Vandaag om 00:48:20
Vandaag om 00:42:51
Vandaag om 00:15:48
13 February 2026, 23:59:24
PB Models, ICR-rijtuigen door MarkSpoor
13 February 2026, 23:57:00
13 February 2026, 23:55:09
13 February 2026, 23:30:44
13 February 2026, 23:08:59
Spoorwegmuseum in zwaar weer door Ferdinand Bogman
13 February 2026, 23:07:10
13 February 2026, 23:03:50
13 February 2026, 22:58:20
13 February 2026, 22:49:17
Roco 63421, hoe kom ik bij de stroomafname lipjes? door Albert de Heer
13 February 2026, 22:38:18
PT Trains 2026 door Chris Westerduin
13 February 2026, 22:10:50
Stub switches door Frank 123
13 February 2026, 21:50:55
13 February 2026, 21:49:12
13 February 2026, 21:41:19
13 February 2026, 21:24:24
13 February 2026, 21:13:45
13 February 2026, 20:31:01
Euronight 295 samenstelling door EN446
13 February 2026, 20:29:30
13 February 2026, 20:05:35
RailBOX Accessoire Decoder RB4400 door Etsmodelspoor.nl / Modelspoorbaanwinkel.nl
13 February 2026, 19:47:25
13 February 2026, 19:33:16
US diorama in H0 door Eric B
13 February 2026, 19:23:39
13 February 2026, 19:19:59
13 February 2026, 18:55:31
13 February 2026, 18:32:55
13 February 2026, 18:19:53
13 February 2026, 17:47:25
Poll
Heeft u interesse in een buffet of restauratie rijtuig zoals hieronder gepresenteerd ?
a)    Buffetrijtuig bruin/beige (1977-1982) in lengteschaal 1:93,5 (l.o.b. 282 mm)
2 (2.7%)
b)    Buffetrijtuig geel/blauw (1982-1994) in lengteschaal 1:93,5 (l.o.b. 282 mm)
8 (10.7%)
c)    Restauratierijtuig geel/blauw (1981-1991) in lengteschaal 1:93,5 (l.o.b. 282 mm)
7 (9.3%)
d)    Buffetrijtuig bruin/beige (1977-1982) in lengteschaal 1:87 (l.o.b. 303 mm)
11 (14.7%)
e)    Buffetrijtuig geel/blauw (1982-1994) in lengteschaal 1:87 (l.o.b. 303 mm)
26 (34.7%)
f)    Restauratierijtuig geel/blauw (1981-1991) in lengteschaal 1:87 (l.o.b. 303 mm)
21 (28%)
Totaal aantal stemmen: 42
Auteur Topic: Herziene Beneluxactie nr. 3: Buffet en Restauratierijtuigen  (gelezen 137545 keer)
  • Hengelooo 1:160
Re: Herziene Beneluxactie nr. 3: Buffet en Restauratierijtuigen
« Reactie #15 Gepost op: 19 May 2008, 21:37:01 »
Bruin/beige met blauwe streep? Die variant kent papa niet!
« Laatst bewerkt op: 20 May 2008, 15:18:24 door Mispoes »
martijnhaman
« Reactie #16 Gepost op: 20 May 2008, 08:56:54 »
@ Mispoes: Zo, met bovenstaande foto is dit kennisgat weer gedicht  ;D
Martijn
  • Hengelooo 1:160
« Reactie #17 Gepost op: 20 May 2008, 15:17:44 »
Aangezien de 1500'en de laatste dagen nogal in de belangstelling staan hier volgt nog even de exacte treinsamenstelling van de 1500-excursietrein op 15 maart 1986.
Er werd op die dag met 2 1500'en gereden: de 1501 en 1502. De 1502 kwam uit de richting Hoek van Holland met de trein naar Amersfoort. Daarna nam de 1501 de trein mee naar Utrecht Lunetten,  1502 ging daar los naar toe, de 1502 nam de trein weer mee naar Amsterdam CS.
1502 met excursietrein te Amsterdam CS, 15 maart 1986
Samenstelling Amf-Ut Lunetten: 1501+Buffet+B+B+B+A+B
Samenstelling Ut-Lunetten-Asd: 1502+B+A+B+B+B+Buffet
De A is de 226, de plan E met plan W-ramen in een kopcompartiment.
  • Hengelooo 1:160
« Reactie #18 Gepost op: 21 May 2008, 11:27:10 »
Ik ga o.a. voor de voor de cremè-bruine variant. Mispoes, behoort een verzoekje voor de 001 met blauwe band tot de mogelijkheden?
Wagennummer 001 is al gereserveerd voor de geel/blauwe variant. Zie mijn pb.
    • Het Groterdam Project
« Reactie #19 Gepost op: 25 May 2008, 17:37:53 »
Op verzoek van Frank is de poll gesloten.
Hij weet genoeg en gaat het een en ander uitwerken.
Buffetkat
TEMP: Aanschaf buffet en restauratie wagen via BeneluxSpoor.net
« Reactie #20 Gepost op: 15 July 2008, 17:27:43 »
En daar is ie dan: het handmonster van de krokettenkar in 1:87 op basis van een Rivarossi.
De basis van de te bouwen rijtuigen zal echter naar verwachting een Roco zijn.
Binnen een week gaat de actie van start en kan er besteld worden!
Frank
Overlast
« Reactie #21 Gepost op: 15 July 2008, 18:03:54 »
Dat ziet er goed uit!
System-M
« Reactie #22 Gepost op: 15 July 2008, 21:59:30 »
Ziet er zeker erg netjes uit!
Als basis ga je een roco gebruiken? Ik neem aan dat je dan niet de ROco ICK bedoelt aangezien die niet geschikt waren?
Een ICK ombouwen tot de genoemde rijtuigen kan echt niet. Het formaat van de ramen komt niet overeen. De instapdeuren kloppen niet, de kopdeuren in de overgang zijn niet overeenkomstig het bedoelde model, de dakventilatoren horen op het midden van het dak te zitten. Bij de ICK's zitten ze een stuk naar de zijkant. Over de al veel besproken traptreden van de ICK's zal ik het maar niet eens hebben.
grt
Marc
Grt
Marc
Machinist Johan
  • gevorderd beginner
« Reactie #23 Gepost op: 15 July 2008, 22:01:47 »
fijn, even mijn leraar op de hoogte brenngen ;D
MvG
  • Hengelooo 1:160
« Reactie #24 Gepost op: 15 July 2008, 22:15:44 »
Nee, Roco komt in het lopende kwartaal uit met DB-rijtuigen die wel geschikt zijn. Ik geef de voorkeur aan Roco vanwege de constructie, Rivarossi lijmt het glaswerk vast en is daarbij niet zuinig met lijm...
« Reactie #25 Gepost op: 16 July 2008, 10:05:38 »
Poll is gesloten, u kunt hier wel verder vragen stellen enz enz.
Deze draad blijft ook open tijdens de gehele actie die binnenkort dan echt van start gaat :)
Voor de actie zal een speciale website worden geopend.
En het een en ander zal binnenkort uit de doeken worden gedaan in twee bekende modelspoorbladen  ;)
« Laatst bewerkt op: 16 July 2008, 10:17:21 door Chris van Diesen »
Menno 1846
  • NS Tp3B/C- heden
  • Frl
    • Frieslandrail
« Reactie #26 Gepost op: 16 July 2008, 10:14:18 »
Interesant!!
Greetz:Menno
There's a plan in everything, kid, and I love it when a plan comes together!
Machinist Johan
« Reactie #27 Gepost op: 16 July 2008, 11:50:58 »
gokje: RH en RM ;D k heb eigelijk gen idee
Buffetkat
« Reactie #28 Gepost op: 16 July 2008, 18:42:41 »
Jij mag nooit meer raden! ;D
Machinist Johan
« Reactie #29 Gepost op: 16 July 2008, 19:13:25 »
he, wat vervelend nou :( ;D
