Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Welk (hand)boortje is geschikt om met 0,4 mm boortje in te boren?  (gelezen 5883 keer)
Han Zijlstra
    • Trainspecials
Re:Welk (hand)boortje is geschikt om met 0,4 mm boortje in te boren?
« Reactie #15 Gepost op: 24 October 2010, 19:49:08 »
Pin Vise  240 is ook prima te gebruiken.
http://www.kadee.com/htmbord/page240.htm
Ivo tB
« Reactie #16 Gepost op: 24 October 2010, 20:39:25 »
Jeroen,
Even contact opnemen met GM&S en vragen naar een Archimedes-boortje.
Werkt prima met boortjes vanaf 0,3mm.
Grtz,
Ton
Kijk zo'n ding moet ik ook altijd nog eens hebben. Ik heb meestal te weinig geduld bij de stand van Piet, maar bestellen via Internet of telefoon lukt me ook prima. Ik gebruik een pin vice met 2 kanten, waarin omkeerbare spantangetjes zitten, waardoor er 2 diametergroepen in passen (begrijpen jullie me nog?). Maar 0,4mm is niet goed vast te houden en ik pas meestal de tip à la Ronald toe, waarmee ik een papiertje of een stukje tape om de boor probeer te wikkelen. Maar dit boortje lijkt me ook wel wat. Je hebt dan alleen 2 handen nodig voor de boor of zie ik dat verkeerd?
@Jeroen,
Een troost, 0,4mm boortjes breken we allemaal regelmatig. Maar met een pin vice is de kans wel kleiner. Het getoonde boormachientje met een groot tandwiel geeft geheid problemen.
Ivo
Ivo
TonM
« Reactie #17 Gepost op: 24 October 2010, 21:43:00 »
@Ivo,
Mijn ervaring met modelbouwen is, dat je vaak drie of meer handen nodig hebt.....  ;)
ff serieus: Je hebt voor dit boortje twee handen nodig om hem snel te laten draaien. Met een beetje handigheid lukt het soms om met één hand zowel het werkstuk als de boor in positie te houden en dan de andere hand te gebruiken om de boor te laten draaien.
Voor boortjes van 0,3 en 0,4 mm gebruik ik hem ook met één hand op dezelfde manier als een pin vice, omdat het mijn enige houder is die zulke dunne boortjes goed vasthoudt.
Grtz,
Ton
