€88.00
€-162.00
om 01:54:23
om 00:33:43
Veevervoer ss/ ns
Edwin2121992
10 September 2025, 23:52:59
Modelspoorbaan van Einte
10 September 2025, 23:36:09
MichielB
10 September 2025, 23:16:30
tandwiel lux modellbau
Olav
10 September 2025, 22:59:14
Rookgenerator wil niet werken, van piko 50652 = BR 93 in Rocrail
10 September 2025, 22:56:39
10 September 2025, 22:51:19
Module vliegveld Jan van Mourik
10 September 2025, 22:47:52
BNLS-Werkspoor - Railhopper SM90
Joz
10 September 2025, 22:46:29
Mijnbouw Indonesië
10 September 2025, 22:26:28
Vislijn
10 September 2025, 21:42:40
PWM regelaar Kato 22018 sx standaard controller
Pollux
10 September 2025, 21:36:30
Peter Soonius
10 September 2025, 21:32:12
Tandwiel 13 tands tbv aandrijfasje
Hasenwald
10 September 2025, 19:28:42
VAM65
10 September 2025, 19:18:35
Koppelingsmechanisme klemt?
Robert vh Prutsert
10 September 2025, 19:12:10
Scandinavië-IG: Skandinavisk bangården. Voor op Scandinavië gerichte spoorzaken
Loki
10 September 2025, 19:06:47
Z21 en het programeren met de Z21App.
10 September 2025, 19:03:41
Da's Daz 2
10 September 2025, 18:37:27
10 September 2025, 18:29:04
Liliput Onderdeel NS 7851 stoomlok
Bas, Dordrecht
10 September 2025, 18:25:26
borotof
10 September 2025, 17:47:49
ES44C4
10 September 2025, 17:20:58
10 September 2025, 17:03:11
Ovaalramer in messing. Schaal 0
10 September 2025, 16:57:23
De bouw van 'Ommelanden' (H0)
phdirk
10 September 2025, 15:57:32
10 September 2025, 15:03:22
BR-18.6 Schaal-0.
10 September 2025, 14:26:11
Swalbenburg, N modulebaan
10 September 2025, 12:07:16
Digitaal
Roco 61118 met 61197
Topic: Roco 61118 met 61197 (gelezen 5775 keer)
Private SNAFU
Member of the 1(to)87 gang
Re: Roco 61118 met 61197
Reactie #15 Gepost op:
07 September 2008, 17:51:24 »
RTFM = Read the Fine/F*cking Manual
Gr,
Bart
Website
NS - IVa (1968 - 1978) / Koploper / LocoNet / IB+ProfiBoss / Modulebouw
p.heinst
Reactie #16 Gepost op:
07 September 2008, 17:52:35 »
Bart,
Bedank
Gr Piet
Roco rijder met 2multimaus als slave, RouteControl, multimaus pro, Multizentrale pro als digitalesysteem/versterker, 4x booster, remgenerator en Rocomotion en Train-controller Gold 8.0 A3 en Rocomotion 10785 als terugmeldsysteem
Richard Snijder
een deel van mijn baan
Reactie #17 Gepost op:
07 September 2008, 18:38:12 »
Met 5 keer op + of 5 keer - er veranderde niets.
En Manuals lezen is mijn hobby onderhand dus daar ligt het zeker niet aan,maar met een huis waarvan het oudste gedeelte ouder is dan 200 jaar en een Waterkrachtcentrale waarvan het oudste gedeelte ook alweer uit 1928 stamt en als je dan ook nog eens in de Alpen op 1400 meter hoogte woont is een storing in de elektrische bedrading en fluktuaties in het aantal Hrz snel een feit,als je dan dagen maakt van tussen de 12 en 18 uur ,de hobby tussen de bedrijven door doet op de spaarzame vrije minuten,dan gebeurt alles in etappes .
Dan gaat het niet zo snel als bij sommige anderen hier die meer tijd hebben en daardoor vaak uren achtereen door kunnen werken totdat ze een nieuw te installeren nieuw onderdeel in een keer kunnen inbouwen,ik ben met het inbouwen van iets nieuws nu eenmaal vaak meerdere avonden bezig omdat ik vaak weggeroepen wordt tijdens de werkzaamheden.
p.heinst
Reactie #18 Gepost op:
07 September 2008, 18:56:40 »
Hallo Richard,
Het is ook niet mijn bedoeling om opmerkingen te plaatsen over het lezen van de manual, ik weet uit ervaring dat bij het programmerenvan de ontkoppeldecoder door vele de eerste keer deze fout is gemaakt.
Ik heb behoorlijk wat vragen gekregen naar aanleiding van de vertaalde handleiding of dat wel juist was zoals het er in staat, vandaar mijn vraagje of je het mogelijk in een andere volgorde was gedaan.
Maar goed ik weet niet of mijn handleiding die ik je toegestuurd hebt nog wat heeft bijgedragen tot de oplossing, is verder ook niet zo belangrijk, het belangrijkste is dat het nu werkt en dan is het ok.
Gr Piet
Richard Snijder
Reactie #19 Gepost op:
07 September 2008, 19:17:28 »
Piet ,jou werk is zeker niet slecht nog bedankt voor je hulp.
Wim Romijn
Reactie #20 Gepost op:
08 September 2008, 10:42:43 »
Waarom RTFM en DWEIS, moet dit niet zijn
LVDH en DWEIS.
Of je doet iets in het engels of in het nederlands maar nooit een mix van beide, want dan RMDWK.
p.heinst
Reactie #21 Gepost op:
08 September 2008, 11:13:40 »
Hallo Wim,
Zet er ook even de vertaling/betekenis bij van de letters dan ben ik en met mij mogelijk andere ook weer op de hoogte, bedank.
gr Piet
Wim Romijn
Reactie #22 Gepost op:
08 September 2008, 12:40:17 »
Raakt Men De Weg Kwijt of beter RMHSB Raakt Men Het Spoor Bijster.
Digitaal
