Ontraxs 2026 door Peter J K
19 February 2026, 23:40:05
Houten Plus zaterdag 21 februari 2026 door p-kokkie
19 February 2026, 23:36:38
Vraagje over digitaliseren Hamo Motorpost door borotof
19 February 2026, 23:21:45
Multimaus Zwart door Caspar25
19 February 2026, 22:59:58
US diorama in H0 door Jelmer
19 February 2026, 22:45:52
19 February 2026, 22:26:14
Duitse/Belgische tegenhangers van Beneluxspoor/3railforum? door sncf231e
19 February 2026, 22:15:30
Aachenau West door Peter J K
19 February 2026, 21:58:27
Stub switches door Hans1963
19 February 2026, 21:54:31
Onlangs gespot - gefotografeerd, de foto's door Menno de Vries
19 February 2026, 21:24:50
Trein Eindhoven Brussel? door Hlv53
19 February 2026, 21:09:45
19 February 2026, 21:01:31
19 February 2026, 21:00:55
19 February 2026, 20:53:32
Fabrieksplaten NS E-lok 1600 en 1700 door Kees-Jan
19 February 2026, 20:52:45
PB Models, ICR-rijtuigen door De eerste Ivo
19 February 2026, 20:49:36
19 February 2026, 20:40:09
19 February 2026, 20:30:26
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Luit
19 February 2026, 20:13:45
19 February 2026, 19:55:44
19 February 2026, 19:21:22
19 February 2026, 19:15:50
19 February 2026, 18:34:04
Vraagje over servo aansluiting door Joost O
19 February 2026, 17:19:49
Fleischmann 1898 set analoog>digitaal door Robert uut Salland
19 February 2026, 17:15:26
Cv instellingen Fleischmann Sprinter door 008200
19 February 2026, 17:08:22
19 February 2026, 17:01:54
19 February 2026, 16:47:17
H0e pizza layout door Sven
19 February 2026, 15:39:10
NSB 20b en 21b door Simplex
19 February 2026, 14:49:30
Auteur Topic: Kleinst mogelijke bocht  (gelezen 18283 keer)
Wim Ros
  • BHV
    • Perrongeluk
Re: Kleinst mogelijke bocht
« Reactie #15 Gepost op: 07 January 2009, 14:20:35 »
MR ik weet niet waar je die meter breedte vandaan hebt, volgens mij is de afmeting 160x54. in het openings bericht.
Mvg
MR
« Reactie #16 Gepost op: 07 January 2009, 14:29:18 »
Ik bedoelde de baan Gleisdreieck van Henning Stelter op de pagina van Carl Arendt onder het kopje "HO (1:87): CURVED SWITCHES CREATE A SMALL, URBAN LAYOUT" Die is 1 meter breed, maar de kleinste boog in de baan neemt niet de hele breedte van de baan in beslag.
Marco
Ronaldk
« Reactie #17 Gepost op: 07 January 2009, 14:47:21 »
Beste MR,
Nou de kleinste straal van marklin is bij C-rails: 360mm, dat is een cirkel diameter van 720mm (72cm) dus dat de kleinste boog niet de gehele breedte van 100cm in beslag neemt is logisch de volgende straal is Marklin R2 = 437,5 mm (diameter 875mm)
Groet Ronald.
MR
« Reactie #18 Gepost op: 07 January 2009, 15:27:29 »
Ik drukte mij wat voorzichtig uit. Maar wanneer ik het baanontwerp zo bekijk, dan zitten er werkelijk hele kleine boogjes in.
groeten,
Marco
« Laatst bewerkt op: 07 January 2009, 16:22:14 door MR. Reden: schrijffout »
  • Schwarzburg-Neuffen-Bahn
« Reactie #19 Gepost op: 07 January 2009, 16:14:08 »
Ik weet dat het hier om Marklin-rails gaat, maar even om de gedachte te bepalen: Fleischmann heeft bij modelrails industriebogen van 250 mm, cirkelgrootte 530 mm buiten diameter. Die zouden precies op de gegeven ruimte van 54 centimeter passen. Op die industriebogen van Fl kunnen korte wagens en locjes rijden. Met andere woorden: Marklinflex zodanig buigen dat 530 mm wordt gehaald, kan een baantje opleveren waarop met beperkingen gereden kan worden.
Qpers
« Reactie #20 Gepost op: 07 January 2009, 16:33:54 »
Dat is goed nieuws! Ik ga morgen gewoon even van die flexrails halen en dan probeer ik het eens ;) De trein hoeft van mij ook helemaal niet lang te zijn. Als er nog 1 personenwagon achter kan vind ik het al prima.
Bedankt voor alle info! Ik laat nog wel wat weten/zien als het gelukt is!
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #21 Gepost op: 07 January 2009, 17:11:51 »
Dan mag je sleper onder de lok wel niet te lang zijn, want anders heb je een kei van een kortsluiting.
Mvg
Wim.
Grumpy
  • Een tevreden Märklin Digitaal rijder.
  • Oost-Souburg.
    • http://www.modelspoorh0.nl
« Reactie #22 Gepost op: 11 January 2009, 13:38:58 »
Met alle respect, maar dit ga je niet redden met 2205 K-flex-rail.
De radius 360 mm is de opgegeven minimale mogelijkheid met de 2205.
En dan heb ik het nog niet eens over de vervolgboog aan te sluiten.
Houd er rekening mee dat je dan een hele korte loc dient te gebruiken.
De 2210 K-rail is al te krap voor diverse locs.
Met vriendelijke modelspoor groetjes,
Riny
Aspelix
« Reactie #23 Gepost op: 24 January 2009, 03:24:56 »
IK denk ook, dat de K-flexrail deze boog niet aan kan.
De Piko Flexrail kan dat in iedergeval wel, maar dan moet je er kontaktpunten bij kopen.
Succes, Ruurd.
Inderdaad: een UITdaging om BINNEN de grenzen te blijven.
