Vandaag om 00:01:44
Vandaag om 00:00:16
Grasmasters door grove den
16 January 2026, 23:58:20
Liliput NS 3500 - kortsluiting (verholpen?) door prutser
16 January 2026, 23:50:40
Raadplaatje door Hlv53
16 January 2026, 23:46:46
📐 Gezocht: Ontwerper voor Märklin H0 K-rail baan (AnyRail) – digitaal & automat door bask185
16 January 2026, 23:30:50
16 January 2026, 23:29:44
Toon hier je nieuwe (model-) spooraanwinst(en)... door Edsko Hekman
16 January 2026, 23:10:03
Preisertjes(?} in Leeuwarden ? door gdh
16 January 2026, 22:40:26
Rondom Charlois door hervé
16 January 2026, 22:15:44
BNLS modules: de groeten uit Berkel door Ad Cleijsen
16 January 2026, 22:05:18
memling, welke loc? door jarietje
16 January 2026, 21:52:22
16 January 2026, 21:50:30
16 January 2026, 21:43:18
16 January 2026, 21:28:36
Jouef 2026 door Martijn193
16 January 2026, 20:38:23
16 January 2026, 20:17:09
16 January 2026, 19:23:42
16 January 2026, 19:23:33
65 baanplannen door reinderlf
16 January 2026, 18:44:45
16 January 2026, 18:40:24
16 January 2026, 18:07:43
16 January 2026, 18:05:16
16 January 2026, 17:55:13
Wat hing er achter een Blauwe Brabander door Maarten-1-14
16 January 2026, 17:46:49
Roco 2026 door grossraumwagen
16 January 2026, 17:42:38
16 January 2026, 17:40:30
Slijptrein door Rob Ellerman
16 January 2026, 17:28:29
16 January 2026, 16:50:38
16 January 2026, 16:25:25
Auteur Topic: Mijnhout, jouhout.  (gelezen 6644 keer)
sneek
Re: Mijnhout, jouhout.
« Reactie #15 Gepost op: 02 May 2008, 23:56:54 »
Bah, zo'n houtdraad wordt direct doorgezaagd met flauwe grappen :'(
Back to business again:
Hoe vindt je deze voorbeelden Noppie:
Toen Pingel Anton nog smalsporig reed;
http://img182.imageshack.us/img182/4743/aa216hd7.jpg
http://img411.imageshack.us/img411/5159/aa223ac0.jpg
ook in het Ruhrgebied was het te zien:
http://img211.imageshack.us/img211/3221/6574ad2.jpg
kleine info ook op:
http://www.eisenbahnmodelltechnik.de/mr-03810-49.htm
http://www.fh-merseburg.de/~nosske/EpocheII/dv/e2d_3318.html
stig
« Reactie #16 Gepost op: 03 May 2008, 00:12:31 »
Geweldig die laatste link!
Han Zijlstra
    • Trainspecials
« Reactie #17 Gepost op: 30 May 2008, 11:15:20 »
Ik heb iets vergelijkbaars gemaakt voor mijn fleischmann wagentjes.
Maar ik werd er helemaal gallisch van als zo'n bak ontspoorde. overal houtjes.
Wat heb ik dus gedaan? Een papieren bakje gemaakt dat precies in een wagon past. Vervolgens houtjes geknipt, Lijmpistool gepakt en het bakje deels gevuld , Houtjes erin geduwd net zolang tot ze mooi in het gelid staan. Je krijg dan een mooi blokje aan de onderkant wat zo in de wagon geplaatst kan worden.
Noppie.
  • Rock and roll is better than music.
« Reactie #18 Gepost op: 30 May 2008, 12:23:02 »
Han.
Mooie plossing geef je aan. Ik heb ze een tijdje geleden in die kolebak gevrot en ges what... ???  De boomstammen zijn nu uitgedroogd en gekrompen. :'( Ze rammelen van alle kanten in die bak. De struik is inmiddels compost en ik zal dus iets anders er bij moeten zoeken en bijvullen tot het geheel weer vol is..... soms.....
Maar eens in de buurt goed rond kijken om iets te snoeien.
Goed weekend,
Noppie.
A world without heroes, Is like a world without sun, You can't look up to anyone, Without heroes.
Han Zijlstra
    • Trainspecials
« Reactie #19 Gepost op: 30 May 2008, 13:39:13 »
Nog een truukje om hout rot te voorkomen.
Op het moment dat je een struik snoeit zit er altijd nog wat water in het hout. Dit kun je met behulp van de magnetron er uit krijgen. Even expirimenteren met de tijd 20 sec. 30 sec. en je houtjes worden kurkdroog.
Op dezelfde manier kun je fraaie boomstammen maken. neem een wat dikkere tak (2 cm doorsnee) en stop die ook in de magnetron. duurt iets langer maar resultaat is ook mooi. De grap is dat de kern van de tak sneller krimpt dan de buitenkant en je dus een mooie gegroefde buitenbast krijgt. Wel even opletten dat het hout niet spontaan gaat branden.
Noppie.
« Reactie #20 Gepost op: 30 May 2008, 14:05:58 »
Sound like a very plan. Nu de magneteron nog ::)
Maar in de oven kan het misschien ook wel.
Noppie.
  • Modelrailroading is fun!
    • Team USA Metusa Junction
« Reactie #21 Gepost op: 30 May 2008, 15:52:43 »
Normaal kan natuurlijk materiaal ook in een oven gedaan worden, het gaat er alleen om om de micro-organismen te doden. Ikzelf gebruik de combi magnetron voor zand-uit-het-bos en takjes, maar ook daar gaat de zaak op ovenstand. Een minuut of 10-15 op een 150 graden zou genoeg moeten zijn.
Grzt,  8) Ronald 8)
RJ
« Reactie #22 Gepost op: 06 June 2008, 23:36:43 »
Toevallig via het kolentreinen topic gevonden:
Klik
Klik
Hansepansje
    • Perrongeluk - van de regen uit de drup
« Reactie #23 Gepost op: 07 June 2008, 10:02:44 »
En mocht je een laad-/losplaats voor hout willen maken, dan kun je op onderstaande foto zien wat een lekkere bende het daar kan zijn.
Foto gemaakt in Duitsland, Limburg a/d Lahn, 18 april 2006.
Groets, Hans
Dachbodenheim: N-spoor, Fleischmann Piccolo, HCCM elektronica, eigen software
  • Spoor-0 & Spoor-1
    • Modeltreinbaan.nl
« Reactie #24 Gepost op: 20 June 2008, 10:26:00 »
Door dit draadje ook maar eens aan het "houten" geweest.
Best een riskante hobby eigenlijk..... :'(  ;D
JanPieter
  • Treinspotten.nl
    • Treinspotten.nl
« Reactie #25 Gepost op: 20 June 2008, 13:40:40 »
Leuk draadje :D.
'k Ben van plan een setje rongenwagens te gaan aanschaffen, daarin kan ik dan ook boomstammetjes stoppen.
Met vriendelijke groeten,
Jan-Pieter
