Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: hobbytrain 15773 Spoor N  (gelezen 1170 keer)
ca.gorter
    • Modeltrein spoor N
« Gepost op: 23 November 2024, 14:44:36 »
Wie kan mij vertellen hoe ik , zonder hem stuk te maken, kan openen.
Er mist een stroom doorverbinding tussen de twee delen. Art.Nr. 40
Ik wil proberen hier een draadje tussen te maken.
Alvast mijn dank
Kees
ca.gorter
Re: hobbytrain 15773 Spoor N
« Reactie #1 Gepost op: 26 November 2024, 21:00:20 »
NOGMAALS EEN POGING VOOR HELP BIJ HET OPENEN VAN DEZE TREIN.
zie eerdere vraag hierboven.
Alvast mijn dank.
Kees
  • Modelrailroading is fun!
    • Team USA Metusa Junction
« Reactie #2 Gepost op: 26 November 2024, 21:01:51 »
Zo te zien kap gewoon geklemd op het onderstel?
T.Spat
« Reactie #3 Gepost op: 26 November 2024, 21:47:53 »
Misschien meer kans op het N spoorforum?
Ik heb de tekening bestudeerd, maar zie ook niet echt iets van verbindingsschroeven o.i.d
Wel schroef 34 die het onderframe vastklemd...
mogelijk dat als die losgemaakt wordt, dat dan ook de kap makkelijker loskomt..
Succes (y)
« Laatst bewerkt op: 26 November 2024, 21:50:41 door T.Spat »
ca.gorter
« Reactie #4 Gepost op: 27 November 2024, 08:28:46 »
De schroef nr. 34 heb al los gehad, daarmee komen de wielen alleen los.
Ik ga het met de kap spreiden nogmaals proberen.
Dank voor het meedenken.
ca.gorter
« Reactie #5 Gepost op: 27 November 2024, 21:23:19 »
Met veel beleid is het toch gelukt om hem uit elkaar te krijgen.
Als eerste de ramen kanten voorzichtig spreiden.
Daarna de kap naar het front schuiven , de koplichten steken door de kap heen, en optillen.
Het tussenstuk kon voorzichtig los en uit elkaar.
Zie het enige verbindingsstrip tussen de kapjes.
Nu iets aanpassen om de draadjes te kunnen verbinden.
T.Spat
« Reactie #6 Gepost op: 27 November 2024, 22:23:17 »
 (y)
