Molenbaan (werktitel)
sdz1976
om 00:19:12
01 February 2026, 23:44:43
Hout realistisch nabootsen
01 February 2026, 23:41:08
01 February 2026, 23:36:40
01 February 2026, 23:14:29
NMJ 2026
Dion
01 February 2026, 23:09:08
01 February 2026, 23:00:46
01 February 2026, 22:43:44
01 February 2026, 22:34:40
reinderlf
01 February 2026, 22:18:42
BR01 van Roco verfraaien.
01 February 2026, 22:09:34
01 February 2026, 21:57:01
Z21
Caspar25
01 February 2026, 21:42:39
Eindstation Daarhuizen
HenkN
01 February 2026, 21:41:32
T.Spat
01 February 2026, 21:38:17
Armita Wagons Amsterdam bv Tds
T.Spat
01 February 2026, 21:34:49
The Summer of 69
01 February 2026, 20:50:28
Inrijbaan 240x120cm
BramFokke
01 February 2026, 20:46:20
01 February 2026, 20:25:59
01 February 2026, 20:18:11
01 February 2026, 20:03:16
De donkere blauwe blokkendozen
01 February 2026, 19:15:05
01 February 2026, 18:49:40
ik kom er niet uit met de esu in de bigboy solderen
01 February 2026, 18:45:59
jack is back
01 February 2026, 18:19:43
Ronald A.
01 February 2026, 17:53:38
01 February 2026, 17:53:34
01 February 2026, 17:45:29
Traintastic - modelbaan besturingssoftware (gratis en open source)
reinderlf
01 February 2026, 17:20:06
reinderlf
01 February 2026, 16:27:08
Ronald gaat Duits met Johanneshausen!
Topic: Ronald gaat Duits met Johanneshausen! (gelezen 71174 keer)
Modelrailroading is fun!
Re: Ronald gaat vreemd! En bouwt een keertje Duits :)
Reactie #225 Gepost op:
13 May 2023, 23:05:33 »
Ok, mijn mittelwagen is er! Met dank aan forumgenoot Roy. Hartstikke bedankt man!!:
20230513_223357
by
, on Flickr
20230513_223407
by
, on Flickr
En dan met de andere nieuwe set samen, kijk zo hoort het
20230513_223603
by
, on Flickr
Wel even onder wat vals kamerlicht maar ik ben er heel erg blij mee. Dus snel even op de plaat gezet
Roy van Dijk
Reactie #226 Gepost op:
13 May 2023, 23:28:04 »
Mooi setje bij elkaar zo, nogmaals graag gedaan
Reactie #227 Gepost op:
13 May 2023, 23:46:19 »
NS tijdperk II(c)/III
Reactie #228 Gepost op:
14 May 2023, 07:14:00 »
Mooi setje zo bij elkaar
Fotodijkje en fotodiorama
Obdam
cor_b
at ,t moar exact 1:87 is
Doornvliet CS 1975 t/m 1995
Reactie #229 Gepost op:
14 May 2023, 08:50:41 »
Toch wat anders dan het brute USA geweld
Cor
Gerard van de Weijer
Reactie #230 Gepost op:
14 May 2023, 09:13:56 »
Citaat van: cor_b op 14 May 2023, 08:50:41
Cor
Wacht maar op het geluid!!!!
Reactie #231 Gepost op:
14 May 2023, 10:07:03 »
Deze zijn ohne sound
Edsko Hekman
Nooit uitgeklust....
Reactie #232 Gepost op:
14 May 2023, 11:13:42 »
Maar dat kun je veranderen Ronald!
Grasland
Reactie #233 Gepost op:
14 May 2023, 11:18:21 »
Zeker Edsko maar opgeteld springt dat het budget behoorlijk.... en dat word mij dan iets te gek. Een baantje zonder sound is dan een betere optie financieel gezien
Ok, had de Noch lasercut brug gekocht. Deze vanmorgen eens even uitgepakt om deze te bestuderen. moet zeggen dat ik wel onder de indruk ben. Wist van vriend Ronald Koerts (van RK products) al wel dat lasercut heel interessant is.
De brug is dacht ik door de Duitse firma Joswood geproduceerd. Het karton is redelijk stevig en voelt goed aan. Dichterbij bekeken ziet het er ook goed gedetailleerd uit. Uit de bouwtekening blijkt dat alles dan ook dubbel gemaakt is zodat je aan beide kanten de details zoals de klinknagels hebt. Dat zal hem uiteindelijk ook stevig maken.
De kit bestaat uit 6 grote "rekken" en 2 kleinere met daarin de verstevigingshoeken. Daarnaast 2 foam brughoofden en een duidelijke beschrijving die de delen goed identificeert en duidelijk laat zien hoe e.e.a. in elkaar gaat. Het is geen grote brug, lengte is 18 cm. Dus dat moet niet moeilijk zijn toch?
Fotoosch; de 6 grote rekken:
20230514_101814
by
, on Flickr
20230514_101930
by
, on Flickr
Ook een smal "rekje" met de fineer looppaden voor op de brug.
Detail is zeker goed te noemen:
20230514_101837
by
, on Flickr
De verstevigingen:
20230514_101724 1
by
, on Flickr
Ook hier mooi detail:
20230514_101730
by
, on Flickr
Heb hier wel zin in moet ik zeggen. Gevraagd om advies en een ieder geeft aan; eerst bouwen en dan verweren/spuiten/lakken naar behoefte. Gaan we dan ook doen. Uiteraard gaan dan de loopplanken er als laatste op.
Nog even een statieportret met beter licht, ik kon het niet laten. Beide sets nu + de stuurwagen die over is:
20230514_105529
by
, on Flickr
20230514_105539
by
, on Flickr
Tevreden mee, als ik het doe doe ik het goed!
Nu aan het turven wat ik nog nodig heb aan decoders, railmateriaal etc. Is overzienbaar, rechts wissel al van Ronald gekregen en de 3-weg moet ik even bestellen net als 2 functiedecoders. Ik doe het met de bussen als volgt:
- Mijn eerste set koppel ik permanent met een vaste doorvoer tussen de wagens. De stuurwagen zal dan vanuit de decoder qua verlichting aangestuurd worden en de stroomafname volgt dan op alle 4 assen van beide wagens.
- Van de 2e 3-set zal de motorwagen de decoder krijgen. De midden- en stuurwagen koppel ik vast en die krijgen een gezamenlijke functiedecoder. Tussen motorwagen en die 2-set komt dan de Viessmann 2-polige koppeling (die ik al aangeschaft had lang geleden) zodat ik de motorwagen nog af kan koppelen en dan als PmG kan gebruiken. Aan de kop zou dan de gangbare koppeling moeten komen die ik ga gebruiken op al het materieel, maar daar ben ik nog niet over uit. De Fleischmann is betrouwbaar maar wel lomp. De Roco oud vind ik niet echt wat en die nieuw beugelachtige dan weer wel. Adviezen hierin zijn welkom, wel rekening houdend met het feit dat er ook wat oudere wagens bij zitten die GEEN Nem schacht hebben.
Zo, weer bijgepraat! Straks nog werken voor een baas en komende dagen toch die brug maar even bouwen
Later!
Reactie #234 Gepost op:
14 May 2023, 11:50:24 »
Citaat van: Ronald Halma op 14 May 2023, 10:07:03
Deze bewegende (voor)beelden mét (01:00)
https://www.youtube.com/v/jJbpQu8uUUc
Niet helemaal correct qua tijdperk, maar een kniesoor ...
Obdam
Reactie #235 Gepost op:
14 May 2023, 11:54:26 »
Die dingen gaan nog vet hard!
Reactie #236 Gepost op:
14 May 2023, 12:07:58 »
Vmax. 90 km/h
Qua achterliggende gedachtegang zijn ze prima te vergelijken met de Nederlandse DE1 en DE2 stellen van Allan.
Lichte treinstellen om de exploitatie van nevenlijnen nog enigszins betaalbaar te houden.
Obdam
Reactie #237 Gepost op:
14 May 2023, 12:11:40 »
Jammer,
je weet dat Gerbrand op Blue Ridge&Western een Doodlebug had rijden, onze eerste test met geluid was deze Doodlebug met het geluid van de Schienenbus, geweld hoor
Reactie #238 Gepost op:
14 May 2023, 12:30:37 »
Ja, ik ken het geluid.... heb een Goose in 0N30 met net zo'n mooi geluid. Op dit baantje hakt sound er wel in... mmm.... verdorie, rotjongens zijn jullie!
Edsko Hekman
Reactie #239 Gepost op:
14 May 2023, 14:44:56 »
We want sound, we want sound!!
Grasland
