Vandaag om 00:00:32
Brawa 2026 door grossraumwagen
24 January 2026, 23:40:44
Doornvliet door Ronzol
24 January 2026, 23:34:13
Condensator - Binnenverlichting en Decoder. door bask185
24 January 2026, 23:13:01
Japanse 2C2, 4-6-4, Hudson locomotieven in vele schalen. door minilocomaster
24 January 2026, 23:06:10
Baan weer opgebouwd na vervangen dakraam door minilocomaster
24 January 2026, 23:05:13
Bahnstrecke 5867 door 741230
24 January 2026, 22:50:51
Spur 0 1 Tage 2026 in Giessen (D) door Marty
24 January 2026, 22:34:05
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door Hans1963
24 January 2026, 22:32:00
24 January 2026, 21:35:17
PB Models, ICR-rijtuigen door cor_b
24 January 2026, 21:12:14
24 en 25 Januari 2026 modelspoorweekend Ewijk door Forever Rocofan
24 January 2026, 20:51:14
Welke central is betrouwbaar? door Ronald Halma
24 January 2026, 20:13:51
Ontraxs 2026 door Ronald Halma
24 January 2026, 20:08:37
24 January 2026, 20:04:43
Baanplan De Oosthoek (h0, 360 bij 140) door Frans Peeters
24 January 2026, 19:28:07
Bruine NS 1200s - Treinsamenstellingen. door Ferdinand Bogman
24 January 2026, 18:54:47
Ervaringen met bezorgdiensten (PostNL, DHL, etc) door Charles_
24 January 2026, 18:51:22
Yamorc YD8116 & MP1 vraag door Bert_Apd
24 January 2026, 18:44:28
19 Toen door Keska
24 January 2026, 18:42:15
US diorama in H0 door gdh
24 January 2026, 17:19:28
24 January 2026, 17:11:28
Die Sauerlandbahn - Tijdperk III door Frank 123
24 January 2026, 17:00:50
heeft iemand ideeën voor een baan van 120CM bij 240CM? door Ronald69
24 January 2026, 16:47:55
24 January 2026, 15:50:12
Oudere Marklin S3/6 opleuken door Robkop
24 January 2026, 15:19:07
24 January 2026, 15:05:32
Handleiding Trix Express 2232 BLS 255 door stoombr38
24 January 2026, 13:36:46
ICR-rijtuigen, voor welk merk ga je? LSmodels, PBmodels, Exact Train of Piko? door Hammondman
24 January 2026, 13:28:12
Big Scale Trains - NS SLT in H0 door hmmglaser
24 January 2026, 13:11:19
Auteur Topic: Line-up foto's van modellen  (gelezen 542181 keer)
Syb030
  • Ik ben ook: Sybs_modellen op insta!
Re: Line-up foto's van modellen
« Reactie #1080 Gepost op: 05 December 2019, 01:00:04 »
Triootje.
« Reactie #1081 Gepost op: 10 December 2019, 21:33:25 »
En er past er geen een op mn baan van 1980  :laugh:
Over een jaar of 3 wanneer ik verhuist ben, maak ik eerst een plank in mn treinkamer en dan zet ik ze achter elkaar en upload een nieuwe foto  (y)
Train-Science.com
Train-Science github
It ain't rocket science ;-)
Hellstech
« Reactie #1082 Gepost op: 21 December 2019, 20:07:32 »
Ik heb mijn reeks Lima's BR152 compleet, alleen de Rivarossi HR2250 ontbreekt nog...…
Mike
Lima sinds 1977, Roco sinds 1981....gestopt in '86......herintreder sinds 2015
  • Twentelijn 1968-1980
« Reactie #1083 Gepost op: 01 January 2020, 21:58:30 »
Een duo Baldwin/Westinghouse/HEEMAF/Werkspoor van old-skool Märklin (NS 1223 en 1202):
In het kader van de kerstvakantie worden ze door de Commissie oogluikend toegelaten in de woonkamer, dus dan komen ze uit de welbekende doos om de spaken te strekken en is er een fotomoment zoals hierboven te regelen. Uiteraard rijden ze bij deze gelegenheid op ratelende metalen M-rails van Märklin, op de vloer.
Lolke Bijlsma
  • Noorwegen jaren tachtig en negentig in HO (DCC)
    • Dombas in model.
« Reactie #1084 Gepost op: 02 January 2020, 00:13:34 »
Een paar modellen van de grote V160 familie op een rijtje:
- Fleischmann 215 034-0
- Brawa 216 221-2
- Fleischmann 218 413-3
- Liliput 219 001-5
DB V160 modellen in HO
Lolke
Rondje_HO
« Reactie #1085 Gepost op: 02 January 2020, 00:47:30 »
Oh, dat is gelijk mooi om te vergelijken  (y)  Brawa is mooi vind ik, ik mis eigenlijk alleen nog de Roco  ;)
Lolke Bijlsma
    • Dombas in model.
« Reactie #1086 Gepost op: 02 January 2020, 03:25:51 »
De Fleischmann 215 is technisch hetzelfde als de huidige Roco 210, 215 en 218. Ik heb nog geen Roco 218 op dit moment maar wel een Roco 210, wat natuurlijk vrijwel hetzelfde model is.
Op dit plaatje zie je de:
- Roco 210
- Roco oer 215 (uit de jaren zeventig)
- Brawa 216
- Fleischmann 218
De Brawa 216 modellen zijn mooie modellen maar ik ben geen fan van metalen (zink) kappen. Het detail dat je kan krijgen in plastic is toch net weer even mooier. Wat ook opvallend is, is dat qua kap de Fleischmann 218 (eerste versie uit 1981) nog best mee kan. De aandrijving is helaas een heel ander verhaal.
Lolke
CKLX
    • Secondtrains.com
« Reactie #1087 Gepost op: 02 January 2020, 14:28:31 »
Lolke,
Mooie vergelijking! Ik heb zelf de Fleischmann 218 uit 1981 (met ronde motor) en de Brawa 216. De Fleischmann is inderdaad nog steeds heel mooi.
De Brawa vind ik ook niet slecht. Deze rijdt in elk geval goed. Hoe is de Liliput in vergelijking met de andere? Het front is net een tikje anders.
Groeten, Cock.
Dick55
« Reactie #1088 Gepost op: 02 January 2020, 16:24:37 »
Mooie serie. Ik heb nog een Lima V160.
Wat een hoop merken maken een model als je het eens op een rijtje zet.
Zal eens mijn 2200-en op de foto zetten.
Lolke Bijlsma
    • Dombas in model.
« Reactie #1089 Gepost op: 03 January 2020, 00:29:24 »
De Lima V160 heb ik vroeger als kind ook wel gehad maar die heb ik niet meer. Het is trouwens een grappig model. Het heeft het dak van een V160 voorserie (001-010) maar de rest van de kap is volgens als de serie-variant.
Dan veel merken een model maken komt omdat er veel varianten in de modellen is. Voor een leek zullen we wel allemaal gelijk zijn maar voor de liefhebber en kenner zijn er heel veel verschillende modellen. Ze zitten er allerlei detail verschillen in de diverse deel series van de 218 (draaistellen, dakopbouw).
De Brawa rijdt inderdaad heel goed. Ik heb onlangs de 216 221 van geluid voorzien, en dat maakt het met de mooie rijeigenschappen helemaal een feest.
Als je goed kijkt dan heeft elk merk wel een iets andere kijk om de neus. De Liliput neus is inderdaad net even anders dan de Brawa maar die is weer net even anders dan de Fleischmann (oud) of Roco (nieuw).
Lolke
« Reactie #1090 Gepost op: 03 January 2020, 10:07:53 »
Leuk zo'n rijtje V160's. Wat me opvalt is dat die Fleischmann 218 duidelijk groter is dan de rest van de familie, of ligt dat aan de foto?
Op de analoge kerstbaan hier is afgelopen week nog meer old-skool Märklin NS-materieel gesignaleerd:
Te zien zijn, van voor naar achteren:
Märklin 3055, NS 1205 met A-seinbeeld
Märklin 3055, NS 1216
Märklin 3055, NS 1212 met gele neusbovenkant
Märklin 3424, NS 1139
De 1200's komen alle uit de jaren '70. De oorspronkelijke mal stamt zelfs uit 1965. Voor die tijd vind ik het een heel acceptabel model, ondanks dat het wat te klein is om voor 1:87 door te kunnen gaan. De 1139 stamt uit de jaren '80 en heeft geen metalen kap zoals de 1200's, maar een plastic kap. Technisch is er ook het eea veranderd. Zo is het mechanische rijrichtingsomschakelrelais vervangen door een electronisch exemplaar en er is een nieuwe motor gemonteerd. De topsnelheid ligt daardoor beduidend hoger, waardoor analoog rijden echt een uitdaging wordt vanwege de snelheidsverschillen met het overige materieel.
Uiteraard rijdt alles op de ratelende M-rails, anders is het niet echt ;D
« Laatst bewerkt op: 03 January 2020, 10:15:22 door 1200blauw »
bosje77
« Reactie #1091 Gepost op: 04 January 2020, 21:40:56 »
Hieronder even een line up van de fleischmann kleintjes  (y) en 1 Roco 😜
Het is ff een panorama foto geworden in de vitrine dus niet de mooiste foto maar goed ze staan op een rij.
Gr robin
Patrick1975
« Reactie #1092 Gepost op: 05 January 2020, 00:18:17 »
Ik zou al die grote loks weg doen,
3 grote tegen 12 kleintjes ;D Bespaart je veel ruimte in de vitrine in iedergeval ;D
Rondje_HO
« Reactie #1093 Gepost op: 05 January 2020, 01:37:00 »
@Lolke: nog bedankt voor de aanvulling!   (y)
dh3201
« Reactie #1094 Gepost op: 18 January 2020, 15:26:42 »
Tijd voor een nieuw line-upje:
