Oudere Marklin S3/6 opleuken
hmmglaser
om 00:18:17
om 00:02:10
29 January 2026, 23:52:57
reinderlf
29 January 2026, 23:21:21
29 January 2026, 23:18:11
reinderlf
29 January 2026, 23:13:59
29 January 2026, 23:08:32
meino
29 January 2026, 23:00:52
29 January 2026, 22:34:20
Dirk
29 January 2026, 22:34:00
29 January 2026, 22:29:42
29 January 2026, 22:27:19
29 January 2026, 22:20:32
BrightonBelle
29 January 2026, 22:20:11
29 January 2026, 22:05:05
Stub switches
29 January 2026, 22:02:56
marctrein
29 January 2026, 21:41:24
29 January 2026, 21:28:18
weslyr
29 January 2026, 21:11:59
Vroeger
29 January 2026, 20:55:42
Gare de Tannay, Frans N-spoor
Rik
29 January 2026, 20:52:30
29 January 2026, 20:46:35
Modelspoorbeurs MSC Spijkspoor 7 februari 2026
Suchet
29 January 2026, 20:11:43
29 January 2026, 19:59:56
Igra model 2026
TGVfreak
29 January 2026, 19:55:08
Oosthoek
29 January 2026, 19:32:06
Slijptrein
29 January 2026, 19:31:43
Mte korting
barry1972
29 January 2026, 19:10:50
Steven Loosman
29 January 2026, 18:35:56
29 January 2026, 18:27:54
Ombouwen
Topic: Ombouw/Pimpen Bolle neuzen (gelezen 978394 keer)
T.Spat
Reactie #2460 Gepost op:
06 September 2019, 22:13:27 »
Vriendelijke groeten, Tis
Reactie #2461 Gepost op:
07 September 2019, 18:51:58 »
Tweede cabine zit er nu ook in, de zilveren rand is niet zo schitterend gelukt, komt later wel in orde met wat vervuiling hier en daar.
Er komen weeral een pakje draadjes te voor schijn. Extra oranje lampen in de neuzen liggen klaar.
Eric.
Reactie #2462 Gepost op:
08 September 2019, 12:33:04 »
Voorbereidende werkjes doen, LED voorzien van draden en weerstanden.
LED die apart moeten kunnen branden.
Vreemd zicht zo met een lampke in de deur, rare Zweden toch.
Eric.
Laatst bewerkt op: 08 September 2019, 13:45:09 door bollen neus. Reden: spellingsfout
Reactie #2463 Gepost op:
10 September 2019, 09:30:14 »
Eric.
Reactie #2464 Gepost op:
10 September 2019, 17:08:21 »
Bovenste LED ingebouwd, deze is apart te schakelen (azchterzijde van de locomotief)
Klein oranje LED aangesloten om te testen. Zilveren rand in messing.
Nog wat kleine werkjes doen deze week want eind deze week naar Portugal. In Oktober naar specialist voor linkerhand, afspraak is reeds gemaakt, dus weet ik ook niet hoe het verder gaat verlopen.
Eric
Reactie #2465 Gepost op:
11 September 2019, 12:54:29 »
Draadjes aangesloten, zijn apart te bedienen.
Eric.
Rondje_HO
Reactie #2466 Gepost op:
11 September 2019, 17:55:58 »
Oeh mooi, net echt zo
Met vr. groet, Martijn.
Mijn banen:
Nieuw; nu met foto's:
Reactie #2467 Gepost op:
12 September 2019, 09:00:59 »
Tis en Martijn, dank voor de reacties.
Nu bezig LED samen te stellen wit/rood, zijn wel aparte LED geen bi-colors. Die komen dan onderaan te zitten om te kunnen wisselen van kleur bij rijrichtingen. Achteraan de locomotief zijn bovenste en de 2 onderste apart aan te klikken via de decoder (maar das voor later) Der kan nog zoveel verkeerd gaan
Eric.
Huib
Reactie #2468 Gepost op:
12 September 2019, 11:15:28 »
Hoi Eric,
Hoort dat extra lampje in de deur niet rood te zijn? Meen zoiets op de foto's van het grootbedrijf gezien te hebben.
Groeten!
Huib
Buitenlust in 1:43,5 | professioneel prutser|
www.prutsvlog.nl
www.magicaminiatura.com
| instagram.com/magicaminiatura
Reactie #2469 Gepost op:
12 September 2019, 12:08:30 »
Dag Huib, inderdaad rood, dit dat erin zit is oranje.
Eric.
IJsselsteyn
Reactie #2470 Gepost op:
12 September 2019, 13:05:33 »
Waartoe dient die extra lamp in de deur bij de Zweedse spoorwegen?
Steyn
Reactie #2471 Gepost op:
12 September 2019, 13:12:01 »
Daar moet ik jou het antwoord schuldig van blijven, weet het niet. Trouwens zelf heb ik dus nog nooit zo'n machiene in het echt gezien. Bouw enkel wat na in de mogelijkheden die ik heb.
Eric.
Reactie #2472 Gepost op:
12 September 2019, 18:03:43 »
@Huib, hier zie je dat het oranje is, maar door licht gaat dit wat naar de "witte" kant op. Bij evetueel kunnen zou ik nog wat extra rood kunnen verven op dit LED.
Eric.
Reactie #2473 Gepost op:
14 September 2019, 16:56:16 »
Kant van de bestuurder en personeel is nu ook voorzien van alle LED. Verdere afwerking is voor binnen een 14 dagen, nu wat valiezen inpakken en morgen richting Portugal om uit te rusten.
Eric.
Reactie #2474 Gepost op:
26 September 2019, 10:51:34 »
Al een klein beetje verder gedaan aan model van de Stukton.
Al een kleine opstap gezet op linkerkant, reeds 2 gaten minder te vullen.
En dan alle bedradingen nog eens uittesten en uitmestennaar een draadje of 5per kant, dan nog 2 pinkdozen gaan halen en solderen om de oranje lampen op dak te laten functioneren.
Het is niet veel maar beter dan niets te kunnen doen.
Eric.
Ombouwen
