Schaal TT
T.Spat
02 February 2026, 23:50:58
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:59:03
02 February 2026, 22:43:31
Petertje
02 February 2026, 22:41:36
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
02 February 2026, 19:42:07
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Inrijbaan 240x120cm
02 February 2026, 16:29:13
Beekdaelen in H0
Topic: Beekdaelen in H0 (gelezen 50142 keer)
VulcanRaven
NS 1960 - heden
Re: Beekdaelen in H0
Reactie #45 Gepost op:
18 March 2024, 15:44:43 »
Die greenkeeper was een goede investering
Martijn
Reactie #46 Gepost op:
18 March 2024, 18:31:52 »
Wat een wereld van verschil zo
Link
Reactie #47 Gepost op:
27 March 2024, 22:17:23 »
Ik krijg hier zoveel inspiratie van hè. Fantastisch! Keep up the good work.
VulcanRaven
NS 1960 - heden
Reactie #48 Gepost op:
28 March 2024, 15:15:11 »
Bedankt heren!
Martijn
Stieven76
Reactie #49 Gepost op:
28 March 2024, 17:17:41 »
Gezellig zo!
Had je niet beter tussen de sporen eerst wat opgevuld vooraleer de ballast te strooien? Dan had je veel minder nodig.
VulcanRaven
NS 1960 - heden
Reactie #50 Gepost op:
29 March 2024, 11:00:45 »
Ik heb hier en daar wat opvulling gebruikt met overtollig XPS / Piepschuim. Ik gebruik het goedkoopste ballast van nog geen twee euro per zakje dus de schade valt gelukkig wel mee.
Martijn
VulcanRaven
NS 1960 - heden
Reactie #51 Gepost op:
21 May 2024, 20:48:41 »
Met het slechte weer vanavond weer even wat aan de baan gebouwd. Tussen beide stations zal het spoor door een uitgraving gaan lopen. Inspiratie hiervoor heb doe ik op uit de cover van Railfoto 2013.
Bron: railmagazine.nl
Vandaag de ruwbouw van de rechterheuvel gemaakt.
Martijn
Jeroen95
NS tijdperk IV/V/VI
Reactie #52 Gepost op:
22 May 2024, 06:35:07 »
Succes
Mvg
https://forum.beneluxspoor.net/index.php?topic=110113.0
DJV
Reactie #53 Gepost op:
22 May 2024, 07:44:02 »
Ducktape...??
Groeten Dirk Jan
V100 "manusje van alles".
VulcanRaven
NS 1960 - heden
Reactie #54 Gepost op:
22 May 2024, 16:01:55 »
Yes, de goedkoopste van de Action. Werkt heel erg goed, hele makkelijke manier om gladde hellingen te maken.
Op het Youtube kanaal van spoorinmodel.nl kwam ik dat tegen en sindsdien zelf ook op meerdere plekken toegepast.
Martijn
jandcargo
Reactie #55 Gepost op:
22 May 2024, 18:55:25 »
Oeioei, als dat maar goed gaat!! Is spekglad dus verf en lijm hecht er nauwelijks op en de kleefkracht laat te wensen over en gaat loslaten . Niet voor niets goedkoop.
Redding is misschien een spuitbus primer van de action Die is nl wel goed.
succes en sterkte,
jandcargo
VulcanRaven
NS 1960 - heden
Reactie #56 Gepost op:
22 May 2024, 19:07:38 »
Ik heb er tot nu toe gelukkig nog geen problemen mee gehad Jan. Ik smeer het geheel in met een dikke laag houtlijm en strooi er vervolgens een basislaag overheen (zand, grind of turf). Als dat eenmaal goed droog is geworden biedt dat een goede basis voor verdere bewerking. Maar het klopt wat je zegt, de 1e laag is altijd wat meer werk i.v.m. het gladde.
Laatst bewerkt op: 22 May 2024, 19:10:06 door VulcanRaven
Martijn
DJV
Reactie #57 Gepost op:
22 May 2024, 22:42:51 »
En zo heeft ieder zijn eigen methode.
Als je de piepschuimplaten ook gelijmd hebt had je er ook een laag lijm over kunnen smeren en daar een krant over kunnen leggen/lijmen.
Groeten Dirk Jan
einte
Tijdperk II - III
Reactie #58 Gepost op:
23 May 2024, 20:46:53 »
Hallo Martijn,
Goed idee om een berg in elkaar te plakken, met ductape?
Ben benieuwd wat dit gaat worden.
Groeten Einte
Mijn draadje
VulcanRaven
NS 1960 - heden
Reactie #59 Gepost op:
21 September 2024, 12:13:38 »
Wegens de zomer periode heeft de hobby zo goed als stil gestaan. De laatste tijd begint het weer te jeuken om langszaam verder te bouwen. Ik heb een tijdje terug buiten wat bovenleiding portalen in elkaar gezet. Ze zijn niet helemaal naar waarheid gebouwd maar ik vindt dat het meteen al een verschil maakt qua look op de baan. Als de portalen allemaal goed vast staan ga ik beginnen met ballasten van de rails op het tussenstuk. Daarna beginnen met het bos te maken eromheen.
Martijn
Beekdaelen in H0
