Vandaag om 00:16:59
Welke centrale is betrouwbaar? door Michiel VL
Vandaag om 00:08:33
Vandaag om 00:05:01
Ondergrond modelspoorbaan door HenkN
25 January 2026, 23:34:12
Faller 2026 door Floris Dilz
25 January 2026, 23:33:48
24 en 25 Januari 2026 modelspoorweekend Ewijk door neudalhausenstadbahn
25 January 2026, 23:25:04
25 January 2026, 23:21:42
Au bord de la Cèze door WimNa
25 January 2026, 23:18:06
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door NTeering
25 January 2026, 23:04:06
25 January 2026, 22:23:42
Länderbahn en Reichsbahn locomotieven. door wob
25 January 2026, 22:17:45
Toon hier je nieuwe (model-) spooraanwinst(en)... door 1200blauw
25 January 2026, 22:01:06
Toon hier je (model)TRAM foto's. door Charles_
25 January 2026, 22:00:08
Interesse stamtafel/club Amersfoort? door Sikko
25 January 2026, 21:56:58
25 January 2026, 21:46:52
Bruine NS 1200s - Treinsamenstellingen. door Vislijn
25 January 2026, 21:27:45
Zaterdag, 31 januari 2026 | 8e Ruilbeurs MSV Post B door Carl
25 January 2026, 21:27:21
25 January 2026, 21:11:21
25 January 2026, 21:03:30
Molenbaan (werktitel) door Marty
25 January 2026, 20:56:36
Modelbaan in schaal N - 520x80cm - schaduwstation door 1op160
25 January 2026, 20:56:17
Wissels omzetten met luchtdruk door Hans van de Burgt
25 January 2026, 20:55:54
25 January 2026, 20:42:00
Altbau e-loc BR163 zelfbouwen in H0 door Quinzeedied
25 January 2026, 20:31:37
Kortsluiting. Maar waarom dan toch? door puntenglijder
25 January 2026, 20:30:51
Oudere Marklin S3/6 opleuken door puntenglijder
25 January 2026, 20:27:23
25 January 2026, 20:22:14
Retrobahn goes to the States: Bergamot Creek door Frits C
25 January 2026, 20:15:02
Modelspoorfans in Amersfoort gezocht! door Martijnstein
25 January 2026, 20:03:36
De Oosthoek (lokaalspoorlijn periode III, diesel) door Ronald Halma
25 January 2026, 19:50:32
Auteur Topic: Bunker  (gelezen 101836 keer)
  • Moderator
    • sleutelspoor
Re:Bunker
« Reactie #180 Gepost op: 23 October 2011, 12:11:09 »
Ik ben er zeker van dat jullie voor 100% gelijk hebben. Ik heb dit langeafstands vliegtuig (bouwpakket) gelijk met het landingsvaartuig gekocht. Ik dacht dat het voor de sfeer wel aardig over kwam om er een plaatje van te maken :)
Wat mij zo op dit "treinen" forum opvalt, is dat er zoveel kennis aanwezig is. Ieder  "foutje" wordt onmiddelijk afgestaft door gefundeerde kritiek (y) Houwen zo.
  • Moderator
    • sleutelspoor
Re:Bunker
« Reactie #181 Gepost op: 23 October 2011, 12:24:28 »
Dit komt beter over! Alhoewel ik er helemaal niet zeker van ben of "wij" daar ook gevlogen hebben?
WimC
  • Spoor N
Re:Bunker
« Reactie #182 Gepost op: 23 October 2011, 13:00:06 »
In ieder geval niet daarmee. Dat is een D-21, zo te zien? Die vlogen na de meidagen van 1940 niet meer. Daarna bestond de nederlandse luchtmacht niet meer.
Bij de RAF waren wel een paar squadrons met nederlandse vliegers (squadron 321 tot en met 323, volgens mij). Daarvan vloog volgens mij de eerste met spitfires. En die zullen vast ook wel met D-day hebben gevlogen. Rond die tijd zullen ze met een spitfire Mk. IX hebben gevlogen.
Geallieerde vliegtuigen vlogen met D-day (en daarna) met invasiestrepen.
Grt, Wim
  • Moderator
    • sleutelspoor
Re:Bunker
« Reactie #183 Gepost op: 23 October 2011, 13:03:52 »
Het is een Fokker D XXI. Ik heb even geen Spitfire, vandaar
WimC
  • Spoor N
Re:Bunker
« Reactie #184 Gepost op: 23 October 2011, 13:08:18 »
Andere opties zijn (zo uit mijn hoofd) een B-25 Mitchell, B-26 Marauder, Hawker Typhoon, Mustang, Thunderbolt. En er zijn er vast nog wel meer te bedenken.
Grt, Wim
Marinus
  • save our planet - it's the only one with chocolate
Re:Bunker
« Reactie #185 Gepost op: 23 October 2011, 13:11:56 »
de duitsers vlogens op D-day zelf met 2 "twee" !! vliegtuigen van het typ FW190-D... ( ook te zien in de film "the longest day "  ... het is gemakkelijker om geallieerde vliegtuigen te nemen want daar vlogen op de eerste dag van D-Day 11590 stuks rond   ;)
groetjes,
Marinus
  • Moderator
    • sleutelspoor
Re:Bunker
« Reactie #186 Gepost op: 23 October 2011, 13:14:30 »
Zo heb ik het plaatje even uit de hand gemaakt ;D Elke illusie en sfeer is hier verloren gegaan.
Jan-Peter
  • Bnlx treinendokter.
Re:Bunker
« Reactie #187 Gepost op: 23 October 2011, 14:10:13 »
Hallo Sobat,
Maar we hebben in ruil hiervoor wel een aardig blik in de 'kombuis' gekregen!
Jan-Peter
  • Moderator
    • sleutelspoor
Re:Bunker
« Reactie #188 Gepost op: 23 October 2011, 15:08:32 »
Zo hoort het ook. Denk je dat een ieder weet wat de Kombuis is?? :P
« Laatst bewerkt op: 23 October 2011, 16:57:07 door Sobat Kras »
  • Moderator
    • sleutelspoor
Re:Bunker
« Reactie #189 Gepost op: 23 October 2011, 17:07:57 »
Vandaag maar eens aan de andere kant van het dio begonnen.De zgn Duitse kant.
Het lokje had bepaald geen Wehrmachts uitstraling en daar moest nodig iets aan gedaan worden.
De eerste laag grijs zit er voor proef op. Lampen, ladders en een enkel raam moet nog verdwijnen.
Met een geladen Wehrmachtstrein voor de bunkers.
Als je de foto goed afsnijd, zie je niet wat er zich aan voorkant afspeelt! ;D Op dit deel speelt Heinrich nog de baas.
« Laatst bewerkt op: 23 October 2011, 18:51:55 door Sobat Kras »
  • Moderator
    • sleutelspoor
Re:Bunker
« Reactie #190 Gepost op: 24 October 2011, 13:10:01 »
Het lokje wat verder aangepast.
Jan-Peter
Re:Bunker
« Reactie #191 Gepost op: 24 October 2011, 22:29:51 »
Hallo Sobat,
Komt ie weer met gezeur  ;)
Staart gebalanceerd ammunitie zie alleen bij vliegtuigen.
De schattige kannonnetjes van jou hebben trekken en velden. Kannonen gebruiken rotatie stabilisatie.
Overigens gaat tegenwoordig wel staart gestabiliseerd munitie door de kanonloop, zogenaamde Sabots (what is in a name), die om de regel te bevestigen ook dus zonder staart komen (goalkeeper etc).
De sabots verlaten de loop als normale kogel, maar verliezen snel hun omhulling, om windweerstand tegen te gaan.
Bij mortieren heb je lopen met en zonder trekken en velden.
Overigens zijn er in de buurt van vliegvelden wel overgebleven bommen misbruikt als, demolitielading of bermbom.
Voor de rest ziet het er bijzonder aardig uit.  (y)
Jan-Peter
« Laatst bewerkt op: 24 October 2011, 22:37:06 door Jan-Peter »
  • Moderator
    • sleutelspoor
Re:Bunker
« Reactie #192 Gepost op: 25 October 2011, 11:29:56 »
Hallo Sobat,
Klop ook, dit zijn de nog niet aangebrachte bommen die onder de Focke Wulff horen te hangen. Trouwens, ik geloof nooit dat de ladder dat gewicht zal houden ;)
Laten we het dan hier maar op houden :)
Jan-Peter
  • Moderator
    • sleutelspoor
Re:Bunker
« Reactie #193 Gepost op: 26 October 2011, 19:32:58 »
beetje aangepast met zoeklicht en baliijzer
Dit is nog voor dat de LCT-s op het strand aankwamen.
T.Spat
Re:Bunker
« Reactie #194 Gepost op: 26 October 2011, 20:19:02 »
Sobat, even vraagje ;)
heeft dit locje in Afrika gediend?
Het palmboomlogo is van het Afrikakorps...
Verder een indrukwekkende dio (y)
Tis
