Spoorwegmuseum in zwaar weer door tinus
Vandaag om 01:09:59
12 February 2026, 23:41:19
12 February 2026, 22:30:31
12 February 2026, 22:25:10
Spotten in Sloehaven en Zeeuws Vlaanderen door Huibert
12 February 2026, 22:11:03
Lok adres programmeren lukt niet met multimaus door Cegielski
12 February 2026, 22:02:11
12 February 2026, 21:55:06
Stub switches door Klaas Zondervan
12 February 2026, 21:28:45
12 February 2026, 21:15:21
RailBOX Accessoire Decoder RB4400 door Steven Loosman
12 February 2026, 21:15:20
Traincontroller software gaat stoppen. door reinderlf
12 February 2026, 21:12:47
12 February 2026, 21:09:20
Bediening OOC terminal Oss door timtrein
12 February 2026, 19:50:02
12 February 2026, 19:42:24
12 February 2026, 18:50:46
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robkop
12 February 2026, 18:42:35
Roco 70788 2400 met Zimo MX645 acceleratie settings door Steven Loosman
12 February 2026, 18:12:17
Station Weesp door virmfan
12 February 2026, 18:05:15
12 February 2026, 18:01:04
Voordelige treinkaartjes door Quinzeedied
12 February 2026, 18:00:49
12 February 2026, 17:46:46
12 February 2026, 17:29:22
12 February 2026, 17:18:29
12 February 2026, 17:03:17
4 april Het Stoomgenootschap naar Köln door Seinhuis
12 February 2026, 16:55:32
Minstens 5 jaar geen treinverkeer Groningen-Leer [D] door Noordster
12 February 2026, 16:51:57
12 February 2026, 16:42:09
Spoor vernieuwing Oisterwijk door Charles_
12 February 2026, 16:42:05
Nederlands-materieel in Spoor-1 door FritsT
12 February 2026, 16:41:07
Spoor vernieuwing Oisterwijk door Daan Knoben
12 February 2026, 16:25:59
Poll
Heeft u interesse in een buffet of restauratie rijtuig zoals hieronder gepresenteerd ?
a)    Buffetrijtuig bruin/beige (1977-1982) in lengteschaal 1:93,5 (l.o.b. 282 mm)
2 (2.7%)
b)    Buffetrijtuig geel/blauw (1982-1994) in lengteschaal 1:93,5 (l.o.b. 282 mm)
8 (10.7%)
c)    Restauratierijtuig geel/blauw (1981-1991) in lengteschaal 1:93,5 (l.o.b. 282 mm)
7 (9.3%)
d)    Buffetrijtuig bruin/beige (1977-1982) in lengteschaal 1:87 (l.o.b. 303 mm)
11 (14.7%)
e)    Buffetrijtuig geel/blauw (1982-1994) in lengteschaal 1:87 (l.o.b. 303 mm)
26 (34.7%)
f)    Restauratierijtuig geel/blauw (1981-1991) in lengteschaal 1:87 (l.o.b. 303 mm)
21 (28%)
Totaal aantal stemmen: 42
Auteur Topic: Herziene Beneluxactie nr. 3: Buffet en Restauratierijtuigen  (gelezen 137434 keer)
Buffetkat
Re: Herziene Beneluxactie nr. 3: Buffet en Restauratierijtuigen
« Reactie #210 Gepost op: 29 December 2008, 09:34:10 »
Het is weer fraai Ceesmeneer! :-*
Dit apparaat is zelfs een keer door de NS voor een paar dagen gehuurd i.v.m. een tekort aan rijvaardige buffetwagens (ca. 1997). Het is de ex-007 van de NS/Biljettencentrale.
Alleen van de bruin/beige variant (dit is namelijk de 007) uit mijn stal is deze dus te maken, de blauw/gele 003 heeft een andere indeling. Dus... weet wat u doet, weet wat u besteld heeft! ;D
Buffetkat
« Reactie #211 Gepost op: 01 January 2009, 22:17:21 »
Hoewel er al een enkele wagens zijn uitgeleverd nu dan plaatjes van de 1:93,5-rijtuigen.
Het restauratierijtuig.
Ten opzichte van eerder gebouwde rijtuigen (ik doel op modellen van voor de Beneluxactie) zijn met name bij het restauratierijtuig verbeteringen aangebracht:
-klein deel van de schortbeplating is aangebracht
-keuken met halfgeblindeerde ramen
-interieur
-afwijkende venttilatoren
-rooster onder één der keukenramen
Blik op het interieur met de lampen op de tafel.
Het dakrooster op de Buffetwagen is gemaakt door Kees-jan, evenals het rooster onder het keukenraam van het restauratierijtuig.
In de gele buffetwagen 003 zijn duidelijk de bar met de krukken te zien.
De reden dat deze in de bruin/beige wagen minder goed te zien zijn zit hem in het verschil qua indeling van de rijtuigen 003 en 007.
Ook de gangzijde van beide wagens is verschillend:
Fred van E
  • dus!!........... zodoende
« Reactie #212 Gepost op: 13 January 2009, 23:16:45 »
Is een buffetkat hetzelfde als een kroegtijger?  ;D
Hoe dan ook kan je laten weten hoeveel rijtuigen je al afgeleverd hebt?
Ik heb beide wagens besteld 1:87 en kan zo langzamerhand niet meer wachten.
Fred
Buffetkat
« Reactie #213 Gepost op: 18 January 2009, 20:00:51 »
Het zal toch moeten want de thans ingeslagen weg stemt mij het meest tevreden want de klanten die hun bestelling hebben ontvangen zijn tevreden. Kwaliteit boven snelheid. Ook aan de poort wordt er streng gecontroleerd of iets afgeleverd wordt of niet. Aan de hoeveelheid wagens is nu nog niets af te lezen, ik zit nog in de aanloopfase waarin ik nog wel eens iets anders uitprobeer. Vanaf maart gaat de routine er in zitten, de oude 1:87-wagens zijn dan op en ga ik aan de nieuwe Roco 45862/63 beginnen. Ik hoop dan ook de meeste Flm 1:93,5 afgeleverd te hebben zodat ik mij kan concentreren op het 1:87-rijtuig. Dit jaar moet iedereen zijn bestelling wel binnen hebben, en dat kan als er geen rare dingen gebeuren. Uw Buffetkat werkt minimaal 10 uur per week aan dit project om de gang er in te houden. In de loop van maart  komt er een uitgebreide nieuwsbrief in PDF-bestand beschikbaar waar enigszins de te verwachten levertermijn uit af te lezen is.
Bonke Billie... Bonke Billie... staat niet op de kaart...
    • sleutelspoor
« Reactie #214 Gepost op: 18 January 2009, 20:46:06 »
is er nog een leven naast het spoor  :P
Arnold
« Reactie #215 Gepost op: 18 January 2009, 21:07:41 »
Laat de buffetkat maar rustig spinnen...
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #216 Gepost op: 18 January 2009, 21:21:58 »
Nauwelijks  ::) ::)
Mvg
Wim.
Rijtuigpaint
« Reactie #217 Gepost op: 19 January 2009, 22:17:59 »
Fraai Frank!
doe het je Niet Na.
Buffetkat
« Reactie #218 Gepost op: 16 March 2009, 11:37:26 »
Tijd voor wat mededelingen:
Komende weken worden deze
12 rijtuigen omgebouwd om op 11 april te Houten te worden uitgeleverd.
De volgende klanten kunnen, indien aanwezig, dan hun bestelling afhalen:
1:87
15009
17010
53002
17014
1:93,5
94017
14022
52001
66029
51055
Dit is slechts een voorbode van wat komen gaat: 30 mei wordt een massale uitlevering verwacht die zijn schaduw nu reeds vooruitwerpt met de bestelling van 40x Roco 45866/67. We hebben er zin in! :-*
Rijtuigpaint
« Reactie #219 Gepost op: 16 March 2009, 12:07:18 »
Dranghekken gaan we maar plaatsen denk ik Frank..............mede ook door mijn uitlevering op die dagen.
(Massale vechtpartijen en verdrukkingen tijdens modelbouw beurs in Houten bron ANP)
Buffetkat
« Reactie #220 Gepost op: 16 March 2009, 12:11:59 »
Toestanden!
we nemen de achterdeur ;D
Dennis
« Reactie #221 Gepost op: 16 March 2009, 13:00:26 »
Je kan beter via de keuken lopen, neem ik meteen een keukendeel over ;D
Grts,
Dennis
Kabouter
« Reactie #222 Gepost op: 16 March 2009, 15:29:13 »
Op 11 april zal ik er zijn o spinnende kater    (y)
Groet
94017  ;D
Christoph
    • Zwetdorf in model
« Reactie #223 Gepost op: 16 March 2009, 16:55:32 »
 (y) ben ik blij dat die achterdeur ook te vinden is.  ;D
Nee, mijn bestel nummer staat er nog niet bij. Kan haast niet meer wachten.
Christoph
Buffetkat
« Reactie #224 Gepost op: 22 March 2009, 19:32:25 »
Vandaag zowaar wat nuttigs gedaan:
De rijtuigen voor de bestellingen 94017, 14022, 52001 en 66029 dichtgemaakt.
