfde uit.
mvg Niels
Wim Ros
BHV
Re: MR-Direct en roco booster 10764
07 October 2008, 18:51:48 »
Ja, dat kan, je hebt alleen geen kortsluitbeveiling dus bij de eerste de beste kortsluiting is de booster overleden.
Mvg
Wim.
Intellibox via LocoNet-Interface met s88 via een s88 naar LocoNet adapter.Of L.NET-S88SD16-N Marklin 6021 via een 63820, LocoNet-Interface en een s88 naar LocoNet adapter. Lenz Digital Plus via LI101F of s88XPressNetLi s88SD16-n.
http://rosoft.boards.net
Beusi
Pindakaas is lekker
07 October 2008, 18:52:31 »
is dit eventueel te verhelpen met een kleine schakeling?
br194
Zie geen problemen, alleen uitdagingen.
14 October 2008, 17:44:44 »
Hallo Niels,
Hierbij een oplossing om de Rocobooster aan te sluiten op MR-Direct met kortsluitbeveiliging.
De schakeling is getest met diverse versie's van MR-Direct en werken goed.
Er is geen extra hulpspanning voor nodig, die wordt uit de RS232 aansluiting gehaald (pen 4).
Op de tekening staat ook aangegeven hoe je de schakeling moet aansluiten op de print van de booster of RJ10 connector.
ALs je een beetje handig bent zou de schakeling in de kap van de RS232/9 pol. connector kunnen onderbrengen.
Als je de booster open wilt maken om deze direct op de print aan te sluiten, kun je in de handleiding van MR-Direct de uitleg hierover vinden.
Let wel de schakeling is alléén getest op MR-Direct, of het ook bij andere DD software werkt heb ik niet uitgeprobeerd.
Indien je er problemen mee hebt laat het maar even weten.
Succes.
Willem
Laatst bewerkt op: 14 October 2008, 17:49:13 door Willem
Digitaal
