Faller 2026 door Floris Dilz
Vandaag om 00:13:44
Miniature Project in Noordwijk ,wat is dit voor bedrijf? door Reinier Z.
27 January 2026, 23:58:17
Bouw van tijdperk 1 HSM en SS rijtuigen door Rob Bennis
27 January 2026, 23:25:28
27 January 2026, 23:23:59
Dubbele keerlussen in schaduwstation door RobVille
27 January 2026, 23:19:28
27 January 2026, 23:13:48
27 January 2026, 23:12:30
Heroplage Artitec Plan W? door Quinzeedied
27 January 2026, 23:12:25
Interesse stamtafel/club Amersfoort? door Huib
27 January 2026, 22:58:24
17 mei Modelspoorbeurs Houten door Quinzeedied
27 January 2026, 22:11:15
27 January 2026, 22:03:24
Artitec 2026 door arnout
27 January 2026, 21:48:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Quinzeedied
27 January 2026, 21:39:02
19 Toen door Ferdinand Bogman
27 January 2026, 20:55:10
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robert vh Prutsert
27 January 2026, 20:38:40
Molenbaan (werktitel) door basjuh1981
27 January 2026, 20:32:50
Altbau e-loc BR163 zelfbouwen in H0 door Frits C
27 January 2026, 20:21:19
Reysburg H0 (NL TP 5/6) door Chiel
27 January 2026, 19:52:15
Länderbahn en Reichsbahn locomotieven. door Ronald69
27 January 2026, 19:36:39
Positie anti-slipbanden bij zes-assige draaistel locs (Roco, DC, H0) door Klaas Zondervan
27 January 2026, 19:35:55
DaisyII door Steven Loosman
27 January 2026, 19:30:06
PIKO 2240 71096 uit de doos! door Ben
27 January 2026, 19:12:01
27 January 2026, 18:52:49
SIK Roco 72012 snelheid ijken Itrain door Steven Loosman
27 January 2026, 18:50:24
Jouef BB9201 anno 1968 door saskia
27 January 2026, 18:48:38
Plan N van Heris. door Edsko Hekman
27 January 2026, 18:35:09
27 January 2026, 18:28:47
Model cipressen in 1:87 door Sven
27 January 2026, 18:12:17
Minibaan Visserskaai H0 door Sven
27 January 2026, 18:11:17
Bouw graafmachine Artitec. door Herb73
27 January 2026, 18:10:14
Auteur Topic: Nieuwe bome, verse nieuwe bome!!!  (gelezen 396030 keer)
Patrick1975
Re: Nieuwe bome, verse nieuwe bome!!!
« Reactie #1215 Gepost op: 31 December 2022, 09:43:57 »
Mooi Jos, eigen bouw het muurtje met bloembak?
Gr.Patrick
grove den
  • Modelboombouwer
    • MBB Grove Den Modelboombouw
« Reactie #1216 Gepost op: 31 December 2022, 10:35:34 »
Bedankt allen.
@ Patrick:
Idd eigen b(r)ouwsel.
Gewoon op maat gesneden afgietsels van gips en de dekstenen van ondervloer v. laminaat.
Jos
natuurlijk kunstboompjes
http://mbbgroveden.com/
grove den
  • Modelboombouwer
« Reactie #1217 Gepost op: 04 January 2023, 14:44:07 »
terug naar de bomen!
"Geroddel in het bos!!"  ::)
H0 en de "hoogstammen" om /nabij de 20+ cm
Jos
« Laatst bewerkt op: 04 January 2023, 14:45:58 door grove den »
grove den
  • Modelboombouwer
« Reactie #1218 Gepost op: 16 February 2023, 22:12:11 »
Ze roddelen wat af...nog steeds! ..... maar nu 200 meter verder op.
Simpele laanbomen op een rij . helaas heb ik geen staddiorama dus gewoon in de "natuur" gezet ::)
"Simpele" in de trant van vrij makkelijk te vervaardigen ( als je een grassmaster of zoiets tot je beschikking hebt  ;))
Jos
Edsko Hekman
  • Nooit uitgeklust....
« Reactie #1219 Gepost op: 17 February 2023, 11:54:40 »
En hoe maak ik die dan? Vind ze wel mooi. (y)
Biessendorf
  • Carpe diem
« Reactie #1220 Gepost op: 17 February 2023, 14:30:28 »
Ik wilde dat ik jouw skills, tijd en geduld had.
Maar ja dat geld ook voor die van Martin Welberg, Lars op 't Hof, TonM, FritsT en nog vele anderen.
Carpe Diem
grove den
  • Modelboombouwer
« Reactie #1221 Gepost op: 17 February 2023, 16:39:06 »
@Biessendorf:
Ja da's dan wederzijds! Ik bak echt letterlijk niks van wat er allemaal "onder" de baan moet gebeuren! ( redelijke digibeet)
Ook het technische gedeelte betreffende het onderhoud van locs /matrerieel.... geen kaas van gegeten!
Moet wel erbij vermelden dat ik dus zelf geen modelbaan heb waar ik aan kan/mag werken. Af en toe bij een vriend of een opdracht....dat wel weer.
Maar @ Edsko:
Zo'n boompje- Carpinus betulus fastigiata,  is gewoon het draadgeraamte van een spar alleen eitsje korter van hoogte. De bast is weer een of 2 laagjes hele fijne zand/löss. Als je het heeeel perfect wil doen dan daarna ook nog met een goedkoop smal kwastje de structuur voor de  bast aanbrengen met heavy gel mat AMSTERDAM  van Talens. Is wel doorzichtig maar als het droog is een kleurtje geven en klaar!
De draden in de juiste stand buigen( "schuin omhoog") en op  de juiste lengte knippen rekening houdend met het nog aanbrengen van 12 mm vezels en daarna 4 mm vezels.
Deze  ,na elke laag opbrengen met de grasmaster,  lichtjes nu naar boven !! blazen. ( bij de sparren was dit juist naar beneden ;D)
De "kunst" is om niet te hard te blazen of föhnen( whatever)  want dan liggen/ worden  ze allemaal tegen de draad aan geplakt!
Na de eerste 12 mm vezels de lijm wat laten drogen en mogelijk met een scherpe schaar wat corrigeren/wegknippen wat niet goed "groeit" In mijn geval Alles dus omhoog= fastigiata!
De vezels dan met een donkergroen/olijfachtige kleur uit een spuitbus of zo bespuiten als basis voor de blaadjes EN het zorgt voor meer stevigheid van de boom in totaal.
ook weer ff laten drogen en dan tenslotte , met een fijne  meelzeef en eerst  lichtjes met spuitlijm over de boom  de fine turf over de buitenkanten van de vezels strooien/verdelen. 2 x matte lak en klaar.
Zal in de loop van de volgende week een stap voor stap maken....met plaatjes erbij natuurlijk.
Jos
« Laatst bewerkt op: 17 February 2023, 16:43:51 door grove den »
Ric
« Reactie #1222 Gepost op: 17 February 2023, 18:34:20 »
top Jos (y)
Grt. Ric.
grove den
  • Modelboombouwer
« Reactie #1223 Gepost op: 17 February 2023, 19:58:39 »
De aftrap:
Het maken van het frame.
Kerndraad is van ijzerdraad met doorsnede van 1 ,5 mm.
De "lus"draden , 3 stuks van 40 cm x0,6 mm.
Deze lusdraden strak om de kerndraad draaien. Belangrijk is dat je na minimaal 5 draadomwentelingen een lus kunt maken. Die 5 x heb je nodig om de secondelijm zijn werk te laten doen= vastlijmen van de draden om de kerndraad. Als de draden op zijn plek zijn gedraaid en mooi strak tegen de kerndraad zitten kun je deze lijmen met druppels seconde/superlijm.
Als lijm verhardt is/droog dan een primer erover verven/spuiten.
En alweer laten drogen....
De lussen zijn ongeveer 30 mm lang.
Zou ze niet korter maken. T'is gewoon makkelijker werken met iets langere lussen. Zeker wanneer je het eind van  lussen na drogen van de superlijm gaat afknippen
 Dan de lussen open/los knippen.
een  magneet uit een oude fietsdynamo doet nog goeie diensten  ;)
de draden in de juiste stand buigen ( een fot van de echte boom is handig als referentie:
laag verf/primer:
en weer drogen laten....dus de rest voor morgen.
« Laatst bewerkt op: 17 February 2023, 23:02:51 door grove den »
Edsko Hekman
« Reactie #1224 Gepost op: 18 February 2023, 00:08:43 »
Top Jos!!!!! (y)
Dank je wel! :D
Gr.
Edsko
« Reactie #1225 Gepost op: 18 February 2023, 00:27:16 »
Hoi Jos,
Ook ik ben fan (y)
Echt ongelofelijk mooi wat je maakt.
Deze uitleg helpt een hoop, wel heb ik meteen een vraag.
Waar koop je dat ijzerdraad?
Is het is speciaals?
Met hartelijke groet.
Dave
Rheinburg tijdperk V/VI
Pascal77
« Reactie #1226 Gepost op: 18 February 2023, 09:37:04 »
Vraagje, je begint met de eerste draad onderaan de stam te draaien en zodra deze “op” is draai je verder naar boven met de tweede enz of begrijp ik het verkeerd?
Mvg Pascal
Wie het kleine niet eert, zit op dit forum verkeerd.
Nederdam
Diorama
  • NS tijdperk II(c)/III
    • Obdam in h0
« Reactie #1227 Gepost op: 18 February 2023, 09:46:42 »
Nog een meelezer :)
Fotodijkje en fotodiorama
Obdam
Biessendorf
  • Carpe diem
« Reactie #1228 Gepost op: 18 February 2023, 09:55:08 »
+1
Carpe Diem
johanw
« Reactie #1229 Gepost op: 18 February 2023, 09:59:49 »
En nog 1. Mooi uitgelegd ook.
Groet Johan Westhoeve.
