Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Depot Chur Sand (RhB) in HOm  (gelezen 34601 keer)
jzegers
    • the family zegers homepage
Re: Depot Chur Sand (RHB) in HOm
« Reactie #15 Gepost op: 01 October 2015, 20:16:35 »
Vandaag niet heel veel gedaan maar toch weer wat dingetjes gedaan de sporen liggen allemaal in de loods en zijn in de vloer verwerkt en heb toch het puntstuk wat halverwege in de loods zat open gemaakt zodat er een vakwerkcontructie ontstond en dat zag er weer zo goed uit dat ik er gelijk 2 bij heb gemaakt.
De binnen indeling is misschien niet naar de werkelijkheid maar naar eigen idee in het achterdeel komt nog een verdieping aan de rechterkant met boven kantoren e.d en beneden werkruimte.
jzegers
« Reactie #16 Gepost op: 02 October 2015, 09:24:49 »
kleine update: heb bij de deur openingen de bogen gemaakt dat rond snijden gat lastig maar is mooi gelukt en maakt het net een beetje af.
Nu nog een paar vraagjes:
Soms blijven er naadjes/kieren open hoe kan ik die het mooiste dicht maken/krijgen?
En er moet ook nog geverfd worden wat voor verf kan ik nu het beste gebruiken?
groeten
Johan
  • Michel
  • low-budget modelbouwer
    • Rangeerbanen
« Reactie #17 Gepost op: 02 October 2015, 15:56:02 »
Hoi Johan,
Ook ik werk met karton, met naden heb ik weinig problemen. Als ik verkeerd snij, dan vervang ik het geheel voor een nieuw juist passend deel. Zo voorkom je naden en hou je je ondergrond vlak. Het materiaal wat je niet gebruikt kan je vaak nog wel ergens anders gebruiken. Daarnaast is het materiaal goedkoop in vergelijking met de styreenbouwers.
Het karton zelf beplak ik met fijn schuurpapier om stucwerk te imiteren. Het makkelijkst gaat dat met dubbelklevend folie. Zie ook mijn draadje met minieme informatie  :-\
jzegers
« Reactie #18 Gepost op: 02 October 2015, 16:29:31 »
kleine update
Michel dat van dat schuurpapier is een goede tipdat ga ik eens uitproberen op een proef stukje.
groeten johan
  • Michel
    • Rangeerbanen
« Reactie #19 Gepost op: 03 October 2015, 16:20:40 »
Je deurtje beneden en het raam erboven zitten scheef  :-\. Foto's geven dat maar al te duidelijk weer...
Niet te grof schuurpapier gebruiken, ik gebruik zelf korrel 180. Dat ik dan verf met Vallejo modelverf. Voor je raampjes zijn er verschillende oplossingen, ik zal eens kijken of ik een klein overzichtje kan maken met wat ik tot nu toe uitgeprobeerd heb.
jzegers
« Reactie #20 Gepost op: 03 October 2015, 21:34:30 »
ja ik zag ook al op de foto dat ze een beetje scheef waren was me eerder niet opgevallen dat moet ik even bij werken maar dat komt goed!!! ben nog niet toegekomen aan het schuurpapier heb vandaag niet heel veel tijd gehad, maar heb wel de hele binnen en buitenkant in een soort primer gezet en die vult ook kleine onevenheden en kiertjes op. Was een tip van een kunstenaar die ik kreeg en ik moet zeggen dat het dat het nog redelijk werkt ook.
Hierna ga ik beginnen aan het schuurpapier en ramen (Experimenteer)project ben benieuwd hoe dat gaat.
Groet johan
« Laatst bewerkt op: 03 October 2015, 21:49:26 door jzegers »
RhB-Mikey
  • Lokifahrer Mikey
  • Rhätische Bahn fan
    • Flickr
« Reactie #21 Gepost op: 03 October 2015, 22:08:38 »
Ziet er goed uit!
Ik zou zelf ook graag een depot willen maken voor een stuk verlenging van de baan om wat te kunnen rangeren  :)
klik hier voor mijn filmpjes
Bouwt aan Bahnhof Langwies
GD
  • Nee hoor, die heb ik al heel lang...
« Reactie #22 Gepost op: 04 October 2015, 12:07:03 »
Mooi project, Johan. Het brengt weer een hoop herinneringen terug aan vakanties eind jaren zeventig in Tschiertschen. Voor de boodschappen moesten we dan regelmatig naar Chur. Het depot heb ik vaak gezien. Dat was nog in de tijd dat Chur - Arosa met motorwagens werd bediend. Ik ben benieuwd naar je vorderingen.
Gerard
jzegers
« Reactie #23 Gepost op: 04 October 2015, 12:59:35 »
vandaag aan het fijne snijwerk begonnen doe eerst de buitenranden van de ramen op de kleine raampjes moet ik nog even oefenen met het mes. Hier ga ik ook wit fotokarton voor gebruiken eens kijken hoe dat werkt.
maar dat komt wel goed denk ik.
jzegers
« Reactie #24 Gepost op: 04 October 2015, 16:00:35 »
Vandaag allemaal kleine dingetjes maar het maakt het wel af zo
jzegers
« Reactie #25 Gepost op: 04 October 2015, 20:30:12 »
Vandaag begonnen met de ramen ben gestart met een raam dat niet direct in het zicht komt en dit is redelijk gelukt hoewel ik niet helemaal tevreden ben maar om dit uit karton te snijden gaat het niet smaller/dunner
Doordat alles wit is geverfd weerkaast de flitser een beetje maar morgen ga ik dit muurtje een kleurtje geven om te kijken hoe het er uit eindelijk uit ziet.
« Laatst bewerkt op: 04 October 2015, 20:49:50 door jzegers »
  • Michel
    • Rangeerbanen
« Reactie #26 Gepost op: 05 October 2015, 08:55:57 »
Om ramen te snijden zijn er enkele mogelijkheden. Natuurlijk kan je bij een fabrikant gaan kijken of die misschien ramen in zijn assortiment heeft, maar dat is niet leuk ;). Bij mij kartonnen bouwsels heb ik drie manieren om ramen te maken. De eerste is vrij eenvoudig, Uit een stickervelletje snij je zeer dunne reepjes. Dat gaat iets makkelijker dan bij papier, maar je loopt ook de kan dat het stickervelletje gaat rimpelen. Een zeer scherp mesje en niet duwen zijn het devies:
De tweede manier is dat wat jij hebt gedaan. Je neemt een stuk karton/dun papier en probeert daar ramen in te snijden. Eerst teken ik de ramen uit op karton, Dat worden de 'spijlen' en kozijnen. Vervolgens snij ik systematisch vlak langs de spijlen de ramen eruit. Systematisch moet je lezen als: liniaal langs de spijl (of kozijn) leggen en alle ramen langs die spijl rustig uitsnijden. Ook hier: een zeer scherp mesje en niet duwen zijn het devies:
Een tip die mij destijds gegeven werd, was om het karton/papier te verstevigen met secondelijm. Het wordt dan wat steviger en rafelt minder. Ik heb dat niet gedaan overigens (ik wilde het eerst zonder proberen ;))
Een derde manier is omgekeerd werken. Op doorzichtig kunststof plak je afplaktape. Je snijdt nu de kozijnen er uit, de stickers op de ramen laat je zitten. Met wat verf schilder je de kozijnen. Je kunt rustig kliederen, de ramen zijn toch afgeplakt. Deze techniek heb ik nog niet zo goed in de vingers:
Alles is schaal H0. Misschien helpen mijn ervaringen jou wat.
jzegers
« Reactie #27 Gepost op: 05 October 2015, 10:16:13 »
Idd kant en klare raampjes is niet leuk je bouwt alles zelf en dan ga je ineens een kant en klaar iets er in zetten ne de uitdaging is voor mij alles zelf te maken maar ik heb dus de tweede methode van michel gebruikt zie ik. Op zich ziet het met deze aardig uit maar voor kleine raampjes is het lastig is naar mijn idee goed geschikt voor grote ramen, ik ga die met het sticker vel en strookjes snijden eens proberen. Kijken hoe dat gaat. Dank voor de tips michel.
Groeten
Johan
jzegers
« Reactie #28 Gepost op: 05 October 2015, 15:29:18 »
Vandaag een beetje verf aan gebracht op de ramen en dan ziet het er iets beter uit alleen moet ik ze iets lichter maken ziet er te schoon uit. Het moet er wel een beetje verweert uit komen te zien maar dit is ook maar een testje, nu de muren zelf nog een kleurtje ergens tussen geel en creme in.
jzegers
« Reactie #29 Gepost op: 06 October 2015, 14:24:24 »
Ben toch weer na een test met strookjes sticker over gegaan op het simpelweg uitsnijden van de raampjes uit Karton het is even wat werk maar het ziet er na oefening goed genoeg uit heb wel de tipp uitgeprobeerd met de seconde lijm en dat werkt ook goed moet wel iets harder drukken op het mes maar het snijd goed en netjes zie de foto voor het resultaat links eerste raam rechts het nieuwe en veel betere dus de andere ga ik opnieuw doen.
