Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Bouw klein voorstation 'Amerpoort' begonnen  (gelezen 496721 keer)
Bart Mestrom
Re: Bouw klein voorstation 'Amerpoort' begonnen
« Reactie #270 Gepost op: 11 November 2008, 17:45:38 »
Ik ben benieuwd. Maak je die seinen zelf of koop je die?
Remco.
« Reactie #271 Gepost op: 11 November 2008, 17:51:25 »
Nee ik heb er over gesproken met Chris en Karst en die waren zeer enthousiast over Henckens Seinen dus hiervan ga ik 2 hoofdseinen en 1 dwergsein of 3 hoofdseinen aanschaffen.
Gr Remco
santerdam
« Reactie #272 Gepost op: 11 November 2008, 18:24:24 »
Het ziet er allemaal heel fraai uit, Remco. Zeker een geslaagd project.
Sander
Hookies
    • De bouw van Hookyville in schaal N (updated 25 januari 2010)
« Reactie #273 Gepost op: 11 November 2008, 19:00:43 »
Ik sluit me bij de anderen aan. Dat heb je knap gedaan Remco!
Remco.
« Reactie #274 Gepost op: 11 November 2008, 19:35:53 »
Dank u wel allemaal  :-[
Gr. Remco.
Automatic-rock
  • Impressionistisch Modelbouwer
    • Modelspoor op Automatic-rock.nl
« Reactie #275 Gepost op: 11 November 2008, 20:42:43 »
Goed bezig Remco!!  :)
Vriendelijke groet, Benno
Mijn Brabantse H0 baan in opbouw:Westerweel 1985-1995
Ouderwets leuke & handige modelspoorideeën op: automatic-rock.nl
Machinist Johan
  • gevorderd beginner
« Reactie #276 Gepost op: 11 November 2008, 21:08:51 »
jij bent egt GOED 8)! ik hoop later zelf ook nog zoiets te doen. ziet er bij jou goed uit!
Remco.
« Reactie #277 Gepost op: 11 November 2008, 23:17:00 »
Bedankt maar het is gewoon veel proberen, zoals ik al eerder aangaf, ik probeer eerst alles op een oefenstukje, dan weet je gewoon wat je in het eindproduct moet doen en dat scheelt erg veel teleurstelling of extra werk :)
Gr. Remco.
Remco.
« Reactie #278 Gepost op: 13 November 2008, 21:51:17 »
Eventjes een fotootje van de nieuwe aanwinst en zijn zusjes ;D
Veel kijkplezier!
Gr. Remco.
Tomas131
  • TraXXer
  • Br 146.2
« Reactie #279 Gepost op: 13 November 2008, 21:55:59 »
Mooie baan. Heb je eigenlijk een schaduwstation? En had je niet net zo goed gewone portaalmasten kunnen gebruiken op het station? Maar het is een erg mooie baan, ik denk alleen dat het na een tijdje rijden gaat vervelen als je geen schaduwstation hebt, maar dat is mijn mening.
« Laatst bewerkt op: 13 November 2008, 21:58:13 door Tomas131 »
Project: Rheinland-Pfalz, met rondrijdend spul uit alle Duitstalige landen, Fransen, Belgen, Luxemburgers en wat Hollanders.
Remco.
« Reactie #280 Gepost op: 13 November 2008, 22:00:41 »
Als je de eerste posting in de draad leest zie je het baanplan. Er is dus een schaduwstation. En waarom zou ik normale portalen gebruiken, ik vind T - Portalen mooi. ( En gezien de reacties ben ik niet de enige ;) )
Gr. Remco.
Tomas131
  • TraXXer
  • Br 146.2
« Reactie #281 Gepost op: 14 November 2008, 08:14:28 »
Dan heb ik niks gezegd :) Btw, Die 1100 is erg mooi
« Laatst bewerkt op: 14 November 2008, 08:19:25 door Tomas131 »
Yskonyn
« Reactie #282 Gepost op: 14 November 2008, 12:54:17 »
Heel mooi, Remco!
Aangezien ik ga verhuizen naar Amersfoort heeft deze draad extra interesse gewekt! ;)
Robin
Remco.
« Reactie #283 Gepost op: 14 November 2008, 12:55:35 »
Hahahha ok mooi!
Nou het is een best bergje leesvoer ondertussen dus leef je uit :)
Gr. Remco.
Remco.
« Reactie #284 Gepost op: 14 November 2008, 21:11:40 »
Goedeavond allemaal,
Even eens een ander vraagje wat wel (in)direct met de baan te maken heeft maar niet met de bouw.
Mijn tijdperk is 1980-1995, mijn materieel probeer ik daar zoveel mogelijk op af te stemmen. Ook de stammetjes
probeer ik zo veel mogelijk conform te organiseren.
Dat is soms nog wel eens lastig omdat ik en er gewoon niet zo veel van weet ( Heb eigenlijk pas nu ik met deze baan bezig ben voor het eerst over nagedacht en naar gekeken ) en niet altijd wat over kan vinden.
Maar goed, ik heb nu de volgende samenstellingen bedacht en ben benieuwd in hoeverre het klopt en wat er eventueel nog aan zou moeten veranderen. Als een samenstelling qua tijdperk mogelijk is, dat is het belangrijkste, het leukste is als ik er een correcte samenstelling van kan maken ( Qua nummers zal dat niet lukken maar volgorde misschien wel? ):
Locomotief
Sleep
NS 634Vrij in beweging
NS 1142Nog geen invulling, ik heb ook geen idee wat ik erachter kan hangen
NS 11453 x Plan W ( 453, 461, 514 507) ( Ze moeten nog binnenkomen hoor :) maar zijn besteld )
NS 1211ICR 1e Kl., BKD, 2e kl., 2e kl. ( Deze stam heb ik ergens in het ICR draadje gevonden, ook de volgorde
NS 13095 x Fals-Z Kalk ( Wil ik 8 van maken )
NS 16022 x UDS-Y, 2x Bollenwagon, 2x Ketel DSM, 2 x Ketel Esso (Formeel is de railion trim volgens mij te jong voor mijn TP)
NS 1731Hiervoor is de nieuwe DDM/DD-AR? set van Rivarossi besteld
NS 1823Nog geen invulling ( Valt buiten tijdperk, maar is mijn enige zwakte ;) )
NS 22993 x fccpps ( Wil ik uiteindelijk 8 voor hebben )
NS 2418Bietenwagentjes 3 x
NS 2433VAM Compost 3x, VAM Recycling, VAM Potgrond, VAM 60
Op de bollenwagentjes en de DSM ketelwagentjes na zijn alle nummers uniek, alles wat ik heb is 1:87 ( De enige welke dat niet zal zijn is straks de koploper maar goed daar is niets aan te doen :) ). Verder heb ik nog een Eanos blauw die ik misschien ook nog ergens bij kan plaatsen.
Alvast bedankt voor de info en hulp.
Gr. Remco.
Even een toevoeging:
De maximale lengte van een sleep is zonder loc +- 120 cm.
« Laatst bewerkt op: 15 November 2008, 09:40:59 door Remco »
