Vandaag om 00:00:32
Brawa 2026 door grossraumwagen
24 January 2026, 23:40:44
Doornvliet door Ronzol
24 January 2026, 23:34:13
Condensator - Binnenverlichting en Decoder. door bask185
24 January 2026, 23:13:01
Japanse 2C2, 4-6-4, Hudson locomotieven in vele schalen. door minilocomaster
24 January 2026, 23:06:10
Baan weer opgebouwd na vervangen dakraam door minilocomaster
24 January 2026, 23:05:13
Bahnstrecke 5867 door 741230
24 January 2026, 22:50:51
Spur 0 1 Tage 2026 in Giessen (D) door Marty
24 January 2026, 22:34:05
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door Hans1963
24 January 2026, 22:32:00
24 January 2026, 21:35:17
PB Models, ICR-rijtuigen door cor_b
24 January 2026, 21:12:14
24 en 25 Januari 2026 modelspoorweekend Ewijk door Forever Rocofan
24 January 2026, 20:51:14
Welke central is betrouwbaar? door Ronald Halma
24 January 2026, 20:13:51
Ontraxs 2026 door Ronald Halma
24 January 2026, 20:08:37
24 January 2026, 20:04:43
Baanplan De Oosthoek (h0, 360 bij 140) door Frans Peeters
24 January 2026, 19:28:07
Bruine NS 1200s - Treinsamenstellingen. door Ferdinand Bogman
24 January 2026, 18:54:47
Ervaringen met bezorgdiensten (PostNL, DHL, etc) door Charles_
24 January 2026, 18:51:22
Yamorc YD8116 & MP1 vraag door Bert_Apd
24 January 2026, 18:44:28
19 Toen door Keska
24 January 2026, 18:42:15
US diorama in H0 door gdh
24 January 2026, 17:19:28
24 January 2026, 17:11:28
Die Sauerlandbahn - Tijdperk III door Frank 123
24 January 2026, 17:00:50
heeft iemand ideeën voor een baan van 120CM bij 240CM? door Ronald69
24 January 2026, 16:47:55
24 January 2026, 15:50:12
Oudere Marklin S3/6 opleuken door Robkop
24 January 2026, 15:19:07
24 January 2026, 15:05:32
Handleiding Trix Express 2232 BLS 255 door stoombr38
24 January 2026, 13:36:46
ICR-rijtuigen, voor welk merk ga je? LSmodels, PBmodels, Exact Train of Piko? door Hammondman
24 January 2026, 13:28:12
Big Scale Trains - NS SLT in H0 door hmmglaser
24 January 2026, 13:11:19
Auteur Topic: Toon hier je (model)treinfoto's  (gelezen 112796 keer)
Jan-Peter
  • Bnlx treinendokter.
Re: Toon hier je (model)treinfoto's
« Reactie #165 Gepost op: 03 May 2021, 14:29:59 »
Hoi Jacob e.a.,
Ik wil hem 1:87, met sleper, geluid, twee-takt oliepluim en MFX decoder van Marklin.  ;D
Als we dan toch onbereikbare dromen gaan ventileren .... ;)
Jan-Peter
« Reactie #166 Gepost op: 03 May 2021, 14:47:51 »
In 1:1 nog wel te maken. Er mee rijden is een ander verhaal...
Vergt een grondige kennis van de bestaande dienstregeling  :D
de groeten van Jacob
En iets in LGBschaal:
Rieks
  • Helemaal opnieuw begonnen
  • Fiat Voluntas HrMs Poolster A835
« Reactie #167 Gepost op: 03 May 2021, 15:12:00 »
Gewoon opvoeren net als vroeger.
En dan achter zo'n arriva ding aanrijden die gaan niet zo hard.
Listen very carefully, I shall say this only once.
Cetero censeo birrum  bibendum esse
« Reactie #168 Gepost op: 03 May 2021, 15:31:36 »
Nu nog gewoon op een stukje rails met een geschilderd achtergrondje:
Fotodijkje is in aanbouw  :)
« Reactie #169 Gepost op: 03 May 2021, 15:48:53 »
De sounddecoder moet er nog steeds in  ::)
Gelukkig is het nog die van ESU. Er zijn geruchten dat die van Piko zelf minder goed is.
« Reactie #170 Gepost op: 03 May 2021, 19:33:38 »
NS1101 met een kort tijdperk III sleepje.......
Gr, Ben.
« Reactie #171 Gepost op: 03 May 2021, 21:58:03 »
een houtel model van de SZ 03 002, voorheen Sudbahn 109.38, DRB 38 4119. Model is ongeveer schaal 1:20. Dit model staat, evenals het origineel in het spoorwegmuseum van Ljubljana. Het origineel stond in een donkere loods, daar heb ik alleen een slechte foto van
Roco heeft een model uitgebracht in de huidige museumuitvoering onder nr 72119
Mooi ding  (y)
Ongeveer schaal G dus: dat wil wel groot worden  :o
hrp
« Reactie #172 Gepost op: 07 May 2021, 16:33:57 »
Overweg nabij vm station NS Kleiweg.
Randstadrail lijn E met aftakking werkplaats RET.
7 mei 2021
Ronald
      Ronald
« Reactie #173 Gepost op: 07 May 2021, 21:06:24 »
Mooi stukje scenery Ben, sfeervol ook.
Gr. Frank.
« Reactie #174 Gepost op: 07 May 2021, 21:23:08 »
In de serie spoorwegmusea wat beelden uit het smalspoormuseum in Gryfice, in het noorden van Polen.
Bezoek was in augustus 2014.
 Gr. Frank
hrp
« Reactie #175 Gepost op: 08 May 2021, 14:35:44 »
In de dierenserie.
Hondekop nabij Blijdorp Zoo , 25 juni 1977
èR
« Laatst bewerkt op: 08 May 2021, 14:59:29 door hrp »
      Ronald
« Reactie #176 Gepost op: 10 May 2021, 22:17:19 »
In de serie 'Spoorwegmusea' - en naar aanleiding van een opmerking over het trammuseum van Mulhouse- een paar beelden uit maart 2012. Het een mooi en vrij groot museum. Ben vergeten de bordjes te fotograferen, dus kan geen inhoudelijke toelichting geven, helaas.
Paar opvallende voertuigen (in mijn ogen).
gr. Frank.
hrp
« Reactie #177 Gepost op: 10 May 2021, 22:46:54 »
Soort van raadplaatjes dus.
Maar een bordje is te lezen: autorail rapide uit 1934.
Het oogt wel heftig.
Ronald
      Ronald
MarcNL
    • foto's op Imgur
« Reactie #178 Gepost op: 11 May 2021, 06:47:49 »
Ben er ook een aantal keren geweest.
Heel mooi museum.
Zal de foto's eens opzoeken (als ze al niet te veel verkleurd zijn...).
  • Bestuur
« Reactie #179 Gepost op: 11 May 2021, 07:22:43 »
Die autorail is een ontwerp van Bugatti. Ja, die van de auto’s
