Vandaag om 00:16:59
Welke centrale is betrouwbaar? door Michiel VL
Vandaag om 00:08:33
Vandaag om 00:05:01
Ondergrond modelspoorbaan door HenkN
25 January 2026, 23:34:12
Faller 2026 door Floris Dilz
25 January 2026, 23:33:48
24 en 25 Januari 2026 modelspoorweekend Ewijk door neudalhausenstadbahn
25 January 2026, 23:25:04
25 January 2026, 23:21:42
Au bord de la Cèze door WimNa
25 January 2026, 23:18:06
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door NTeering
25 January 2026, 23:04:06
25 January 2026, 22:23:42
Länderbahn en Reichsbahn locomotieven. door wob
25 January 2026, 22:17:45
Toon hier je nieuwe (model-) spooraanwinst(en)... door 1200blauw
25 January 2026, 22:01:06
Toon hier je (model)TRAM foto's. door Charles_
25 January 2026, 22:00:08
Interesse stamtafel/club Amersfoort? door Sikko
25 January 2026, 21:56:58
25 January 2026, 21:46:52
Bruine NS 1200s - Treinsamenstellingen. door Vislijn
25 January 2026, 21:27:45
Zaterdag, 31 januari 2026 | 8e Ruilbeurs MSV Post B door Carl
25 January 2026, 21:27:21
25 January 2026, 21:11:21
25 January 2026, 21:03:30
Molenbaan (werktitel) door Marty
25 January 2026, 20:56:36
Modelbaan in schaal N - 520x80cm - schaduwstation door 1op160
25 January 2026, 20:56:17
Wissels omzetten met luchtdruk door Hans van de Burgt
25 January 2026, 20:55:54
25 January 2026, 20:42:00
Altbau e-loc BR163 zelfbouwen in H0 door Quinzeedied
25 January 2026, 20:31:37
Kortsluiting. Maar waarom dan toch? door puntenglijder
25 January 2026, 20:30:51
Oudere Marklin S3/6 opleuken door puntenglijder
25 January 2026, 20:27:23
25 January 2026, 20:22:14
Retrobahn goes to the States: Bergamot Creek door Frits C
25 January 2026, 20:15:02
Modelspoorfans in Amersfoort gezocht! door Martijnstein
25 January 2026, 20:03:36
De Oosthoek (lokaalspoorlijn periode III, diesel) door Ronald Halma
25 January 2026, 19:50:32
Auteur Topic: NS-200 Sik. Bouwproject in Spoor- 0 en Spoor-1.  (gelezen 83958 keer)
  • Team Mitropa
Re: NS-200 Sik. Bouwproject in Spoor- 0 en Spoor-1.
« Reactie #240 Gepost op: 25 October 2023, 23:36:29 »
 ;D (y)
becasse
  • http://becasse-weathering.blogspot.nl/
« Reactie #241 Gepost op: 26 October 2023, 08:28:48 »
Ja, ho…..€40,-…. Daar maak ik bezwaar. Ik tel ook de giga collectie gereedschappen er bij….walsen, knipmachien, frees en draaibank, straalcabine, boortjes en een enorme voorraad messing….niks geen keukentafelprojectje Frits!
Waar gaan we heen voor spoor 1?
    • nulpunt
« Reactie #242 Gepost op: 26 October 2023, 11:39:31 »
@ Michiel,
Waar haal je als hobbyist die onzin vandaan?
Moet ik dan ook de onkosten voor verwarming en electra  in mijn werkruimte gaan meerekenen?
Moet ik dan ook kosten gaan berekenen als ik de huif voor toekomstige bouwers ga buigen?
Moet ik dan ook kosten gaan berekenen als ik het gebouwde model voor iemand ga zandstralen?
Moet ik dan ook. enz. enz.
Als bouwer heb je een boormachine, heb je een tang, heb je een soldeerbout, heb je soldeer of 10-secondenlijm enz. enz.
Een draai/freesbank heb je voor dit model NIET nodig.
Een wals heb je voor dit model NIET nodig De buigmal is al gemaakt.
Een knipmachine heb je NIET nodig. Daarvoor heb je een boormachine met slijpschijfjes.
Een straalcabine heb je NIET nodig. Dat kan ook met schuurmiddel en een oude tandenborstel
Wat je WEL nodig hebt is een keukentafel, plaat messing (20x30cm bij Conrad of de etsplaat), wat profieltjes en boutjes/moertjes (GHW/Knupfer) en wat gietdelen (Shapeways) maar vooral de "wil" om een zelf een Nederlands Spoor-1 model te maken waar buitenlandse fabrikanten zich kennelijk niet aan wagen.
Heb je de doelstelling van het project wel begrepen: Zo goedkoop mogelijk een Nederlands model (in vele varianten) in Spoor-1 ontwikkelen wat er perfect uit ziet.
Ok, ik begrijp het. Jij wilt het model, in tegenstelling tot eerdere mededelingen, dus toch niet gaan bouwen. Het zij zo, maar zeg dat dan openlijk.
Ik ga gewoon door met het bouwen en laten zien wat er allemaal bij komt kijken om een dergelijk model tot in de puntjes te ontwerpen en daar zijn vele volgers van dit verhaal iedere dag weer blij mee.
16630
« Laatst bewerkt op: 26 October 2023, 12:00:00 door FritsT »
    • nulpunt
« Reactie #243 Gepost op: 26 October 2023, 11:49:29 »
Dat is snel.....
becasse
« Reactie #244 Gepost op: 26 October 2023, 12:58:39 »
Frits,
je hebt me helemaal verkeerd begrepen. Ik volg je draadje met veel plezier en ben onder de indruk van je kunnen. Ik wil zeker een sik, heb net zelfs hierover een leuk artikeltje geschreven dat ik wilde publiceren. Ik heb ontzettend veel plezier beleefd aan de oersik, die ik nooit zo goed in elkaar had kunnen bouwen zonder jouw hulp en jouw goed geoutilleerde werkplaats.
Ik durf het zeker aan om de sik te bouwen, heb jou en Edwin zelfs nog gepusht. Dus voor mij meer dan 1 misschien zelfs wel. Want geel/ grijs is ook leuk.
Ik zal het wel verder uit mijn hoofd laten om commentaar te schrijven, omdat dit verkeerd opgevat zou kunnen worden  ;)
Jammer dat het nou niet meer zo gezellig voor mij is hier maar ik heb veel eelt op mijn ziel. Dus blijf je gewoon volgen.
Michiel
    • nulpunt
« Reactie #245 Gepost op: 26 October 2023, 14:08:56 »
 (y)
    • nulpunt
« Reactie #246 Gepost op: 26 October 2023, 15:02:41 »
Met de samenstelling van de van de roosters aan de zijkant van de huif, bij verschillende loc-varianten, kunnen we alle kanten op.
De luiken komen OP de huif te liggen tussen 2 horizontale strips. Strips zijn 0,5mm dik en de print/gietdelen 0,6 mm (zonder nog enige mate van krimp bij het messing). Die 0,05-0,1 mm verschil ga je waarschijnlijk niet zien en het is natuurlijk altijd mogelijk om er een vijl langs te halen.
Scharnieren worden als etsdeel gemaakt.
Voor de positionering van de handgrepen zitten er boorgaatjes in het ontwerp.
1. Oersversie:
 -3 kleine luiken aan iedere kant.
2. Latere versie
 -1 klein luik en 2 grote luiken aan iedere kant.
Ik heb zojuist een testbestelling gedaan. Zowel in FDP/clear en messing om kosten (factor 4-5) versus kwaliteit te kunnen beoordelen.
Bewust ook nog geen rekening gehouden met de krimp van het messing zodat we daarop een correctiefactor kunnen loslaten.
16720
« Laatst bewerkt op: 26 October 2023, 15:06:23 door FritsT »
    • nulpunt
« Reactie #247 Gepost op: 26 October 2023, 19:03:23 »
Voordat ik me ga verliezen aan teveel detailwerk, ga ik nu het 2e handmonster maken.
De eerste aanpassing is het frame inkorten zodat het TT_profiel niet uitsteekt.
Dan kan het frame in elkaar worden gezet.
Voor de zijdelingse afstandsmaat gebruik ik nu niet een stukje aluminium-strip  (2e aanpassing) maar een 3,0 mm profiel. Dat zou dus iets mee gesoldeerd kunnen worden, maar is wel kaarsrecht.
10x nameten op haaksheid en alle voetjes op de vloer ?
Maar toen stond het 2e frame op  tafel.
16781
« Laatst bewerkt op: 26 October 2023, 19:06:31 door FritsT »
    • nulpunt
« Reactie #248 Gepost op: 27 October 2023, 16:11:02 »
De test-HIAB is binnen.
Buis 1 is apart en buis 2 en 3 zijn samengevoegd en moeten dus van elkaar losgesneden worden.
Hoe diep zit de kleurstof? Zoals Mitchell al zei, die laag is heel dun. Is dat een ramp? Nee.
We hadden de ruimte tussen de buizen krap gehouden. Eerder bang voor rammelende buizen dan vastzittende buizen. Dat bleek dus zo te zijn. Er moest toch heel wat worden gevijld en dat bleek met dit materiaal niet mee te vallen. Breekbaar is het niet maar vijlbaar...tja. Het is eerder elastisch en onhandelbaar. Maar de aanhouder wint na een half uurtje vijlen en schrapen schoof alles in en uit elkaar, maar het geel is wel weg. :( Gelukkig heb ik een bijpassende gele kleurstift  ;D die in 3-4 lagen goed overeen gaat komen.
Metalen buis 2 mm aan buis-2 vast en schuifbaar in de cyinder. Draad 1 mm aan buis-3 vast. Elastisch draad (oprolbaar om een zelf gedraad messing wieltje aan de achterkant) en katrol en hijshaken van Knupfer.
Test GESLAAGD(y) (y) (y) (y) (y) (y) :D :D :D :D :D :D ik ben dus heeeeeeeeel erg blij met dit resultaat.
Volgende stap is het verkleinen van buis 2 (midden) en 3 (eind) zodat er niet gevijld hoeft te worden en de gele kleur gehandhaafd blijft en de dan buizen even opnieuw bestellen.
Ik overweeg nu ook om de geprinte katrollen te vervangen door messing exemplaren.
Ik heb nu ook er het volste vertrouwen in dat de hele kraan gaat lukken, dus daar gaan we komende week aan werken.
16959
« Laatst bewerkt op: 27 October 2023, 16:18:05 door FritsT »
MB6400
« Reactie #249 Gepost op: 27 October 2023, 16:56:18 »
De voortgang zit er goed in Frits  (y)
Ook de kraan ziet er inderdaad ook al goed uit.  En als het lukt, zou ik zeker kijken naar losse (messing) katrollen.
Voor mij tzt waarschijnlijk ook zeker 2 sikjes, één met en één zonder kraan.
    • nulpunt
« Reactie #250 Gepost op: 27 October 2023, 17:37:08 »
 (y)
    • nulpunt
« Reactie #251 Gepost op: 27 October 2023, 19:20:20 »
Shapeways heeft de radiateur, met zichtbare lamellen, in FDP/Clear geprint. Dat staat gelijmd op een blokje messing dat op zijn beurt met 2 stuks M1,4 boutjes aan de voetplaat vast zit.
Bovenop de huif komt nog een gat 2,5 mm waardoor de radiateur, via de vuldop, kan worden bijgevuld. Vaak zie je bij 1:1 over dat gat een rechthoekig afdekplaatje zitten.
    • nulpunt
« Reactie #252 Gepost op: 28 October 2023, 12:14:59 »
De eerste contouren.
17150
« Laatst bewerkt op: 28 October 2023, 12:42:14 door FritsT »
becasse
« Reactie #253 Gepost op: 28 October 2023, 18:19:56 »
Ik heb jullie deelname aan het 01TREFF even internationaal onder de aandacht gebracht, in het zonnetje gezet zeg maar…
Omdat jij mijn zonnestraaltje bent Frits  :laugh:
(En uiteraard ook om het 01TREFF te promoten natuurlijk)
https://s1gf.de/index.php?page=Thread&threadID=39884
Laat die Duitsers maar eens een p0@pie ruiken…of soldeerdampen eerder. Die spoor 1ers kennen dit nog niet.
Michiel
    • nulpunt
« Reactie #254 Gepost op: 29 October 2023, 19:09:10 »
Deze mutatie had ik al aangekondigd.
Het verticale deel van de steunen voor de treeplanken vergroten van 4 naar 5 mm en de steunen 1 mm onder de frameplaat laten uitsteken.
Ook iets ruimte (circa 1 mm) tussen de afsluitplaat en de steun en  niet strak er tegenaan zodat de rand van de treeplank er tussen past.
17480
« Laatst bewerkt op: 29 October 2023, 19:12:54 door FritsT »
