NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
Betrouwbare Stroomafname met Trix C-Rail door Floris Dilz
Vandaag om 00:01:16
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
28 January 2026, 19:55:14
Auteur Topic: Stationsplein Baden Baden  (gelezen 396526 keer)
Dion
  • powerd by Uhlenbrock & Esu
  • stationsplein Baden-Baden
    • stationsplein Baden Baden
Re: Stationsplein Baden Baden
« Reactie #1170 Gepost op: 11 March 2016, 17:09:35 »
De volgende 15cm2 die aangekleed is.
Gaat het om dit stukje plank.
Links komen bomen te staan rechts wat spullen.
Van allerlei bewaarde spullen uit de verzamelbak wat aankleding gemaakt.
Overzicht van het gene wat ik heb gedaan. Alleen de lantaarnpalen, extra groen en de vulinstallatie voor de tankwagens
moeten er nog komen.
groetjes Dion
Dion
« Reactie #1171 Gepost op: 12 March 2016, 15:44:11 »
De heg met poort geplaatst. Daarachter had ik een wegneembare plankje gemaakt wat nu te groot is. Wederom aanpassen dan maar.
groetjes Dion
Dion
« Reactie #1172 Gepost op: 20 March 2016, 15:02:27 »
Wat kleinigheden aan de baan gedaan en wat rond gereden met materieel.
Weer een stukje verder met het instrooien tussen de rails. Her en der nog voorzien van wat groen en op een later tijdstip evt. nog de bovenleiding
masten enz plaatsen.
Dit plankje moet weg te nemen zijn en er moest een mooie overgang komen met de rest rondom het plankje.
Naar mijn zin goed gelukt. Er volgt uiteraard nog wel wat verdere aankleding.
groetjes Dion
Dion
« Reactie #1173 Gepost op: 20 March 2016, 15:06:47 »
Vandaag ook wat rond gereden met wat materieel. Nu zien jullie vaak modern materieel van mij, maar uiteraard heb ook nog wel iets anders.
De stoomafdeling van Stationsplein Baden Baden.
groetjes Dion
  • Spoor-0 & Spoor-1
    • Modeltreinbaan.nl
« Reactie #1174 Gepost op: 20 March 2016, 15:11:16 »
Prachtcollectie. (y)
  • de hondsrug baan
« Reactie #1175 Gepost op: 20 March 2016, 16:48:26 »
Hallo Dion,
Wist niet dat je een collectie stoomlocomotieven had, wel fraai  (y)
ps fraaie plaatjes
mvgr Evert
Dion
« Reactie #1176 Gepost op: 20 March 2016, 17:06:55 »
Dank u heren. (y)
Heb ik sommige toch nog kunnen verrassen. ;D
De enige stoomlocomotief die niet op de foto staat(paste niet op de draaischijf) is een grote uit de usa.
Een van mijn nieuwe aanwinsten van dit jaar wordt de Roco glaskast van de bbo, met sound.
groetjes Dion
Dion
« Reactie #1177 Gepost op: 26 March 2016, 18:52:38 »
De bestelde bomen zijn binnengekomen en maar meteen geplant.
Deze zat er ook bij
Kort filmpje gemaakt. De ledstrip heeft nogal wat mogelijkheden.
https://www.youtube.com/watch?v=DhygkSgv_Kc
groetjes Dion
  • de hondsrug baan
« Reactie #1178 Gepost op: 26 March 2016, 19:37:45 »
Dat is wel erg fraai Dion  (y) zo'n verlichtings- set.
Mvgr Evert en Bas
« Laatst bewerkt op: 26 March 2016, 20:00:12 door mass am see. Reden: even een extra spatie gemaakt »
nighttrain1
  • Team Beurzen en PR
« Reactie #1179 Gepost op: 26 March 2016, 19:48:59 »
Mooi systeem, ziet er goed uit.  (y)
Ga je al je rijtuigen daar mee uitvoeren?
Groeten Richard, nighttrain1
Bouw:Modelbaan & modulebakken
Dion
« Reactie #1180 Gepost op: 27 March 2016, 11:06:12 »
Dank u heren, ben ook zeer tevreden over de ledstrip. Ga er nog verder mee expermiteren wat betreft mogelijkheden en afstellingen.
Eerst ga ik uitzoeken welke wagens in aanmerking gaan komen voor rijtuigverlichting. Dan kijken welke in de stam er sluitseinverlichting mee gaat krijgen.
Of ze allemaal worden voorzien van een ledstrip met functiedecoder weet ik nog niet. Het is een vrij prijzige ledstrip en dat gaat wel in de papieren lopen met het aantal rijtuigen dat ik heb. Waarschijnlijk zal het wel uitdraaien op een combinatie van gewone ledstrip en die met een functiedecoder.
De ledstrips met functiedecoder zal in de toekomst ook wel wat in prijs zaken.
groetjes Dion
« Reactie #1181 Gepost op: 27 March 2016, 11:18:28 »
Je bomen zou ik toch nog wat verfraaien Dion.
Mvh Steef
Dion
« Reactie #1182 Gepost op: 27 March 2016, 11:30:30 »
Dank je voor het meedenken Steef. (y)
In welk opzicht verfraaien en hoe en met wat?
Heb namelijk nogal wat verschillende soorten van dit soort bomen staan(rechtstreeks uit de zak) en vind zelf dit de mooiste(noch).
Maar als ze verbeterd kunnen worden sta ik daar wel voor open.
« Laatst bewerkt op: 27 March 2016, 11:33:31 door Dion »
groetjes Dion
nighttrain1
« Reactie #1183 Gepost op: 27 March 2016, 14:33:26 »
Zijn de ledstrips niet op een of andere manier door te koppelen via een multipolige kortkoppeling?
Dion
« Reactie #1184 Gepost op: 28 March 2016, 18:00:27 »
Geen flauw idee.
Zal eens kijken in de gebruiksaanwijzing.
Heb vandaag al mijn rijtuigen bekeken wat er aan verlichting kan. Gekeken of er sluitverlichting kon worden ingebouwd, of ze evt al bij de assen stroomafnemers hebben zitten en zo niet wat nodig te hebben om dit te bewerkstelligen.
« Laatst bewerkt op: 28 March 2016, 18:03:29 door Dion »
groetjes Dion
