Voordelige treinkaartjes
Seinhuis
om 00:54:05
Molenbaan (werktitel)
sdz1976
om 00:19:12
01 February 2026, 23:44:43
Hout realistisch nabootsen
01 February 2026, 23:41:08
01 February 2026, 23:36:40
01 February 2026, 23:14:29
NMJ 2026
Dion
01 February 2026, 23:09:08
01 February 2026, 23:00:46
01 February 2026, 22:43:44
01 February 2026, 22:34:40
reinderlf
01 February 2026, 22:18:42
BR01 van Roco verfraaien.
01 February 2026, 22:09:34
01 February 2026, 21:57:01
Z21
Caspar25
01 February 2026, 21:42:39
Eindstation Daarhuizen
HenkN
01 February 2026, 21:41:32
T.Spat
01 February 2026, 21:38:17
Armita Wagons Amsterdam bv Tds
T.Spat
01 February 2026, 21:34:49
The Summer of 69
01 February 2026, 20:50:28
Inrijbaan 240x120cm
BramFokke
01 February 2026, 20:46:20
01 February 2026, 20:25:59
01 February 2026, 20:18:11
01 February 2026, 20:03:16
De donkere blauwe blokkendozen
01 February 2026, 19:15:05
01 February 2026, 18:49:40
ik kom er niet uit met de esu in de bigboy solderen
01 February 2026, 18:45:59
jack is back
01 February 2026, 18:19:43
Ronald A.
01 February 2026, 17:53:38
01 February 2026, 17:53:34
01 February 2026, 17:45:29
Traintastic - modelbaan besturingssoftware (gratis en open source)
reinderlf
01 February 2026, 17:20:06
Materieelbespreking
Roco en Fleischmann
Roco N.S.diesel elektrische loc 2400
Topic: Roco N.S.diesel elektrische loc 2400 (gelezen 442755 keer)
eric den boer
Einzelganger
Re: Roco N.S.diesel elektrische loc 2400
Reactie #840 Gepost op:
29 December 2007, 14:49:04 »
Voor Eric...
Het nieuwe model wordt aangedreven doormiddel van een motortje.
Zo!!! i,am imperessed
theomeeuwsen
Reactie #841 Gepost op:
29 December 2007, 14:51:00 »
wanneer is Nürnberg Messe
Thowra
Reactie #842 Gepost op:
29 December 2007, 14:54:24 »
Van 7 tot 12 februari.
Maar graag nu weer ontopic.... Roco Ns 2400!
Laatst bewerkt op: 29 December 2007, 14:56:25 door Thowra
Fred Eikelboom
Wees jezelf, er zijn al anderen genoeg.
Team encyclopedie
Zonderling en fobie-deskundige.
Reactie #843 Gepost op:
29 December 2007, 16:02:42 »
Heb vanmorgen een L*** Silver Decoder in mijn R*** 2433 HO geplaatst.
Volgens de gebruiksaanwijzing moest deze plat onder de huif geplaatst worden, maar toen ik de kap terug wilde plaatsen, bleek de decoder ongeveer een milimeter breder dan de kap te zijn.
Heb inmiddels wel een oplossing gevonden, maar zou graag weten of er nog andere HO bezitters zijn die dit probleempje tegengekomen zijn, en wat eventueel hun oplossing was.
(Weet niet of ik hier merknamen mag noemen, vandaar de ***)
Fred.
Laatst bewerkt op: 29 December 2007, 16:13:27 door Fred Eikelboom
mvg, Fred
Als de oorzaak bekend is, is de oplossing een stuk dichterbij.
Jo Heuschkiel
B-1220 (uit 1914) van de ZLSM (foto van 29-5-'05)
Reactie #844 Gepost op:
29 December 2007, 16:16:25 »
Hallo Fred,
Ja, ik had hetzelfde probleem.
Ik heb i.p.v. de Silver een ESU-52611 geplaatst, die is nl. iets smaller en past wel.
Ben wel geïnteresseerd in jouw oplossing.
Ik denk trouwens niet, dat er problemen ontstaan bij het noemen van merken. Internet-forums staan er vol mee......
M.vr.gr.
Jo
2-rail H0 & IB2+Digikeijs & TrainController-Gold
Piet van Dorssen
Reactie #845 Gepost op:
29 December 2007, 16:26:20 »
Hallo Fred,
Ook ik heb een Silver decoder geplaatst en 1 van de zijkanten iets minder dan een mm afgevijld. aan de andere kant van de decoder lukt dat niet omdat de komponentjes vlak langs de rand lopen. Het past nu als een soort klikverbinding en functioneert perfect.
Piet
NS tijdperk 3; Lenz Digital Plus; station Meppel; Koploper in voorbereiding
Reactie #846 Gepost op:
29 December 2007, 17:07:29 »
Citaat van: Fred Eikelboom op 29 December 2007, 16:02:42
Als je geen merknamen zou mogen noemen, dan zou het halve forum vol met sterretjes staan ;-)
Gertjan.
TonM
Reactie #847 Gepost op:
29 December 2007, 17:16:27 »
Fred,
Doordat de huif van de 2400 zo smal is, luistert het inderdaad nauw. Ik had zelf al die ervaring opgedaan met de 2400 van DKM en ik heb nu een LokPilot Basic gebruikt. Pas precies.
Ton
Tedo
Wacht tot het rode licht gedoofd is
Reactie #848 Gepost op:
29 December 2007, 17:22:10 »
Citaat van: Thowra op 29 December 2007, 14:35:23
Ik heb belooft dit niet bekend te maken.
Doe dat dan ook en maak ons niet lekker
Grtz!
Tedo
Esperopt
Sic gorgiamus allos subjectatos nunc
Reactie #849 Gepost op:
29 December 2007, 18:11:53 »
@Wijktrein: je hebt het toch niet over de 1100 met botsneus?
Gouda
kaas, kaars en siroopwafel
Reactie #850 Gepost op:
29 December 2007, 18:14:53 »
Ik heb een Ulhenbrock 76 420
geplaatst en heb totaal geen problemen met de ruimte.
Marc
Laatst bewerkt op: 29 December 2007, 18:16:38 door Gouda
Nederlandse diesels zijn mijn favoriet.
Fred Eikelboom
Team encyclopedie
Reactie #851 Gepost op:
29 December 2007, 18:50:55 »
Hallo heren,
Mijn oplossing bestond uit het volgende:
Door op de plaats waar de decoder moet komen, aan één lange kant een stukje schuimplastic tochtstrip (1 cm dik) te plakken, en dit aan de bovenzijde onder een hoek van ongeveer 45 graden af te schuinen met een scheermesje ontstond een prima 'fundering' voor het diagonaal plaatsen van de decoder. (diagonaal over de korte zijde)
Aan de andere lange zijde heb ik een reepje dubbelzijdig plakband
bevestigd (ongeveer 3 x 16 mm.) en de print hier schuin opgelegd.
Na het op deze wijze monteren van de decoder paste de kap weer prima.
(Op mijn WebSpace staat een tekening)
Bedankt voor jullie reacties.
Fred.
Laatst bewerkt op: 29 December 2007, 19:27:40 door Fred Eikelboom
mvg, Fred
Trainmotion
I'm watching you
Reactie #852 Gepost op:
29 December 2007, 19:37:13 »
Beste mensen,
Ik heb een lokpilot v3.0 gebruikt. Past net in de huif. Dacht eerst dat het niet lukte maar het folie wat er omheen zit gaf nog een beetje mee. De lokpilot gekozen vanweg de blinkfunctie incl. dimmen van het licht. Leuke bijkomstigheid vind ik dat deze functie ook in analoog knippert.
Oh ja, voor de rest vind ik de 2400 een topmodel. Nu nog de versie met een derde sein.
Roelof
Digitaal DCC 2 rail DB-NS tijdperk III/IV/V
Gideon
Reactie #853 Gepost op:
29 December 2007, 20:13:07 »
Sluit me aan bij Gouda, bijde 2400's met Uhlenbrock 76420.
Prima decoder tegen goede prijs (19,95), genoeg ruimte.
Gideon
Reactie #854 Gepost op:
29 December 2007, 20:29:56 »
Heb er ook een lenz Silver ingezet, en ging niet helemaal probleem loos, maar uiteindelijk ligt hij plat op z'n plaats, en past de kap er net over zonder aan de decode te veilen.
Had zo snel geen Gold bij de hand, maar die is net iets kleiner dan de silver, dus zou misschien standaard al iets makkelijker gaan.
Materieelbespreking
Roco en Fleischmann
