Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: La vie...Sud-Est; zolderbaan met thema zuidoost Frankrijk  (gelezen 117516 keer)
Edsko Hekman
  • Nooit uitgeklust....
Re: La vie...Sud-Est; zolderbaan met thema zuidoost Frankrijk
« Reactie #30 Gepost op: 27 May 2021, 08:59:59 »
Ziet er mooi uit Paul! (y) Heel sfeervol.
Paulus
  • La vie est belle...
« Reactie #31 Gepost op: 04 July 2021, 19:51:57 »
Even provisorisch, moet de software opnieuw aanschaffen, dus maar even getekend. Dit is niveau 0 van het baanplan, met daaronder een detaillering van het station met de wissels.
Afmetingen van de zolder zijn ongeveer 5,5 bij 3,3 meter, in 2 nivo's dus. De tekening daarvan volgt, dat is het dubbelspoor naar het schaduwstation, 2 doorgaande sporen en 7 opstelsporen van elk zo'n ruim 4 meter, en aan het einde een keerlus.
Foto's van het verloop van de bouw volgen spoedig.
salut
  • Vinnie the who?
    • Arlbergbahn...?
« Reactie #32 Gepost op: 04 July 2021, 21:14:51 »
Het station heeft een mooi vloeiend verloop, maar is het niet een beetje gek dat aan de linkerkand de binnenkomende sporen eindigen op de goederenloods..?
De groeten! Vincent
Arlbergbahn...?
Bf Kibronn
Paulus
« Reactie #33 Gepost op: 04 July 2021, 21:25:37 »
Ik snap wat je zegt, ik heb hier in verband met de ruimte bewust voor gekozen. De kopsporen waaronder de bovenste voor goederen, stoppen tegen een dakbalk van de zolder en ik wilde ook nog een kleine onderhoudsloods. Ziet er misschien wat onlogisch uit maar dat valt aardig mee. Zie ook eerdere foto's.
  • Vinnie the who?
    • Arlbergbahn...?
« Reactie #34 Gepost op: 04 July 2021, 22:49:23 »
Is het niet mooier (en wellicht interessanter voor expoitatie?) om daar een kopspoor voor lokale treinen van te maken? Is nog wel ruimte voor tot het stationsgebouw. Buitenste spoor kan geen kopspoor worden, of je moet een extra wisselverbinding maken om na vertrek weer op juiste spoor te komen, maar dat wordt dan omloopspoor. Spoor voor goederenloods lijkt er op de foto's nog wel naast te kunnen? Of de loods halveren, als decor; achter de loods zie je door het schuine dak toch niet..? overigens allemaal goedbedoelde suggesties: sfeertje is fraai en je bent al een stuk verder dan ik ooit gekomen ben!  ;D
De groeten! Vincent
Arlbergbahn...?
Bf Kibronn
  • Vinnie the who?
    • Arlbergbahn...?
« Reactie #35 Gepost op: 05 July 2021, 10:25:40 »
Zie net wel dat je vanaf mijn voorgestelde kopspoor niet naar schaduwstation kan, dus wellicht qua exploitatie niet zo spannend.. Maar aangezien het een ovaal is, komen alle treinen die links vertrekken rechts binnen; dus dan kan je ook kopmaken naar het schaduwstation, wellicht wel leuk... :)
De groeten! Vincent
Arlbergbahn...?
Bf Kibronn
Modellbahnwagen
« Reactie #36 Gepost op: 05 July 2021, 11:12:23 »
Mooie baan, maar is het station voor doorgaande treinen alleen te passeren over aftakkende wissels? (Ene HF Enter draait zich om). Daarnaast zou ik ook gaan voor zware 1500 volt bovenleiding, levert Sommerfeldt niks op dat vlak? Overigens lijken sommige NMBS bovenleidingsportalen van dat merk wel wat op de zuid Franse bovenleiding.
Richard
  • Vinnie the who?
    • Arlbergbahn...?
« Reactie #37 Gepost op: 05 July 2021, 12:38:45 »
... nog een kleine onderhoudsloods.
Wellicht hier?
De groeten! Vincent
Arlbergbahn...?
Bf Kibronn
Paulus
« Reactie #38 Gepost op: 07 July 2021, 20:58:04 »
Nou leuk zo'n forum....zet je dr iets op en dan een hoop commentaar  ;D ;D.... nee geintje. Ik heb nog eens nagedacht en er zit nog wat in de linkerwisselstraat wat niet helemaal loopt.
Die laat ik dan dus nog maar even los liggen en wellicht nog even heroverwegen.
Aan de rechterzijde gaat het de betere kant op, wissels aangesloten en alles rijdt prima, berg beetje aangekleed.
Anton Maris
  • Modelspoor is magisch
« Reactie #39 Gepost op: 07 July 2021, 21:30:36 »
Het landschap ziet er in elk geval al mooi uit. De Purschuim is niet meer te zien.
HuubvG
« Reactie #40 Gepost op: 07 July 2021, 21:50:19 »
Niet van ju wat mooi.  (y)
Edsko Hekman
« Reactie #41 Gepost op: 07 July 2021, 22:03:04 »
Erg mooi geworden Paul!  (y)
  • Vinnie the who?
    • Arlbergbahn...?
« Reactie #42 Gepost op: 07 July 2021, 22:10:38 »
Ook zonder dat je iets doet met mijn suggesties.. Fraai!  (y)
En ging er door het dieselmaterieel op foto's van uit dat het niet-geelectrifieerd zou worden, maar zie toch een bovenleidingmast..? Een Duitse.. ;D
De groeten! Vincent
Arlbergbahn...?
Bf Kibronn
CC72067
« Reactie #43 Gepost op: 08 July 2021, 08:54:03 »
Lekker bezig Paul  (y)
En over de wisselstraat links: In de schematische weergave ziet het hoofdspoor er misschien wel erg aftakkend uit, maar op de eerdere foto's van die wisselstraat vind ik dat wel meevallen. Strikt genomen takt het spoor misschien af, maar door de vloeiende lijn van het hoofdspoor vind ik dat het optisch gezien niet direct storend is.
Roderik
Roderik
Frankrijk - Région Sud - V/VI
Jeroen Water
  • NS tijdperk IV (1973/1974)
« Reactie #44 Gepost op: 08 July 2021, 09:17:22 »
Wat een heerlijk sfeertje begint er op je baan te ontstaan, Paul! Super!  (y) (y) (y)
