€88.00
€-162.00
om 00:42:55
07 October 2025, 23:55:21
info gezocht over ETS aandrijfunits
Tom Z.
07 October 2025, 23:18:42
Show je werkplek
07 October 2025, 22:44:01
LS Models/Lemke CityNightLine samenstelling??
jeremy23
07 October 2025, 22:39:36
Fleischmann rijtuig 5896
07 October 2025, 22:25:06
Bouw spoor nul modulebaan, Bahnhof Königshofen, tijdperk III
bernhard67
07 October 2025, 22:21:51
Tankinstallaties voor dieseltreinen
07 October 2025, 22:08:18
Station Roodeschool
07 October 2025, 21:46:54
Doornvliet
07 October 2025, 21:43:55
MODELSPOOR by MTD - 2025 - 18 & 19 oktober 2025 in Edegem (B)
BrightonBelle
07 October 2025, 21:33:43
Beneluxspoor Forum Modulebaan is te zien bij Carmeliet op stoom in 2025.
Dick55
07 October 2025, 21:19:00
Paul1969
07 October 2025, 20:56:45
Märklin 2025
barry1972
07 October 2025, 20:24:34
extra terugmeld module viessmann 5217
Kolho005
07 October 2025, 20:09:10
Franse lantaarnijzers in 1:87 gezocht
07 October 2025, 19:36:28
C12c rijtuig
07 October 2025, 19:35:38
Roco wagon openen
07 October 2025, 19:33:02
Wim1969
07 October 2025, 19:19:04
07 October 2025, 19:09:01
waterwagens
j.ossebaar
07 October 2025, 18:34:55
slechte stroomafname bij ROCO RH310 7120013
07 October 2025, 17:10:31
Modules van Kees Gorter (vervolg)
ca.gorter
07 October 2025, 16:49:12
Project seaside Germany
07 October 2025, 16:47:15
't Boemeltje
07 October 2025, 16:23:34
07 October 2025, 15:33:53
07 October 2025, 14:55:36
07 October 2025, 13:44:42
Op Zuid (NL H0)
07 October 2025, 13:35:20
Ik ben aan het opruimen.
07 October 2025, 13:33:31
Digitaal
gezamenlijk (zimo)decoders kopen
Topic: gezamenlijk (zimo)decoders kopen (gelezen 14048 keer)
Dirk J
Re: gezamenlijk (zimo)decoders kopen
Reactie #15 Gepost op:
06 September 2006, 23:00:43 »
Die logische uitgangen is o.a. op de 64. Over de 64H staat op
www.zimo.at
8 function outputs in two groups, max. output per group 0.5 A,
8 Funktionsausgänge
in zwei Gruppen (4 + 4) mit je 0,5 A (Summe),
koosvp
Reactie #16 Gepost op:
07 September 2006, 00:05:58 »
Koos bestelt
4 x MX64R idem met 8-pol. stekker per stuk 32,00
Fraaie actie! Hulde!
Groet
Koos
Als de Blokkendoos rijdt, is de avond verblijd
maartenvanderburgt
Reactie #17 Gepost op:
07 September 2006, 12:59:43 »
Uitgangen Zimo decoders, zonder functies aangegeven (behalve de standaard gebruikte lichtuitgangen)
ZIMO MX64 MX64R MX64F
1/ witte draad (front licht)
2/ gele draad (sluit licht)
3/ bruine draad
4/ groene draad
5/ soldeervlak, onversterkt
6/ soldeervlak, onversterkt
7/ soldeervlak, onversterkt
8/ soldeervlak, onversterkt
Onversterkt wil zeggen, alleen een logisch 0 (nul) of 1 (een) niveau, te vergelijken met aan of uit. Aan deze uitgang mag NIETS aangehangen worden, behalve een signaalversterker.
Over het aanhangen van een relais (NEE), transistorschakelaar (MISSCHIEN) of andere logische schakeling (die genoegen neemt met een zeer kleine stroom) doe ik geen uitspraken. Ik ben geen electronicus en neem hiervoor geen enkele verantwoording.
Zimo heeft voor de versterking de M4000Z, die ook door een eigen
? vervangen kan worden. Wat
?? is weet ik niet (geen electronicus) (transistor??) maar schijnt iedere electronicus je zo te kunnen vertellen.
MX64H MX64HR MX64V1 MX64V5
alle uitgangen zijn op de decoder al versterkt en er kan direct een belasting op aangesloten worden.
Maarten.
willem22
Reactie #18 Gepost op:
10 September 2006, 16:26:22 »
Bestelling willem 4 x MX64 a 29.85.
Goede zaak Sander!!
PS; Verneem de betalings voorwaarde nog wel.
willem
Sander
Reactie #19 Gepost op:
13 September 2006, 19:50:33 »
Nog 1 week en dan ga ik de balans opmaken.
Wie doet er nog meer mee?
Sander
Sander
Harry
Reactie #20 Gepost op:
16 September 2006, 19:41:04 »
Graag dan meenemen van de beurs in houten (indien mogenlijk):
2x MX64R idem met 8-pol. stekker 32,00
2x MX64F idem met 6-pol. stekker 33,00
Dat is dus een bruto prijs van : 130,00 Euro.
Gewensde betaalwijze etc.etc. lees ik hier nog wel of PM'tje (voorkeur).
Akties van Beneluxspoor, je kén niet zonder
Harry
H0e: Lilliput en Halling
koosvp
Reactie #21 Gepost op:
17 September 2006, 15:59:05 »
Koos heeft al besteld (zie hiervoor 4x MX64R)
Gaarne erbij:
2 x MX620N zonder stekker € 38,25 per stuk
Groet
Koos
Sander
Reactie #22 Gepost op:
18 September 2006, 18:16:26 »
nog 2 dagen....
Sander
Sander
Edsko Hekman
Nooit uitgeklust....
Reactie #23 Gepost op:
18 September 2006, 20:06:14 »
ik doe ook mee. Heb ik tenminste ook wat te doen op regenachtige (mid)dagen.
Ik wil graag het volgende bestellen:
MX64 3x
MX64R 1x
MX620 2x
Alleen de MX64R heeft een stekker nodig, de rest graag zonder stekker.
Edsko
Grasland
Sander
Reactie #24 Gepost op:
19 September 2006, 17:57:45 »
Morgen zo rond de klok van 18:00 maak ik de ballans op en ga ik de info doorgeven aan de importeur.
Daarna weet ik meer omtrent prijzen en afhandeling en welke data.
Laatste dag dus om nu nog mee te doen met deze bestelling!!!
Heb je ze nu niet nodig maar in de toekomst wel, pak dan je voordeel nu nog even mee..scheelt altijd iets.
Sander
Sander
Sander
Reactie #25 Gepost op:
20 September 2006, 20:26:00 »
Vanaf nu ga ik me bezig houden met het verdere verloop van deze actie.
Het wachten is nog op 2 reacties van mensen die het niet helemaal duidelijk vermeld hebben. Daarna verzend ik alles naar de omporteur en kijken we wat de korting zal zijn.
Daarna volgen de betaling gegevens en verdere afwikkeling.
Heb geduld, je hoort van me.
Sander
Sander
Sander
Reactie #26 Gepost op:
24 September 2006, 22:45:05 »
Heb op dit moment een email gestuurd naar Maarten voor de kortingen.
Zodra ik bericht terug heb zal ik iedereen die besteld heeft een persoonlijk bericht sturen met betaling gegevens.
Welke dan zo speodig mogelijk betaald dienen te worden zodat we ook snel (liefst op Houten) kunnen leveren.
Sander
Sander
Sander
Reactie #27 Gepost op:
26 September 2006, 19:40:11 »
Heren,
jullie hebben allemaal prive bericht van mij gehad. Met daarop enige instructies.
Een aantal heeft dit inmiddels uitgevoerd, ik zou het op prijs stellen als de overige mensen ook gehoor geven aan deze oproep zodat ik ieder naar tevredenheid de decoders op Houten kan uitleveren.
Uitstel van jullie kant betekend uitstel van leveren.
Sander
Sander
Harry
Reactie #28 Gepost op:
26 September 2006, 21:13:04 »
Sander, mooi gedaan (tot nu toe). Ik hoop (wens) dat iedereen vlot handeld.
Anders weet ik nog niet wanneer ik de decoders in ontvangst kan nemen.
Het liefst op 07/10. Want dan staat de wekker op 7 uur
Harry
koosvp
Reactie #29 Gepost op:
26 September 2006, 22:44:57 »
Sander,
Waar is mijn prive bericht?
In kom naar Houten en betaling is ruim voor die tijd geen probleem
Groet
Koos
Digitaal
