Schaal TT
T.Spat
02 February 2026, 23:50:58
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:59:03
02 February 2026, 22:43:31
Petertje
02 February 2026, 22:41:36
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
02 February 2026, 19:42:07
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Inrijbaan 240x120cm
02 February 2026, 16:29:13
Diorama creation workshop
Topic: Diorama creation workshop (gelezen 13193 keer)
olaf99
Re: Diorama creation workshop
Reactie #15 Gepost op:
27 September 2022, 18:38:01 »
Met de 3D jake resin zit ik op 5sec belichten.
Andere resin heb ik nog niet. Eerst de huidige voorraad opmaken.
Youtube kanaal:
http://www.youtube.com/user/olaf99a
Blog site:
http://bouwwerkenvanolaf.blogspot.com/
Facebook:
https://www.facebook.com/Bouwwerken-van-Olaf-374688453309634/
olaf99
Reactie #16 Gepost op:
01 October 2022, 14:54:21 »
Hallo
De buildplate samengesteld met de modellen.
Olaf
Youtube kanaal:
Blog site:
Facebook:
Reactie #17 Gepost op:
02 October 2022, 11:14:52 »
Netjes
Met hartelijke groet.
Dave
Rheinburg tijdperk V/VI
olaf99
Reactie #18 Gepost op:
02 October 2022, 14:28:39 »
Hallo
Dank je wel.
Eerste print. Helaas niet helemaal goed gegaan. Nu maar eens onderzoeken waar het allemaal aan ligt.
Olaf
Youtube kanaal:
Blog site:
Facebook:
olaf99
Reactie #19 Gepost op:
09 October 2022, 16:03:43 »
Hallo
Bulldozer in de maak.
Olaf
Youtube kanaal:
Blog site:
Facebook:
olaf99
Reactie #20 Gepost op:
28 April 2023, 20:07:12 »
Hallo
Ik heb een nieuwe print test gedaan. Helaas gaat het deze keer ook niet helemaal goed. Zie de video voor alle uitleg. Misschien toch maar een nieuwe printer kopen.
https://www.youtube.com/v/w0SkngX79VA
Youtube kanaal:
Blog site:
Facebook:
Reactie #21 Gepost op:
28 April 2023, 21:11:32 »
Wat ik zelf nooit zou doen is 1 model als geheel te printen
Altijd in delen. Alleen al om slechts enkele delen te moeten printen als het misgegaan is.
Als je het aandurft mag je het bestand als * stl wel naar me toesturen.
Kan ik eens kijken of er "schrijf-fouten" inzitten.
Ook zet ik alles gewoon horizontaal of verticaal. Geen schuine opstellingen.
En ik heb een anycube, zou kunnen testen voor je.
Groet Ronald Visser
Laatst bewerkt op: 28 April 2023, 21:16:45 door MOVisser
olaf99
Reactie #22 Gepost op:
29 April 2023, 15:35:48 »
Hallo
Ik heb de silce file bekeken in UVTools en hier en daar waren er wel wat eilanden maar die waren niet zo erg. Voor al bij het bandenprofiel van de graafmachine gaf hij veel eilanden aan. Maar ja om nu elk ribbeltje te voorzien van een support.... tja zit toch aan de onderkant.
Verder heb ik geen laag verschuivingen gezien.
Ik heb net een test gedaan met de "The Cones of Calibration" en het laatste deel was grotendeels afgebroken. Wel vreemd aangezien het bovenste deel 2.5mm dik is. Dat had toch moeten printen.
Misschien morgen een nieuwe poging met een langere belichting. De print duurde nu al 1u20min ( 5 sec belichting) en dan zouden we nog wat langer moeten wachten..
Olaf
Youtube kanaal:
Blog site:
Facebook:
olaf99
Reactie #23 Gepost op:
07 May 2023, 14:51:35 »
Ik heb een Elegoo Mars 3 pro resin printer gekocht en getest.
Zie mijn video update:
https://www.youtube.com/v/DtggHOVSnBU
Youtube kanaal:
Blog site:
Facebook:
Reactie #24 Gepost op:
07 May 2023, 20:12:59 »
Ik heb het instellen van printplaat omhoog en naar beneden anders ingesteld.
Veel minder snel dan op de video.
Ronald Visser
olaf99
Reactie #25 Gepost op:
07 May 2023, 20:34:12 »
Dat kan zeker. Dat had ik bij de halot one ook zo gedaan. Daar had ik 60mm/ min op en neer gedaan. Bij deze nieuwe printer heb ik de neergaande slag versneld. Tevens gebruik ik nu andere resin die aardig goed werkt met 2.5 sec in plaats van de 5 sec met de 3D jake resin.
In de handleiding van de elegoo printer wordt ook een hogere snelheid geadviseerd. De elegoo printer heeft trouwens ook de mogelijkheid om de snelheid in 2 stappen uit te voeren.
Het printen gaat in ieder geval sneller. In plaats van 10mm/uur gaat het nu met 17.5mm/uur.
Al met al blijft het moeilijk te bepalen waar e.v.t oorzaken van problemen liggen. Er zijn simpel weg te veel parameters. Zo als je in de video ziet zie ik verschillende dingen. Bij het ene moet de belichtingstijd omhoog terwijl het bij het andere juist weer omlaag moet.
Maar goed ik ga hier maar mee verder en e.v.t dingen aanpassen kan altijd.
Youtube kanaal:
Blog site:
Facebook:
olaf99
Reactie #26 Gepost op:
14 May 2023, 12:39:50 »
Hallo
De bulldozer is bijna klaar om geprint te gaan worden.
Olaf
Youtube kanaal:
Blog site:
Facebook:
olaf99
Reactie #27 Gepost op:
21 May 2023, 22:17:42 »
Ik heb een bulldozer en een vrachtwagen getekend met Blender. Ik print de modellen met de Elegoo Mars 3 pro printer en standaard resin beige.
https://www.youtube.com/v/Gt0EWSXLBCA
Youtube kanaal:
Blog site:
Facebook:
Reactie #28 Gepost op:
22 May 2023, 10:01:34 »
Waarschijnlijk een domme vraag,
wat gebeurd er als je belichtingstijd tijdens het printen te lang is?
Dave
olaf99
Reactie #29 Gepost op:
22 May 2023, 18:50:50 »
Dan worden de details minder scherp. En gaan onderdelen meer aan elkaar "smelten/ klonteren".
Youtube kanaal:
Blog site:
Facebook:
