Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Houtkaai, H0/H0e  (gelezen 21860 keer)
  • Het leven op de weg.
    • Midland
Re: 't Eilandje port 49, HO/HOe
« Reactie #60 Gepost op: 25 April 2024, 12:57:17 »
De inbouwmaat was ook een probleem.
Behalve die wagonschijf heb ik maar 8 cm ruimte op die plek.
Nog ff door prutsen en in nood kan die van Faller erin.
    • Midland
« Reactie #61 Gepost op: 27 April 2024, 19:18:14 »
Vandaag weer beetje kunnen klussen.
De wissels zijn binnengekomen.
Nu gelijk de rails maar precies op maat gemaakt. Er moeten hier en daar nog raillasjes op. En de railsstaaf hier en daar beetje bijwerken.
Voor de draaischijf.
Ben ik over gestapt van bout en moer naar een 360 graden servo SG 90 type. Ik bedacht me: die heb ik nog liggen.
Nu bezig die in te bouwen. Maar waar ik al op gerekend had zit ie iets uit het midden. Het gevolg ervan is dat ik het vastgeschroefd plaatje onder de ring moet gaan vervangen en het gat even goed afmeten voor precieze afstelling op de sporen.
Tijdelijk met nagels vastgezet zodat ik ze nog enigzins kan verleggen.
De servo kan op allerlei manieren aangestuurd.
Daar moet ik ook even naar kijken, analoog of zelfs via wifi.
Miss morgen eventjes.
« Laatst bewerkt op: 28 April 2024, 11:11:20 door NS264. Reden: Tekst. »
    • Midland
« Reactie #62 Gepost op: 21 May 2024, 19:03:18 »
Na, verwoede poging iets te maken wat op een draaischijf lijkt, bleek dat toch wel lastig om dat netjes te krijgen.
Daarom toch wat advies aangenomen daar niet mee verder te gaan en vervolgens het Faller wagondraaischijfje bestelt.
Er speelt ook nog een ander idee mee.
Mijn wens was er om er een railcar of bus bij te nemen maar dat wordt nu een tramstel van Lilliput.
Daarvoor heb ik een deel aangepast maar de bebouwing min of meer in stand gelaten.
De straat is er nog.
De bedoeling is om van de bocht een doorgaande tramlijn te maken naar sporen buiten de kist.
De draaischijf verplaatste ik naar het fabrieksterrein.
De schijf beperkt zich tot vier standen.
Om het dan simpel te kunnen bedienen pas ik verder geen wissels toe behalve het toevoer spoor.
Zit nog wel met het feit dat de wagon ook van de schijf gehaald moet worden.
Wordt dat dan een 2e loc?
Gr. Koen.
  • Michel
  • low-budget modelbouwer
    • Rangeerbanen
« Reactie #63 Gepost op: 21 May 2024, 20:54:44 »
Of met een lier, ook leuk. Zie ook deze video
Dit oogt ook wel weer leuk. Maar neigt meer naar Duits;)
Hans GJ
« Reactie #64 Gepost op: 22 May 2024, 07:42:53 »
Goed idee zo'n tramstel.
In Wallonië reden nog lang trams rond ipv bussen.  Ik denk dat ze pas rond het jaar 2000 stilaan buiten gebruik zijn geraakt.  Niet enkel in de steden, maar ook op het platteland reden toen veel trams.  Zo'n trams werden hier 'boerentrams' genoemd , dus zoek maar eens op flickriver naar dat woord.  Ongetwijfeld vind je er een schat aan leuke inspiratie.
mvg
Hans
Na 25 jaar opnieuw gestart - https://tinyurl.com/yr8c9e84
Project Cherteau - https://tinyurl.com/448tmc8h
Cherteau – klik, kijk, ontdek - https://tinyurl.com/vxaz97xj
    • Midland
« Reactie #65 Gepost op: 30 May 2024, 23:44:14 »
Even een vlug bericht voor de vrijdag.
Ipv een railcar of bus heb ik mijn zinnen gezet op een tramstel.
Een (ik weet niet hoe oud) tramstelletje via MP gescoord. Analoog.
Werking moet nog getest.
Ook bleek het onderstel niet op 009/N spoor bedacht te zijn maar HO.
Dat creërt nog wat hobby uurtjes.
Ook het baan plan volledig aangepast, nu kan het nog. De  Faller draaischijf biedt 4 standen.
Daar valt weinig aan te doen.
Ik heb nu een ster vormige indeling.
De tram slingert nu van links opzij naar de andere kant.
Ook aan het uitvogelen hoe ik de kist modulair ga opstellen
Ws fiddle yards aan 2 kanten voor pendelwerk.
Het trammetje vind ikzelf een erg leuk modelletje😀.
Rustig aan weer door.
Ondertussen is Jacob ook aan de gang!
Gr Koen.
  • Michel
    • Rangeerbanen
« Reactie #66 Gepost op: 30 May 2024, 23:53:32 »
Die slinger naar de achtergrond is ook leuk, Koen!
Daarmee komt het gaatje naar buiten ook wat minder in het zicht.
    • Midland
« Reactie #67 Gepost op: 30 May 2024, 23:57:44 »
Het ziet er dan ook gelijk nauwer uit die tram erdoor.
Maar het is dan ook 'Narrow Gauge' ;D
Gr. Koen.
« Reactie #68 Gepost op: 31 May 2024, 08:59:03 »
Het zou best kunnen dat het trammetje H0m is, dat is 12mm breed spoor. Qua smalspoor zijn er in model (bijna) net zoveel spoorwijdtes als in het echt, ook H0f bestaat nog (6mm, dat is omgerekend 60cm spoor).
Rogier
    • Midland
« Reactie #69 Gepost op: 31 May 2024, 21:58:49 »
Rogier,
Het is van het merk Lilliput.
Gr. Koen.
« Reactie #70 Gepost op: 01 June 2024, 08:38:44 »
Trammetje is h0 en normaalspoor. Model dat in diverse kleurvarianten is uitgebracht door Lilliput.
Het origineel reed dan ook in diverse steden in Duitsland en Oostenrijk. Het is een model van een KSW Kriegsstraßenbahnwagen
DJV
« Reactie #71 Gepost op: 01 June 2024, 18:10:30 »
Nieuw projectje Koen... Beetje aangestoken door de Franse draadjes/topics hier op het forum.??
Groeten Dirk Jan
V100 "manusje van alles".
Noordernet
« Reactie #72 Gepost op: 01 June 2024, 18:15:46 »
Ja, ik kan het thema ook erg waarderen. Succes verder, Koen!
Wolter
    • Midland
« Reactie #73 Gepost op: 01 June 2024, 21:19:57 »
Goedenavond ,
Die baantjes waardeer ik zeer van iedereen.
Ik volgde Michel al vanaf begin hier hadden we een klik.
Zoveel jaar later viel die klik samen op Ontrax.
Daar werd nog meer duidelijk wat je op zo'n baantje allemaal kan doen.
Maarre, wel probleempje,
Marc zegt het zijn Duits/Oostenrijkse trams en ik zit met mijn thema richting België.
Dan voornamelijk het vlakke deel, niet iets specifieks of perse industriegebied.
Er staat overal wel ergens een fabriek of bedrijvigheid.
Verder gewoon een lekker stukje bouwen.
Gr Koen😁
« Reactie #74 Gepost op: 01 June 2024, 22:27:11 »
Het is gewoon een leuk trammetje om te hebben. Als je hem hier niet gebruikt dan later wel es.
de groeten van Jacob
En iets in LGBschaal:
