Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: On30 diorama: Sedona Red Rock Canyon, AZ  (gelezen 34366 keer)
  • Spoor 0, dat wordt wel wat!
Re: 0n30 diorama: Sedona Verde River Canyon
« Reactie #45 Gepost op: 23 July 2025, 16:19:44 »
laatste update voor de vakantie waarbij de ondergrond steeds meer voltooid raakt:
Alle is ballast aangebracht en een rood/bruine zanderige bodembedekking bij de rest.
Hier en daar nog wat steenslag toegepast uit kattenbakkorrel en rode aarde van RTS.
vr. groet,  Hans
« Reactie #46 Gepost op: 26 July 2025, 14:49:27 »
Zeer fraai,nu al  (y)
  • Modelrailroading is fun!
    • Team USA Metusa Junction
« Reactie #47 Gepost op: 26 July 2025, 17:44:09 »
 (y) (y) (y) (y) (y)
« Reactie #48 Gepost op: 17 August 2025, 21:55:36 »
Met het einde van de vakantie in zicht begint het te kriebelen om de bouwactiviteiten weer op te pakken.
De kleine Gallows draaischijf moest nog afgerond worden. De beplanking van het dek uit balsahout en de tuien compleet gemaakt en de functionaliteit van het geheel getest.
vr. groet,  Hans
« Reactie #49 Gepost op: 18 August 2025, 06:52:24 »
Mooi verweerd hout. Een juweeltje op je baan.
m.v.g.  Frits
« Reactie #50 Gepost op: 18 August 2025, 11:18:48 »
 (y)
« Reactie #51 Gepost op: 13 September 2025, 17:29:25 »
Na het eerste optreden van "Les Billards du Vivarais" bij de Nederlandse smalspoordagen 2 weken geleden, heb ik de draad weer opgepakt bij de Sedona-baan.
Bij de uitbouw aan de voorzijde is een waterpartij is aangebracht.
Een een geprint vissersbootje heeft er zijn plaats gevonden.  :)
vr. groet,  Hans
« Reactie #52 Gepost op: 13 September 2025, 17:47:55 »
Ik vind die golven wat te veel van het goede. ::)
m.v.g.  Frits
« Reactie #53 Gepost op: 14 September 2025, 15:08:02 »
Je hebt gelijk Frits, het is idd te veel. Door de lichtreflectie komt het te sterk over.
Ik heb de witte highlights op de golftoppen verwijderd en nog 2 lagen vernis aangebracht.
de bodemplaat ook dikker gemaakt met XPS. het komt nu massiever over en sluit netjes aan bij de bakken.
vr. groet,  Hans
« Reactie #54 Gepost op: 14 September 2025, 15:12:07 »
Oh, veel beter zo Hans. (y)
m.v.g.  Frits
« Reactie #55 Gepost op: 14 September 2025, 15:34:51 »
Mooi Hans! Alleen..... bij Sedona is geen waterpartij te zien hoor  ;)
« Reactie #56 Gepost op: 14 September 2025, 16:33:05 »
Ik weet het Ronald, alleen een klein stroompje de "Oak Creek" .
maar je moet zaken niet te letterlijk nemen vindt ik maar, dat beperkt de fantasie teveel  ;D
« Laatst bewerkt op: 14 September 2025, 16:38:16 door Hans1963 »
vr. groet,  Hans
« Reactie #57 Gepost op: 14 September 2025, 16:40:39 »
Dat is ook zo, die vrijheid neem ik zelf ook  ;)
« Reactie #58 Gepost op: 14 September 2025, 17:51:52 »
Dus dat 'schip' is ook flauwekul? :o
Niks geen postboot uit de volgende grote plaats dus.
m.v.g.  Frits
« Reactie #59 Gepost op: 14 September 2025, 21:07:38 »
Flauwekul zou ik het niet willen noemen.
Er liggen diverse kleinere meren in de omgeving, maar een postboot is niet aan de orde.
Het wordt dus een kleine vissersboot. Deze is ontstaan door AI in te schakelen.
ChatGPT levert een plaatje door de vraag te stellen een kleine vissersboot uit de jaren 1920 te presenteren.
Tripo3D (o.a.) heeft de mogelijkheid dit om te zetten naar een STL-bestand welke geprint kan worden.
zo kan uit eenvoudige vraag-en-antwoord interactie iets unieks worden ontworpen.
diverse zaken uit de scenery zijn hiermee ontworpen.
vr. groet,  Hans
