12 February 2026, 23:41:19
Spoorwegmuseum in zwaar weer door WesleyMunnik
12 February 2026, 23:20:49
12 February 2026, 22:30:31
12 February 2026, 22:25:10
Spotten in Sloehaven en Zeeuws Vlaanderen door Huibert
12 February 2026, 22:11:03
Lok adres programmeren lukt niet met multimaus door Cegielski
12 February 2026, 22:02:11
12 February 2026, 21:55:06
Stub switches door Klaas Zondervan
12 February 2026, 21:28:45
12 February 2026, 21:15:21
RailBOX Accessoire Decoder RB4400 door Steven Loosman
12 February 2026, 21:15:20
Traincontroller software gaat stoppen. door reinderlf
12 February 2026, 21:12:47
12 February 2026, 21:09:20
Bediening OOC terminal Oss door timtrein
12 February 2026, 19:50:02
12 February 2026, 19:42:24
12 February 2026, 18:50:46
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robkop
12 February 2026, 18:42:35
Roco 70788 2400 met Zimo MX645 acceleratie settings door Steven Loosman
12 February 2026, 18:12:17
Station Weesp door virmfan
12 February 2026, 18:05:15
12 February 2026, 18:01:04
Voordelige treinkaartjes door Quinzeedied
12 February 2026, 18:00:49
12 February 2026, 17:46:46
12 February 2026, 17:29:22
12 February 2026, 17:18:29
12 February 2026, 17:03:17
4 april Het Stoomgenootschap naar Köln door Seinhuis
12 February 2026, 16:55:32
Minstens 5 jaar geen treinverkeer Groningen-Leer [D] door Noordster
12 February 2026, 16:51:57
12 February 2026, 16:42:09
Spoor vernieuwing Oisterwijk door Charles_
12 February 2026, 16:42:05
Nederlands-materieel in Spoor-1 door FritsT
12 February 2026, 16:41:07
Spoor vernieuwing Oisterwijk door Daan Knoben
12 February 2026, 16:25:59
Auteur Topic: Schaal 1:100 1:93 1:87  (gelezen 9477 keer)
Jeroen1975
  • GTW in de tuin
  • 45mm, zelfbouw, Brits- en Achterhoeks smalspoor
    • Jeroen's Treinen Site
Re: Schaal 1:100 1:93 1:87
« Reactie #15 Gepost op: 27 January 2007, 07:41:24 »
Niet helemaal waar, schaal 0 is eigenlijk 1:43,5.
http://home.hetnet.nl/~rkievit/arch/gauges.html voor het hele spoor 0 overzicht.  ;D
Treinen van britse eilanden
Treinen uit de achterhoek
Wurlitzer
« Reactie #16 Gepost op: 28 January 2007, 12:26:49 »
Prima site net wat ik zocht. Bedankt voor de korrektie van Modelspotter.
H.O is dus echt de helft van O.  Jaap
Donaldus
    • Mijn modelspoorpagina
« Reactie #17 Gepost op: 28 January 2007, 19:00:42 »
Niet helemaal waar, schaal 0 is eigenlijk 1:43,5. H0 = 1:87 omdat het 3,5 mm op een voet schaal  is, een voet (12 inch) in werkelijkheid. Vreemd is natuurlijk de verhouding van het metrische stelsel met het Engelse stelsel. 00 (1:76) werd 4 mm to the foot (= 304,8 mm).
Het verschil tussen het Europese 1:87 en het Engelse 1:76 wordt ook wel eens verklaard op grond van het verschil van het profiel van vrije ruimte dat in Engeland kleiner is dan op het continent. En dat heeft weer te maken met het feit dat in Engeland krappere bogen ("bochten" is geen spoorse term) worden gebruikt omdat het landschap wat heuvelachtiger is.
DB-tijdperk 3, 2-rail DC, Lenz Digital Plus / LDT, Railware.
mmhajvth
  • fulltime busy
  • IC met 1762+1773 op Ht richting Mt op 23-4-06
    • Markenburg
« Reactie #18 Gepost op: 28 January 2007, 19:32:16 »
Niet alleen dat maar de engelse hebben ook als eerste de trein in het leven geroepen. En hebben daarbij weinig naar de toekomst gekeken de mensen op het vaste land hebben later de trein overgenomen en meteen het profiel breder gehouden omdat met er in Engeland er ook achter kwam dat dat misschien wel handig geweest zou zijn. Maar het vanwege het inmiddels opgebouwde netwerk nog maar moeilijk veranderen, en dus maar niet hebben aangepast.
Om even terug te komen op de schalen het is wel grappig dat H0 tegenwoordig nogsteeds vele inkortingen en verkleiningen kent zoals hier voor al besproken (denk aan 1:90 1:93 1:100 enz) terweil andere schalen neem bijvoorbeeld de kleinere, daar minder last van hebben. Wellicht ligt dat aan het feit die later ontwikkeld zijn, en daardoor maatvaster zijn door betere afspraken?
m.v.g.
Mark
love to build realistic     let's be kind.
Jeroen1975
  • GTW in de tuin
« Reactie #19 Gepost op: 30 January 2007, 18:07:30 »
Zal ik jou ook corrigeren ?
het is H0 met de 0 van 0,1,2,3,4 etc en niet met de O van ABCD etc.
Succes
« Laatst bewerkt op: 30 January 2007, 18:11:13 door Jeroen1975 »
