Lobomotion69
om 03:05:51
Frans Peeters
om 00:30:31
23 January 2026, 23:58:05
23 January 2026, 23:16:42
23 January 2026, 23:12:31
23 January 2026, 22:18:11
Welke Rookvloeistof gebruik jij?
23 January 2026, 22:00:29
Joz
23 January 2026, 21:56:34
23 January 2026, 20:47:50
Arlbergbahn.. ?
23 January 2026, 20:15:00
De Projecten van RetroJack
23 January 2026, 19:47:47
Roco Hippel 04160C digitaliseren
Stootjuk
23 January 2026, 19:40:58
Handleiding Trix Express 2232 BLS 255
23 January 2026, 19:38:42
Fotowedstrijd 2025
23 January 2026, 19:35:46
23 January 2026, 19:35:34
23 January 2026, 18:58:54
23 January 2026, 18:57:32
23 January 2026, 18:46:46
23 January 2026, 18:26:24
23 January 2026, 18:09:36
Albert.H0
23 January 2026, 18:09:27
Lars Smelter
23 January 2026, 18:03:25
W.V. Kalender 2026
Keska
23 January 2026, 17:59:28
Rsd1000
23 January 2026, 17:35:29
Yamorc YD8116 & MP1 vraag
Bert_Apd
23 January 2026, 17:35:23
23 January 2026, 17:14:55
Brawa 2026
spoorzeven
23 January 2026, 17:10:07
23 January 2026, 16:28:33
ecos2 koppelen met handregelaar.
AlbertG
23 January 2026, 16:27:53
23 January 2026, 16:05:05
Al het andere!
St. Janskathedraal van 's-Hertogenbosch in 1:87, de bouw gevolgd
Topic: St. Janskathedraal van 's-Hertogenbosch in 1:87, de bouw gevolgd (gelezen 104546 keer)
Niekleair
Re: St. Janskathedraal van 's-Hertogenbosch in 1:87, de bouw gevolgd
Reactie #75 Gepost op:
12 February 2019, 22:04:47 »
Gaaf project. De vloer is enorm overtuigend!
Ga je het orgel nog
werkend
maken
Oeps!
Eens komt het goed.
Reactie #76 Gepost op:
12 February 2019, 22:05:45 »
Het wordt met het uur indrukwekkender
SuperSylvester
Reactie #77 Gepost op:
12 February 2019, 22:11:54 »
Citaat van: Niekleair op 12 February 2019, 22:04:47
Ga je het orgel nog
werkend
maken
Wow, jij maakt het wel erg bont
Ik heb een PIC compiler dus.... wie weet. Wel gaaf!
Groeten, Jack. Don't only practice your art, but force your way into it's secrects. For it, and knowledge can raise man to the Divine - Ludwig Van Beethoven
Team Mitropa
Reactie #78 Gepost op:
12 February 2019, 22:52:46 »
iets met honden die een bepaald brood niet lusten
Team Mitropa - OHMB
Reactie #79 Gepost op:
12 February 2019, 23:38:01 »
Formidabel, ik vind het een prachtig werkstuk. Waar heb je de vloertegels van gemaakt?
RETROBAHN A.G.
SuperSylvester
Reactie #80 Gepost op:
13 February 2019, 08:04:33 »
Citaat van: Besselspoor op 12 February 2019, 23:38:01
Nou, eigenlijk heel eenvoudig.
Dit plaatje ergens van het web geplukt en dat op zijdeglans fotopapier afgedrukt, een avondje knippen en plakken et voilá.
Ik kan die vloer eindeloos blijven uitbreiden dat is ook wel zo prettig.
Mike 1961
Bruggenbouwer
Reactie #81 Gepost op:
13 February 2019, 08:19:47 »
WOW!
Complimenten hoor.
Je laat zien dat er met de 3D printer en een hoop tekenwerk mooie resultaten zijn te behalen.
Met vriendelijke groeten,
Mike
Jeroen Water
NS tijdperk IV (1973/1974)
Reactie #82 Gepost op:
13 February 2019, 08:42:34 »
Wat een prachtig resultaat weet je te bereiken met deze giga uitdaging, Jack!
Eton Wick, UK
Reactie #83 Gepost op:
13 February 2019, 10:39:23 »
Wat een project, zeg. Opnieuw moet ik het met Marc eens zijn. Ik ben meer onder de indruk dat je zo'n project bent aangegaan.
Ik heb ook zo'n XYZ printer. Nadeel is als je platte oppervlakten print, het aan de onderzijde gaat bollen, doordat de zijkanten omhoog trekken. Zeker als het voorwerp groot is. Knap dat je zulke voorwerpen er uit gekregen hebt. Ik kan me zo voorstellen dat het nadeel in jouw geval is dat de print ook veel te grof is en je alles moet schuren. Het is een goede printer, maar je moet bij het ontwerpen wel rekening houden met deze printer. Is het overigens mogelijk dat je je de prijs verkeerd herinnerd? Ik heb er €200 voor betaald en dat is eigenlijk de gangbare prijs.
Sinds kort heb ik de Anycubic Photon. Een hoogwaardige resinprinter voor rond de €400. Ik vermoed dat je nieuwe printer een zelfde soort ding is. Om van de vervelende lucht af te komen, kun je een 8cm computerventilatortje op het ventilatiegat bouwen en daarop een carbonfilter. Zoek maar eens op het Internet. Op Thingiverse zijn ontwerpers die adapters gemaakt hebben voor de verschillende printers om de ventilator en carbonfilter aan te sluiten. De lucht van de resin is niet gezond voor mens en dier. Komt je XYZ printer wellicht weer van pas.
www.tramfabriek.nl
Volg mijn bouwactiviteiten op
Facebook
Reactie #84 Gepost op:
13 February 2019, 10:51:11 »
Hoe zijn de figuren tot stand gekomen
SuperSylvester
Reactie #85 Gepost op:
13 February 2019, 11:24:49 »
@Sven, ik heb sinds kort deze:
(zie een aantal postings terug). Die is vergelijkbaar met de Anycubic en werkt met hetzelfde principe. Die geur valt best wel mee al zou ik hem
niet op de slaapkamer of in de woonkamer zetten (bij mij staat die in de berging) en voldoende ventileren.
Je moet altijd rekening houden met de printer en de (on)mogelijkheden ervan dat maakt het des te uitdagender
@Gerco, de beelden pluk ik van het internet. Op Thingiverse staan er genoeg als je even zoekt dat zijn meestal 3D scans van het orgineel, je kunt ze gemakkelijk verschalen.
Laatst bewerkt op: 13 February 2019, 11:28:45 door SuperSylvester
ATB
Modelrailroading is fun
Reactie #86 Gepost op:
13 February 2019, 12:34:07 »
Als je de (stl's van de) figuren spiegelt om de verticale as heb je ook gemakkelijk varianten
. Heb ik ook gedaan met de persoon op mijn draaiorgel in schaal 0.
Ted
Reactie #87 Gepost op:
13 February 2019, 12:38:42 »
Je hebt wel kans dat er een religieuze logica in de houding van de figuren zit. De hand waarin een staf wordt vastgehouden en zo. Dat kan je niet zomaar spiegelen.
Team Mitropa - OHMB
Reactie #88 Gepost op:
13 February 2019, 12:46:41 »
Ik heb daarom mijn interieur wat eenvoudiger gehouden
Maar qua beelden, er is zo'n diversiteit in én op de St Jan, ik kan me voorstellen dat je alleen maar een indruk wil wekken en een gangbaar type dupliceert met voorbijgaan aan diepere betekenis.
RETROBAHN A.G.
SuperSylvester
Reactie #89 Gepost op:
13 February 2019, 12:59:07 »
Precies, ongeveer 600 beelden (!) op de Sint Jan. Dat is niet te doen en daarom zijn de meeste hetzelfde, het gaat inderdaad om 'de indruk te wekken'
Ander puntje: in het echt zijn de beelden wel verschillend maar lijken toch veel op elkaar, ga je dat verschalen naar 1/87 dan wordt het verschil nog kleiner.
Mooi interieurtje trouwens.. duidelijk protestants?
Geheel overbodig: heeft iemand al de spreekwoordelijke mol gevonden in mijn laatste update? zit een prijs aan verbonden
Laatst bewerkt op: 13 February 2019, 13:02:59 door SuperSylvester
Al het andere!
