Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: OHMB Station EDE 1925  (gelezen 91404 keer)
Beached
Re:OHMB Station EDE 1925
« Reactie #435 Gepost op: 11 August 2012, 12:11:44 »
Nu maar hopen dat 'ie niet gaat overgeven ::) ;D
Ik heb geen ervaring met washprimer, maar kunstofprimer zal ook best werken op metaal. Ik gebruik ook vaak kunstofprimer op kunstof/messing hybride modellen zonder problemen.
  • Team Mitropa
« Reactie #436 Gepost op: 11 August 2012, 13:20:27 »
ja ik pak de kunststofprimer
  • Team Mitropa
« Reactie #437 Gepost op: 08 December 2012, 16:50:47 »
nou het spuitwerk zit er al een paar maanden op
Afbouwen nog ff geen zin in gehad.
  • Team Mitropa
« Reactie #438 Gepost op: 08 December 2012, 16:52:51 »
wel met iets nieuws begonnen gisteravond.
Er liggen hier nog een paar philotrain kits me aan te kijken.
Philo kit nr 23 SS 3as postrijtuig.
trapje en handrail over de zijkant en treeplanken plaats ik na het spuiten.
nu snel verder met een Philo kit 33 HSM C11.
« Laatst bewerkt op: 08 December 2012, 16:55:18 door roadster36 »
  • Team Mitropa
« Reactie #439 Gepost op: 09 December 2012, 23:07:17 »
Ik ben nu de philotrain kit nr 33 HSM C11 aan het bouwen
ik snap helemaal niks van de draaistel bevestiging
moeten de piefjes van het draaistel er af?
als ik de ronde schijf onder de bodem soldeer en de piefjes verwijder is de bevestigings pen/schroef met veer veel te lang
zou het een optie zijn om de schijf op de bodem te solderen , dus in het interrieur en een nieuwe bus onder de bodem te maken?
eigenlijk is de blanke schroef veel te lang
de veer gaat ruim door het gat in het draaistel en doet dus niks
kan iemand eens kijken hoe het kant en klaar zit
gr Jan
« Laatst bewerkt op: 10 December 2012, 02:45:17 door roadster36 »
Karst Drenth
    • Plan U op Sleutelspoor
« Reactie #440 Gepost op: 09 December 2012, 23:14:16 »
D'r hoort een busje met sluitplaatje bij Jan. Net als ik bij de MK DE-III gemaakt heb.
Dus:
Messing bus onder de vloer, dan draaistel, dan sluitplaatje dan veertje dan schroef.
Wil je het heel fraai maken, dan maak je een busje om het schroefje dat tussen messing bus en schroefkop past. Het slutiringetje en veertje schuift dan weer om het busje heen.
Grtzz,
Karst
  • Team Mitropa
« Reactie #441 Gepost op: 09 December 2012, 23:15:31 »
dit snap ik ff niet.
gevonden: pagina 4 diesel 3 topic (y)
een foto maakt veel duidelijk  ;D
« Laatst bewerkt op: 09 December 2012, 23:22:08 door roadster36 »
Karst Drenth
« Reactie #442 Gepost op: 09 December 2012, 23:21:43 »
Een busje ( 2.5mm buiten, 2.0 binnen ) van ca. 10mm lang. Dit busje schuif je over het schroefje, zodat je het vast kunt draaien tegen de messing schijf die je onder de vloer soldeert.
Om het draaistel te bevestigen steek je het busje over het schroefje, dan het veertje, dan het ringetje. Het ringetje zal in het blijven rusten en het veertje tegenhouden. schroefje met busje gaan door het ringete en draaistel heen en schroef je in de messing schijf vast.
Grtzz,
Karst
Karst Drenth
« Reactie #443 Gepost op: 09 December 2012, 23:22:29 »
Veertje is dus niet strikt noodzakelijk ;)
  • Team Mitropa
« Reactie #444 Gepost op: 09 December 2012, 23:22:44 »
yep zo ga ik het ook maken
  • Team Mitropa
« Reactie #445 Gepost op: 11 December 2012, 00:34:17 »
na de C11 ook meteen begonnen aan de HSM AB
al die pokkehandgreepjes zitten er nu op ;D
al zie ik nu er weer een paar die nog een nabehandeling behoeven grrrrrr.
« Reactie #446 Gepost op: 11 December 2012, 20:59:20 »
T leven van een modelspoorder gaat niet altijd gelijk over rails  ;D
  • Team Mitropa
« Reactie #447 Gepost op: 18 December 2012, 01:02:41 »
AB 5001-5056 ex HSM
andere kant
HSM C11
bakken staan nog los op het onderstel ;D
Martin Welberg
  • FYA !!!
  • OO. Organisatie OntraXS!
« Reactie #448 Gepost op: 18 December 2012, 01:10:38 »
Kekke karretjes  (y)
  • Team Mitropa
« Reactie #449 Gepost op: 18 December 2012, 01:27:03 »
ja in 5 dagen 3 rijtuigjes ;D
ik mag niet mopperen
foefje uitgedacht voor de bankjes.
morgen ff uitproberen ;D
« Laatst bewerkt op: 18 December 2012, 01:41:12 door roadster36 »
