Vandaag om 05:19:49
Vandaag om 02:38:52
Vandaag om 00:32:31
Vandaag om 00:07:35
17 February 2026, 23:53:29
17 February 2026, 23:33:12
17 February 2026, 23:17:28
17 February 2026, 23:03:24
17 February 2026, 23:02:46
17 February 2026, 22:53:29
17 February 2026, 22:52:33
17 February 2026, 22:25:54
17 February 2026, 21:53:49
17 February 2026, 21:52:21
17 February 2026, 21:41:11
17 February 2026, 21:41:05
17 February 2026, 21:37:24
17 February 2026, 20:39:30
17 February 2026, 20:27:09
17 February 2026, 20:06:51
17 February 2026, 19:36:48
17 February 2026, 19:34:07
17 February 2026, 19:21:28
17 February 2026, 19:13:40
17 February 2026, 19:13:00
17 February 2026, 18:23:36
17 February 2026, 18:14:32
17 February 2026, 18:01:26
17 February 2026, 17:48:00
17 February 2026, 17:29:24
Auteur Topic: Groterdam- (bug) ?  (gelezen 26466 keer)
santerdam
Re: Groterdam- (bug) ?
« Reactie #90 Gepost op: 28 September 2008, 00:36:28 »
Uit de logging van m'n router lees ik af dat de groterdam site calls doet naar www.google-analytics.com - die wil java-scripts uitvoeren die geblokkeerd worden.
Sander
    • Het Groterdam Project
« Reactie #91 Gepost op: 28 September 2008, 01:52:55 »
Interessant,
Daar laat ik Joost morgen even naar kijken !
IC 2000
« Reactie #92 Gepost op: 28 September 2008, 09:22:00 »
ziggo (casema) hier loopt gewoon met Groterdam.
  • NS 1607 Vlissingen
  • Zal 't gaan, ja!
    • Tramlijn Maastricht-Vaals
« Reactie #93 Gepost op: 28 September 2008, 09:44:15 »
Ik heb ook Ziggo, en het loopt perfect
En was 1680 cm Lang
(Rotterdam, 2009)
Ernest
« Reactie #94 Gepost op: 28 September 2008, 09:45:46 »
Ik zit in Maarssen; oude Casema.
Kan enkel Chris'homepage openen. Daarna loopt 'ie vast.
Ernest
HO, 2 rail digitaal, IB en MM, NS, geen tijdperk binding.
Sander Fondse
  • MSc Micro-Electronics
« Reactie #95 Gepost op: 28 September 2008, 10:20:27 »
Zijn er meer probleemgevallen Ziggo Den Haag ? (het oude wanadoo)
Regio Alphen a/d rijn, ex-Casema (ex-Wanadoo).
Wat die calls betreft. Ik gok dat dat de oorzaak is (hoop ik). Het zou kunnen dat die Site bij wijze van spreke bedorven is.
Peter van der Leek
  • Administrator
    • Somda
« Reactie #96 Gepost op: 28 September 2008, 11:21:44 »
Een heel erg groot deel van de websites heeft tegenwoordig de code van Google Analytics er op staan. Als dat het probleem is zouden jullie ook op bijvoorbeeld Somda.nl of op Vergelijk.nl problemen moeten hebben.
Peter van der Leek
ronald56
« Reactie #97 Gepost op: 28 September 2008, 12:26:45 »
En toevallig ook in de regio Den Haag Ronald ?
Klopt , Het oude Wannadoo , dus het witte Motorola SB4200E surfboard cable modem
@ Peter , met Somda en Vergelijk heb ik geen problemen.
ps) vanaf woensdag geen ex Casema/Wannadoo (Ziggo) meer , maar dan echt Ziggo , kijken of dat iets uitmaakt .
« Laatst bewerkt op: 28 September 2008, 12:47:56 door ronald56. Reden: aanvulling »
  • in 1964 met modelspoor begonnen
  • M* & bezig te digitaliseren
« Reactie #98 Gepost op: 28 September 2008, 15:50:59 »
Hier ook maar eens getest,
Provider at Home.nl nu dus ook Ziggo.
Ondanks een wat mindere betrouwbaarheid laadt het Groterdam hier (in het zuiden des lands) behoorlijk snel. Ook de vervolgpagina's
De groeten van Rob
Jupie
« Reactie #99 Gepost op: 28 September 2008, 18:39:46 »
Ik  heb 11/9 j.l. een vraag gesteld op de site van Chris. Tot nog toe geen antwoord gehad. Lijkt me sterk, maar heeft dit ook te maken met de 'bug'?
mvg.
Willem.
« Laatst bewerkt op: 28 September 2008, 18:45:33 door Jupie »
Tinussie
« Reactie #100 Gepost op: 28 September 2008, 18:42:22 »
Hè gedverdemme Sander! Is dat net zo iets als bedorven stroom? ;D
Overigens hier in Vleuten met XP SP3 en IE6, Ziggo, modem zonder router direct op de PC ook noppes... >:(
@ Chris
Overigens (misschien heeft Joost er iets aan) krijg ik de eerste pagina wel, als ik één van de menu-buttons aanklik gebeurt er net zoals bij vele anderen niets... echter als ik dan je hoofdpagina refresh (ook niet met shift+refresh = 'harde' refresh) gebeurt er... ook niets ???
*** edit *** na de harde refresh krijg ik de hoofdpagina toch wel... na 5+ minuten...
mvg Tinussie.
« Laatst bewerkt op: 28 September 2008, 20:09:12 door Tinussie »
lokloods
« Reactie #101 Gepost op: 28 September 2008, 18:43:27 »
Ik kan de site van Chris ook niet krijgen via Ziggo. Binnen 3 weken de overstap naar XS en dan maar weer even kijken. Ook ik heb Chris al een paar vragen gesteld, doch ik krijg daar geen antwoord. Zal dus aan de verbinding liggen.
Wiebe
Camickaeze
« Reactie #102 Gepost op: 28 September 2008, 19:57:21 »
Omdat mijn vorige post niet veel goeds opleverde, heb ik dan maar even getest op welke machines de site het wel of niet doet:
Windows XP SP1, IE6
Windows XP SP2, IE6 & IE7
Windows XP SP3, IE6 & IE7
Windows Vista
Windows Vista SP1
Allemaal geprobeerd, werkt hier overal.. Provider is Ziggo, zowel hier als op m'n kantoor.. Geen probleempies hier!
Desalniettemin heb ik een zelfde soort probleem gehad (zie vorige post) en na het door mij beschreven stappenplan doorlopen te hebben waren de problemen opgelost..
EDIT: Het hele provider-idee is een beetje vreemd, aangezien de hoofdpagina wel wordt laten zien. Misschien onderstaand nog één reparatiepoging, al kan ik het me niet voorstellen:
Start >> Uitvoeren >> 'CMD' >> 'ipconfig /release' >> 'ipconfig /flushdns' >> 'ipconfig /registerdns' >> 'ipconfig /renew'..
« Laatst bewerkt op: 28 September 2008, 19:59:57 door Camickaeze »
Ik bén vreemd, en sta daarom altijd normaal op de foto!
Tinussie
« Reactie #103 Gepost op: 28 September 2008, 20:13:53 »
Het provider-idee is inderdaad vreemd, je krijgt duidelijk wel verbinding echter niet met de 'achterliggende' pagina's... alleen is het wel zo dat er veel problemen zijn met Ziggo gebruikers... Misschien toch geen toeval...?
Het hele ipconfig gebeuren heb ik net maar even gedaan maar heeft helaas niet geholpen...
Mvg Tinussie.
jakop
« Reactie #104 Gepost op: 28 September 2008, 20:32:55 »
Geen probleem om de site van Chris te bereiken, elke achterliggende pagina wordt meteen weergegeven. Internet via Ziggo (vh. Casema).
