Vandaag om 01:13:43
Vandaag om 00:09:10
Lemke 2025 door arnaud-ns/htm
Vandaag om 00:05:10
CIWL of toch niet?? Maar wat dan wel? door Dennis1984
27 October 2025, 23:54:05
27 October 2025, 23:37:19
Had de NS4903 rangeerlicht? door prutser
27 October 2025, 23:21:06
Vraag over vervangmotor Lima-locomotief door Arjen52
27 October 2025, 22:52:56
Scandinavië-IG: Skandinavisk bangården. Voor op Scandinavië gerichte spoorzaken door Ronzol
27 October 2025, 22:25:58
27 October 2025, 22:25:57
27 October 2025, 22:04:19
Yet Another Servo Decoder door Dennis1984
27 October 2025, 22:00:56
Toon hier je nieuwe (model-) spooraanwinst(en)... door MathynK
27 October 2025, 21:59:16
Da's Daz 2 door Huup
27 October 2025, 21:47:59
mDDM, waarom 3 draaistellen? door Eric B
27 October 2025, 21:46:40
27 October 2025, 21:17:04
Zoutkamp 1921 - 1942, Het plan door Noordster
27 October 2025, 20:32:24
Crème daken mitropa rijtuigen epoche 2 door Stefan88
27 October 2025, 20:31:18
Line-up foto's van modellen door Jeroen95
27 October 2025, 20:12:18
Digitaal-delta door Biesje
27 October 2025, 20:07:34
Minibaan Visserskaai H0 door NS264
27 October 2025, 19:59:28
Seinen programeren met de Pro-Link naar de 10837 dec. door bask185
27 October 2025, 19:58:39
27 October 2025, 19:30:50
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Gerrit H
27 October 2025, 19:17:08
27 October 2025, 19:16:31
27 October 2025, 18:53:13
27 October 2025, 18:52:43
TAMS PZS-2.2 door bask185
27 October 2025, 18:49:53
Retrobahn goes to the States: Bergamot Creek door hervé
27 October 2025, 18:28:25
15 November Modelspoorbeurs en Houten digitaal door maartenvdb
27 October 2025, 18:23:36
Problemen met rookgenerator KM1 materiaal in spoor 1 door Biesje
27 October 2025, 16:55:39
Auteur Topic: IRM verlichting + poging boveninterieur  (gelezen 4372 keer)
Hans sprinter
  • Vriend van vlaflip
Re:IRM verlichting + poging boveninterieur
« Reactie #15 Gepost op: 30 October 2009, 13:10:02 »
Inderdaad geeft dit hoop.
Welk tape, en hoe is de "plak" duurzaamheid daarvan?
Heb je daar ervaring mee? In het gemiddelde plastic tape heb ik niet veel vertrouwen vwb de duurzaamheid.
Het laat na een tijdje meestal (zonder merk uitzonderingen) weer los.
Ziet er in ieder geval nu goed uit  (y)
Hans
Jos
« Reactie #16 Gepost op: 30 October 2009, 13:40:21 »
Ik heb inderdaad niet al te veel ervaring met deze tape, het plakt niet echt stevig en we moeten maar afwachten wat het gaat worden.
Ik heb het ruim 3 jaar geleden ook in de Piko ICE3 (voor het zelfde doel) gebruikt en daar blijft het wel op z'n plaats zitten, dus hoop is er wel.
De tape is ooit eens gekocht bij Action en is 18 mm breed en zat in een pakje met 5 veschillende kleuren.
Mvg, Jos
MRDirect, Koploper, EDITS-booster, zelfbouw wissel/sein/servo decoders en S88's, 80% NS
GW
« Reactie #17 Gepost op: 30 October 2009, 13:51:32 »
Wat te denken van een paar lagen Acryl verf zwart mat aan de binnenkant? Dat zou toch hetzelfde effect moeten geven als tape?
Gerard
Jeroen Water
  • NS tijdperk IV (1973/1974)
« Reactie #18 Gepost op: 30 October 2009, 14:11:27 »
Dat zou je wel verwachten, maar als ik het laatste bericht van Jos zo lees, begin ik te vermoeden dat hij isolatietape gebruikt. En dat is natuurlijk wel dik spul. Daar schijn je niet zo makkelijk met een paar LEDs doorheen.
Nadeel van schilderen is ook weer dat je exact langs de ramen moet schilderen.
Jos: hoe is trouwens het zicht bij daglicht? Je kijkt bij een Rivarossi IRM nogal erg makkelijk naar binenn, ben benieuwd hoe dat staat met zwarte tape aan de binnenkant.
Wordt de gele buitenzijde nu niet wat donkerder als er een zwarte tape aan de binnenkant zit?
Ben alleen wel bang dat het een raar gezicht wordt met de motorwagen waar het benedendek niet verlicht kan zijn.
Mocht zwart isolatietape werken, kan natuurlijk ook geprobeerd worden of wit isolatietape werkt. Dan heb je ook meteen de (bijna) juiste interieurkleur  ;D ;D
In ieder geval een goede poging om IRM te verlichten! Succes verder!
Jos
« Reactie #19 Gepost op: 30 October 2009, 14:52:36 »
Beste Jeroen,
Het is inderdaad isolatietape.
Bij daglicht zie je er helemaal niets van, vooral omdat ik de bovenverdieping erbij heb gemaakt, dan worden de zijkanten aan de binnenkant niet meer zichtbaar.
De kleur geel blijft hetzelfde in tegenstelling tot verf dan wordt het geel duidelijk donkerder (ik heb maar een klein stukje met verf als proef gedaan omdat het niet is terug te draaien als het niet bevalt).
Bij de motorwagen breng ik alleen licht aan bij de deuren omdat daar aan de bovenkant geen plaats is voor passagiers.
Ik heb ook geel isolatietape geprobeerd en dat geeft bijna het zelfde resultaat, zwart werkt iets beter.
Mvg, Jos
Albert Bas
« Reactie #20 Gepost op: 30 October 2009, 15:38:46 »
Toch die aluminium zelfklevende folie proberen, kleeft geweldig goed, is absoluut lichtdicht en hittebestendig.
Albert (y).
_Jasper_
    • RailZminiworld
« Reactie #21 Gepost op: 30 October 2009, 15:52:27 »
Echter gaat dat gaat ook als spiegel/reflector werken, en ik weet niet of je daar gelukkig van wordt. Wit isolatie tape is volgens mij nog steeds de best genoemde oplossing hier.
Groeten Jasper
    • Het Groterdam Project
« Reactie #22 Gepost op: 30 October 2009, 16:00:04 »
Een idee voor Gerco is om een heel dunne plaat styreen te gebruiken, en die te maken inclusief uitgesneden ramen.
Dan zwart spuiten en als masker erin lekker tegen de wanden ?
Erik
  • treinen snuffelaar
« Reactie #23 Gepost op: 30 October 2009, 17:23:18 »
Kan je toch ook zelf proberen om zoiets te maken?.
Erik-Jan
Geoffrey Korstanje
  • prutser
« Reactie #24 Gepost op: 30 October 2009, 18:25:36 »
Vind niemand het eigenlijk storend dat je de motorwagen niet kan verlichten  ???
Juist om die reden zou ik er helemaal niet aan beginnen. Of alles of niks.
Jos
« Reactie #25 Gepost op: 03 November 2009, 16:47:20 »
Alle rijtuigen (zoveel als mogelijk) zijn nu voorzien van bovenverdieping, binnenverlichting en passagiers.
IRM
Mvg, Jos
« Laatst bewerkt op: 03 November 2009, 16:48:57 door Jos »
Bart Mestrom
« Reactie #26 Gepost op: 03 November 2009, 16:53:28 »
Wel jammer dat het motorrijtuig geen binnenverlichting kan ontvangen
  • Team Mitropa - OHMB
« Reactie #27 Gepost op: 03 November 2009, 16:56:39 »
Dat ziet er best netjes uit! Dat boveninterieur kan dus eigenlijk heel simpel. Misschien een beetje blauw er bij om stoelbekledingen te simuleren..
Ik zou overigens voor de afdichting van de wanden zelf de voorkeur geven aan mat-lichtgrijs gespoten zelfkleven alu-folie, daar heb ik in diverse hondekopprojecten goede ervaringen mee.
Iemand trouwens nog wat gehoord van Manuel, die bezig was interieurtjes te gieten voor de IRM? Daar wacht ik eigenlijk op en hij heeft het blijkbaar te druk om zijn PM's te lezen....
Bessel
« Laatst bewerkt op: 04 November 2009, 12:34:13 door Besselspoor »
RETROBAHN A.G.
Jos
« Reactie #28 Gepost op: 03 November 2009, 17:08:27 »
Ik heb ook al meerdere mailtjes naar Manuel gestuurd maar nog niets van hem gehoord.
Mvg, Jos
