Vandaag om 00:15:48
Vandaag om 00:04:16
13 February 2026, 23:59:24
PB Models, ICR-rijtuigen door MarkSpoor
13 February 2026, 23:57:00
13 February 2026, 23:55:09
13 February 2026, 23:30:44
13 February 2026, 23:08:59
Spoorwegmuseum in zwaar weer door Ferdinand Bogman
13 February 2026, 23:07:10
13 February 2026, 23:03:50
13 February 2026, 22:58:20
13 February 2026, 22:49:17
Roco 63421, hoe kom ik bij de stroomafname lipjes? door Albert de Heer
13 February 2026, 22:38:18
PT Trains 2026 door Chris Westerduin
13 February 2026, 22:10:50
Stub switches door Frank 123
13 February 2026, 21:50:55
13 February 2026, 21:49:12
13 February 2026, 21:41:19
13 February 2026, 21:24:24
13 February 2026, 21:13:45
13 February 2026, 20:31:01
Euronight 295 samenstelling door EN446
13 February 2026, 20:29:30
13 February 2026, 20:05:35
RailBOX Accessoire Decoder RB4400 door Etsmodelspoor.nl / Modelspoorbaanwinkel.nl
13 February 2026, 19:47:25
13 February 2026, 19:33:16
US diorama in H0 door Eric B
13 February 2026, 19:23:39
13 February 2026, 19:19:59
13 February 2026, 18:55:31
13 February 2026, 18:32:55
13 February 2026, 18:19:53
13 February 2026, 17:47:25
NMJ 2026 door hansberekvam
13 February 2026, 17:40:43
Auteur Topic: Keyboard 6040  (gelezen 5765 keer)
Wim Ros
  • BHV
    • Perrongeluk
Re: Keyboard 6040
« Reactie #15 Gepost op: 13 October 2008, 23:01:05 »
Is het keyboard ook los geweest van je intellibox?
Anders gezegt zit deze nog nog goed ermee verbonden?
Mvg
Wim.
ernst
Re: Keyboard 6040
« Reactie #16 Gepost op: 14 October 2008, 00:05:57 »
Jazeker, het keyboard zit goed verbonden aan de Intellibox
groetjes
Ernst
Wim Ros
  • BHV
    • Perrongeluk
Re: Keyboard 6040
« Reactie #17 Gepost op: 14 October 2008, 00:16:49 »
Is het eraf geweest? Of is het blijven zitten zoals het zat?
Mvg
Wim.
Evert M
Re: Keyboard 6040
« Reactie #18 Gepost op: 14 October 2008, 06:09:40 »
In welke volgorde van werken heb je de pinnetjes veranderd?
Je hebt de voeding uitgezet.
Apparaat losgekoppeld
Pinnetjes veranderd
Apparaat aangekoppeld
Voeding weer aangezet
Of heb je een andere manier van werken gebruikt?
ernst
Re: Keyboard 6040
« Reactie #19 Gepost op: 14 October 2008, 07:44:19 »
ik heb de pinnetjes veranderd terwijl de 6040 nog was vastgekoppeld en de voeding aan stond.
mvg
Ernst
Wim Ros
  • BHV
    • Perrongeluk
Re: Keyboard 6040
« Reactie #20 Gepost op: 14 October 2008, 09:35:56 »
Prima, maar dan zal de verandering die je gedaan hebt niet werken, daar had je dus last van, kapot gaat hij er niet van, maar een verandering in de stand van de dipswitsches aan de achterzijde zal alleen overgenomen worden als de voeding eraf is en hij opnieuw wordt aangezet.
Dus om het adres van het keyboard te kunnen wijzigen moet eerst de spanning eraf, dan veranderen en dan aanzetten.
Mvg
Wim.
ernst
Re: Keyboard 6040
« Reactie #21 Gepost op: 14 October 2008, 10:56:36 »
Hoi Wim
Dat heb ik daarna gedaan, maar de schakelaars functioneren nog steeds niet
groetend
Ernst
Wim Ros
  • BHV
    • Perrongeluk
Re: Keyboard 6040
« Reactie #22 Gepost op: 14 October 2008, 11:28:54 »
Ernst als de units niet van elkaar afgeweest zijn, dan zal er iets mis zijn met de stand van de schakelaars. Dus ik stel voor alles uit te zetten , alle schakelaartjes aan de achterzijde allemaal in de aan stand te zetten, en de spanning er opnieuw op te zetten. Helpt dat allemaal niet dan zal er iets aan de binnenzijde van de 6040 kapot zijn. En dan kunnen we je hier niet verder helpen.
Mvg
Wim.
ernst
Re: Keyboard 6040
« Reactie #23 Gepost op: 14 October 2008, 20:48:08 »
Hoi Wim
Bedankt voor al je adviezen.
tot een volgende keer
groetjes
Ernst
