€88.00
€-162.00
Lobomotion69
om 03:31:30
NL-baan in Canada
om 02:17:48
Verwisselen koppelingen Hamo 1205
hmmglaser
om 00:33:52
Modeltreinenbeurzen
om 00:10:03
Project seaside Germany
20 October 2025, 23:26:48
Het bouwen van een Philotrain 2400 kit
Huup
20 October 2025, 23:22:53
Märklin 2025
Edwin2121992
20 October 2025, 23:11:41
Schroefkoppeling voor H0.
Edwin2121992
20 October 2025, 23:09:16
Modelspoor Vereniging Nijkerk MVN Nijkerk
Train Charter Services
20 October 2025, 23:03:33
MODELSPOOR by MTD - 2025 - 18 & 19 oktober 2025 in Edegem (B)
20 October 2025, 22:52:31
20 October 2025, 22:24:31
T.Spat
20 October 2025, 22:19:35
West-Brabantse modelspoordagen
HenkN
20 October 2025, 21:25:38
Werking Piko goldcap i.c.m. met niet-Piko decoder
De eerste Ivo
20 October 2025, 21:21:20
20 October 2025, 21:16:39
NL cameo layout (0,26m2)
Joran
20 October 2025, 20:38:07
Cherteau, fictieve Waals industriedorp
20 October 2025, 20:36:29
20 October 2025, 20:23:16
Diorama Oelde Mittelweg Hp
20 October 2025, 20:23:03
20 October 2025, 19:43:39
20 October 2025, 19:22:16
20 October 2025, 19:17:34
20 October 2025, 19:07:07
Zaterdag, 1 november 2025 | 7e Ruilbeurs MSV Post B
20 October 2025, 18:46:48
Pendel module Viessmann 5214
Te 2/2
20 October 2025, 17:57:31
Huup
20 October 2025, 17:55:12
Het einde van de RhB- Chiavenna Stazione Merci
AP3737
20 October 2025, 17:51:57
gtw6016
20 October 2025, 17:25:44
Bruggen-IG - brug over de Poldervaart Schiedam/Kethel
Forever Rocofan
20 October 2025, 17:22:45
20 October 2025, 16:41:37
Digitaal
E8a Broadway Limited (N-spoor) met sound, rijden ho maar
Topic: E8a Broadway Limited (N-spoor) met sound, rijden ho maar (gelezen 2391 keer)
Robert_N-Nm
Fan van Zwitsers Spoor N(m)
Re:E8a Broadway Limited (N-spoor) met sound, rijden ho maar
Reactie #15 Gepost op:
27 August 2011, 01:12:14 »
Hoi Ronald,
Alle hardwarematige resets heb ik uitgevoerd onder analoge spanning. Dan heb ik gewoon contact als ik de schuif openzet en doet de lok keurig netjes z'n reset-ding (een koppelgeluidje). Het heeft alleen geen effect op het functioneren in DCC. Hij blijft stoïcijns staan zonder ook maar iets te doen. Ik krijg m'n vinger er dus niet achter, adres 3, adres 100 er gebeurt niets. Ook niet als ik de knop van de muis volledig opendraai. Activeren van de functies 6 of 9, geen soelaas.
Met opstartcyclus wordt neem ik aan het starten van de motor--> stationair draaien --> gassen bedoeld. Dat doet de lok keurig in analoge modus.
Misschien doet de weerstand nog wel iets, die heb ik er niet tussen zitten.
Maar goed, ik hoop dat die Challenger niet zo gaat lopen doen...want dit is knap lastig
Robert
p.s. Misschien een keer tegenover de Lenz zetten, daar staat een complete programmeerhandleiding voor in het bijbehorende infoboekje?
Fan van Zwitsers spoor N(m)
Robert_N-Nm
Reactie #16 Gepost op:
27 August 2011, 15:23:31 »
We hebben er beweging in
Maar dan niet meer als 3 cm en toen stond de lok weer stil digitaal. De lok knippert af en toe een beetje (dus ergens is er wel contact, maar niet continue) op de DCC baan. Blijft alleen wel vreemd dat ie dan wel goed rijdt analoog.
Robert
Robert_N-Nm
Reactie #17 Gepost op:
31 August 2011, 00:11:39 »
Hoi Hoi,
Update: Vanavond even bij Guus (Piksov) de beruchte E-unit losgelaten en uiteraard rijdt deze daar zonder problemen rond onder de openDCC-centrale
. Probleem zit dus ergens tussen Centrale enerzijds en decoder anderzijds. Schiet mij maar lek
Robert
Digitaal
